Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 04-02-2014, 01:34 PM   #1
TakSD OP
Oddometer: 55
1190 R low speed wobble - any fix available?
I have read through many posts on the 990 handle bar wobble problems but I haven't really found a solution...
My 2014 1190 now has 2500km; yesterday it was like it was on rails and today while decelerating for some traffic lights took my hands off the bars and almost lost the bike!!! Tried it a few more times and when taking my hands off the bars at any speed from 50-90 km/h, they start to wobble. I could even feel it with my hands ON the bars at one point...
It is very annoying, especially knowing that the bike has a steering damper and simply was 100% ok yesterday... I put Pirelli scorpion trails on when the bike was new, simply because I don't trust the continentals... I must say till now the pirellis have performed impressively!
So here are any more details I can think of that might be relevant:
Front tyre needed 40 grams to fully balance from day 1. Re checked the balancing today and it was still OK
I checked could not feel any play on the axle, bearings, head etc
Suspension has been set to standard from day 1 and ran like on rails
I weight about 82kg so even the sag was fine
So do other have is problem?
Is there a permanent solution?
Is there something else I could check that might need adjusting?
Wouldn't you be pissed???
Cheers
1190R for everything, EXC 450 Six days for the rough stuff
TakSD is online now   Reply With Quote
Old 04-02-2014, 01:39 PM   #2
Black Hills
Oddometer: 1,185
Check tire pressure first (F&R), that can cause it. Also check for cupping on the tire. make sure you check axle torque and bearing play front and rear. after that steering head and swingarm bearings.
your answer is most likely the tire unless you have been doing creek crossings.
Black Hills is offline   Reply With Quote
Old 04-02-2014, 02:38 PM   #3
Martyred
Martyred's Avatar
Oddometer: 112
I had the same problem between 50 to 80 km/h. All balancing and reajustment of the front tire didn't solve the problem. Than my dealer changed the tire for warrenty and now it is all perfect.
There were a couple of conti tires which had a manufacturing error. Probably you got one of those.
Martyred is online now   Reply With Quote
Old 04-02-2014, 06:23 PM   #4
scudrunner82
human whoopy cushion
scudrunner82's Avatar
Oddometer: 2,172
Check your front rim runout. I have a truing stand and mine was out enough to make the bars wiggle around 45-55 MPH. I thought it was the tire balance, but turned out to be the rim. Easy fix at least if you have a spoke wrench and some patience. So far its been the only issue with my 1190.
Hungry Tenere TripTeam Ghetto Does a Hot Lap of America
350, 450, 848, 900, 1190r
My Youtube channel----- https://www.youtube.com/channel/UCXo...kdER0Y5QfoE9gQ
scudrunner82 is offline   Reply With Quote
Old 04-03-2014, 01:19 AM   #5
TakSD OP
Oddometer: 55
Thanks for all the responses!
Blackhills, tyres pressure is 2.3 front and 2.6 rear. I always prefer to keep them a little low. Beauty of having TPMS :)
Have checked axle torque, bearing play and steering head... Will also check the swingarm.
Martyred, I changed the tyres when new to the Scorpion Trail that is practically a road tyre... I am sure a new tyre would fix it for now but I prefer not to mask the problem and have it happening again in 2,000 km...
Scudrunner, thanks for the info. I am hoping this is the problem and will have it checked today. When balancing the tyre there was some runout so fingers crossed :)
Old 04-03-2014, 07:41 AM   #6
Black Hills
Oddometer: 1,185
try p bumping tire pressures up to recommended and see what happens. My CBR would wobble when the front was 5psi low.
Old 04-03-2014, 11:03 AM   #7
PS-RagE
PS-RagE's Avatar
Oddometer: 616
Betcha the rim has a flat spot. Happens to me all the time.
A. Dale McLean
aka PS-RagE
2007 Beta REV3 270
2012 KTM 350 EXC-F
2014 KTM 1190 Adventure R
PS-RagE is offline   Reply With Quote
Old 04-03-2014, 01:58 PM   #8
TakSD OP
Oddometer: 55
Thankfully, PROBLEM SOLVED!
Played with geometry, rebalanced the wheels, realigned the rear wheel, checked every single spoke... the shake wouldnt go away...
Just when I was out of options we said to physically check the head bearing, even though there was no play when pushing/pulling the tyre, forks, handlebars etc...
Well it was loose, tightened it just a bit and now its like it's on rails again :)
weekend riding here i come!!!
Old 06-14-2014, 01:58 PM   #9
Pork Butt
Save the USA
Pork Butt's Avatar
Oddometer: 65,739
bumping this thread my new 1190 ADV not an R has a terrible wobble
it came with a bad controller for the signals and high beam (fixed already) but look what I found on the front tire.
six on each side
PB
I'm a piston farmer .....
Pork Butt is offline   Reply With Quote
Old 06-14-2014, 06:12 PM   #10
Two Tigers
Oddometer: 100
Steering head bearings! I had to have them tightened a few times my standard 1190 due to the same issue.
Two Tigers is offline   Reply With Quote
Old 06-14-2014, 07:06 PM   #11
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,485
six on each side
PB
It's the new steel ones that weigh less, since the good lead ones have been banned.
Old 06-15-2014, 12:13 AM   #12
DirtyOrange
Gnarly n00b
DirtyOrange's Avatar
Oddometer: 5
My 1190 standard has been to the dealer two times to address the head shake/ wobble. The first time the mechanic corrected front wheel balance and trued the front rim. It was better but did not eliminate it altogether. It gradually got worse and so I checked runout on both front and rear rims. Front was within spec., rear was out with two "low tone" spokes. Mechanic trued and balanced rear wheel but it didn't help much.
He acknowledged that the head shake remained but concluded that it was probably the tires. I was advised to see how things are when I change tires. It annoys me that the problem remains.
It's going in on tuesday for starter/battery cables and a leak down test (yes, dust in the air box and intake stacks). I'll have him check the steering head bearings.
DirtyOrange is offline   Reply With Quote
Old 06-15-2014, 06:23 AM   #13
irongrady
irongrady's Avatar
Oddometer: 241
Mine had a runout issue from the factory as well. 20 minutes on a truing stand turning some spokes and it's all better.
irongrady is offline   Reply With Quote
Old 06-24-2014, 07:54 PM   #14
Pork Butt
Save the USA
Pork Butt's Avatar
Oddometer: 65,739
Dealer called today .... the rim has a major flat spot and is being replaced.
I have never heard of this many rims and tires being fooked not very confidence building.
PB
Old 06-25-2014, 07:57 AM   #15
PS-RagE
PS-RagE's Avatar
Oddometer: 616
PB
They are replacing it? Under warranty?
A. Dale McLean
aka PS-RagE
2007 Beta REV3 270
2012 KTM 350 EXC-F
Times are GMT -7.   It's 11:32 PM.
