Old 11-18-2013, 02:56 PM   #106
USAIR
picking and riding
USAIR's Avatar
Oddometer: 1,622
I need a little help please.
Bike ---- WR250R 2013
Handle Bars ----- Pro Taper EVO YZ high
Ordering online trying to figure out what I need.
Here's what I have so far.
I think I'm correct on my selections...just not sure on lower clamp.
Red is my selection
Choose Your Top Clamp Bolt Pattern*
100 x 38/40mm
Upgrade Your Top Clamp
ADVdx Top Clamp, Fat Bars Only Add $25
Choose Your Shield Color*
Black
Add Lower Clamps
12mm Bolt Lower Clamp Medium 2 1/8" Add $38 ------------------EDIT -----After getting a call from HDB they straighten me out and ordered whats in red (Here's where I have trouble---not sure which I need???)
Add Black Anodize
Add Black Anodize,Set W/Guards Add $25
Two Mirrors Add $50
----EDIT-----
This is what I ordered above for the 2013 WR I'll let you guys know how everything worked out.
Fred
2013 WR250R 2007 Wee
www.riverbendphotos.com
YouTube feed
Wallpaper for Montana GPSr
Beware of the Wallnut
USAIR screwed with this post 11-19-2013 at 05:56 AM
USAIR is offline   Reply With Quote
Old 11-18-2013, 03:14 PM   #107
crjdirt
crjdirt's Avatar
Oddometer: 104
lower clamp
You're going to love this set up.
copied and pasted this from an email from HDB when I purchased for my 2011 wr250r
the top clamp goes to 100x38/40mm w/fat bars and the lowers will be with a 12mm through bolt.
Hope this helps
crjdirt is offline   Reply With Quote
Old 11-18-2013, 03:58 PM   #108
USAIR
picking and riding
USAIR's Avatar
Oddometer: 1,622
Hope this helps
Thank you that answered my question.
Now just hope cables are long enough with the high bars.
The lowers I ordered are 2 1/8.
Fred
YouTube feed
Old 11-19-2013, 02:22 PM   #109
Shooby
Anti-Cager
Shooby's Avatar
Oddometer: 1,008
Hi Paul,
Thanks for the prompt service. FYI - the "ADV" top clamp does not work on a '13 F800GS. Due to it's size, when turning, the lower corners encroach in the space of the ignition key guard. I imagine it would only take a few lock to lock turns before the key guard would fail.
After loosely mounting it on the bar clamps, I held the guards to their mount points while turning and they'll hit the stock screen 1"-2" before hitting the steering stops.
Also, are these intended to use the stock bar-end weights? (no instructions provided, not that it's needed but would help to clarify)
I really want to use these without hacking off screens and key guards.. Please advise.
Paul S.
Shooby is offline   Reply With Quote
Old 11-19-2013, 02:43 PM   #110
VxZeroKnots
VxZeroKnots's Avatar
Oddometer: 2,871
Originally Posted by Shooby View Post
Hi Paul,
Paul S.
Can you adjust your steering stops to keep the gaurds from contacting the screen?
Also, since the hand guards tap into the end of the bar I'm going to guess it's a no go on keeping the bar end weights.
I say we take off and nuke the entire site from orbit. It's the only way to be sure
No bike does everything perfectly. In fact, no bike does anything until someone gets on it to ride.
VxZeroKnots is online now   Reply With Quote
Old 11-19-2013, 03:09 PM   #111
BanhXeo
BanhXeo's Avatar
Oddometer: 334
Hi Paul,
Paul S.
If you can Paul can you post up a pic of the screen clearance. I added Rox 2" risers to my '13 800 gs and don't think I will have clearance issues with stock key placement. However I did not think about screen clearance and am waiting a response from HDB on the stock bar weights. They did have a "Kit" listed on there website under top clamp bolt pattern for F800/650 GS not sure or not if you chose that option as its 30 bucks and I didn't see any notes regarding it.
2013 KTM EXC-F SOLD
2013 BMW F8 GS FOR SALE
SmugMug: http://ktmrider.smugmug.com/
This is my WIFE, here are my BIKES, and these are my STORIES: http://www.advrider.com/forums/showthread.php?t=897188
BanhXeo is offline   Reply With Quote
Old 11-19-2013, 03:18 PM   #112
Shooby
Anti-Cager
Shooby's Avatar
Oddometer: 1,008
HDB’s Ultimate Handguards and 10% discount
Originally Posted by VxZeroKnots View Post
Can you adjust your steering stops to keep the gaurds from contacting the screen?.
Negative, they're cast tabs on the neck & fork brace.
I've read others had the same issue with stock and aftermarket, but they were pre '13, so I was hoping against hope.
This pic is off HDB site gallery. Earlier model. Appears these weights were a custom cut. Paul, do you supply these or do I cut my stockers ?
Shooby screwed with this post 11-19-2013 at 04:33 PM
Old 11-19-2013, 03:23 PM   #113
Shooby
Anti-Cager
Shooby's Avatar
Oddometer: 1,008
I'll mock it up again tonight for pics.
"Kit" - didn't see it and should have asked more questions over the phone.
Agreed, with risers it shouldn't have clearance issues to the key guard. I'll get pics of that as well.
Old 11-19-2013, 03:39 PM   #114
BanhXeo
BanhXeo's Avatar
Oddometer: 334
This pic is off HDB site gallery. Earlier model. Appears these weights were a custom cut. Paul, do you supply these or do I cut my stockers?
Just got an email reply. They supply bar ends.
2013 KTM EXC-F SOLD
Old 11-19-2013, 03:43 PM   #115
Shooby
Anti-Cager
Shooby's Avatar
Oddometer: 1,008
Emailing now...
Old 11-19-2013, 05:26 PM   #116
Shooby
Anti-Cager
Shooby's Avatar
Oddometer: 1,008
Top clamp not as extreme as first mock up, It touches, but just. The key guard flexes slightly so a little sanding and it will clear.
I turned the bars aft a bit ( which is more comfortable for me anyway) and the bars clear the screen by 1/4".
Initially, I believe I had the top clamp tilted forward which turned the bars downward and into the wider part of the screen.
In short, before you post up,
"measure twice, cut once"
Now, how long before I scrub off the anodized black? :-)
Shooby screwed with this post 11-19-2013 at 05:32 PM
Old 11-23-2013, 08:32 AM   #117
Droptarotter
Oddometer: 1,285
Hey Paul;
Thanks for getting my nice shiny orange handguards to me so quickly!
Cheers!
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat
Droptarotter is offline   Reply With Quote
Old 11-23-2013, 10:03 AM   #118
empedrado
Oddometer: 370
Nice fit and finish
Just finished installing the handguards on my 500EXC, everthing went smoothly and I am very happy with my decision to go with this set up. My only regret is that I wish I had gone with the black handguard shields vs the orange. I mounted some small led lights in the shields and the amber on orange is not nearly as visable as amber on black would have been. Unfortunately the freight to purchase a set of black shields now is almost as much as the replacement handguards. Need to keep thinking about what else I might need.
empedrado is online now   Reply With Quote
Old 11-24-2013, 12:45 PM   #119
Shooby
Anti-Cager
Shooby's Avatar
Oddometer: 1,008
Thanks Paul, appreciate your prompt attention and quality hardware.
Old 04-07-2014, 05:27 PM   #120
tedmarshall
tedmarshall's Avatar
Oddometer: 553
KTM 1190 R Adv
Paul: email sent. Need a set with mirrors for my new ride.
Ted
tedmarshall is offline   Reply With Quote
Times are GMT -7.   It's 05:56 AM.
