Old 04-06-2014, 01:24 AM   #13981
Itchi
Oddometer: 7
missing oil?
Originally Posted by rvt View Post
Good choice Itchi!
Now you need to bling it up, so you can tell it apart from the rest of ours.
See you on a Perth ride sometime.
Bling it up? other than some colour i am not sure what i'd do that hasnt already been done. lifted straight from the add:
"Fully kitted out Suzuki DR650 SE ready for any adventure. This bike is ready to go anywhere.
18L adventure fuel tank.
*Procycles jetting kit (dyno tuned at 39hp)
*RaceTech cartridge emulators +7.0 springs plus seals and oil.
*Procycles gold valve rear shock kit upgrade with 8.3 spring and oil
*B&B bash plate
*30mm handlebar risers plus oversize handlebars
*bark bustera with custom mounts
*lowered foot mounts with pivot foot pegs
*vapour digital odo with custom mount and custom mount for GPS
*heavy duty O-ring chain EK 525-120
*sprockets f 14T, r 42T
*High flow K&N filter and high flow oil filter.
*side racks to carry 2 Wolfman teton bags included
*rear tube/tool storage
*perspex headlight guard
*windshiels
I was thinking some tank decals. I want to call it Lion-hog. I have never really been into naming my vehicles but keen i think this is pretty appropriate.
Anyway i just put it through a service (mechanic wrecked my new helmet because i 'shouldn't have left it locked on the back' in the helmet lock apparently) and having it returned i notice that the oil reservoir window still doesn't show me enough oil when the bike is standing. I checked as soon as i left the garage. should i be at all concerned about this?
i'm in Sydney by the way.
Itchi is offline   Reply With Quote
Old 04-06-2014, 01:33 AM   #13982
BergDonk
BergDonk's Avatar
Oddometer: 3,825
0.7 fork springs
The oil should be as per the manual, preferably up near the upper line. There is a procedure in the manual for checking the oil, OTTMOH check 2 mins after shutting down. I found that it doesn't change, so cold level check is fine and what I do.
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 04-06-2014, 04:23 AM   #13983
Goosefeather
Captain Slow
Goosefeather's Avatar
Oddometer: 877
Manual says three minutes, but key thing is held vertical, not on the stand.
Goosefeather is offline   Reply With Quote
Old 04-07-2014, 12:34 AM   #13984
Itchi
Oddometer: 7
I know. it has the same glass view window as the spada. i have tried with a level and a block of wood and its pretty low despite having just come out of the mechanics.
The bike is from randwick, not coogee. Shes beautiful. i was pretty pleased no one had snapped her up before i got to her.
Old 04-07-2014, 02:22 PM   #13985
Benz-in-Oz
Benz-in-Oz's Avatar
Oddometer: 202
Top it up and change mechanics or better still do your own work.
Graeme
The journey is the reward.
Benz-in-Oz is offline   Reply With Quote
Old 04-09-2014, 03:27 AM   #13986
J_B
Mid-life Crisis
J_B's Avatar
Oddometer: 387
dr 650 tank Required
anyone got a 20 L safari or Acerbis tank in white or Translucent sitting around that they would k=like to part with.
Can pick up in Perth or Sydney or pay postage
Cheers
JB
The Older I Get The Better I Was!
[B]625SXC
Yamaha DT360 vintage mx
Xr650r
KX450F Yamaha AG100
J_B is offline   Reply With Quote
Old 04-09-2014, 03:53 AM   #13987
Killa Meter
Oddometer: 272
Talking
Hey Itchi get hold of an owners manual and read it .Get rid of the K &N filter if your going to ride dirt.Buy a stock air filter or a uni , their cheap enough .Keep an eye on that chain for stretching , read the manual for proper adjustment. HAVE FUN!
" Now i know why you like it , and it's completely dangerous! " ...my 8 year old after his first ride on my GS 1200
Killa Meter is offline   Reply With Quote
Old 04-10-2014, 12:57 AM   #13988
Thumper Dan
Oddometer: 328
I've read you can 'hair nets' to put over stock filter which and then toss out when dusty/dirty and throw on a new one.
Currently riding DR650 (2011)
Mods: Manrack, ebay 48 litre top box, grind header pipe; B&B bash plate; bigger/better tool compartment (pvc pipe) - Screens For Bikes Windscreen, TM40 Pumper Carb, Safari Tank, Seat Concepts, Oxford Heater Grips, Highway Pegs, Wolfman Expidition bags and racks, HDB handguards, Cogent Mojave rear shock, intiminators, GSX muffler/mod
Thumper Dan is offline   Reply With Quote
Old 04-10-2014, 01:40 AM   #13989
B1
Carbon-based bipedal
B1's Avatar
Oddometer: 3,431
swimming pool filter covers work well too.
B1 is offline   Reply With Quote
Old 04-10-2014, 02:48 AM   #13990
kezzajohnson
kezza
kezzajohnson's Avatar
Oddometer: 1,666
filter skin
Chux cloths work well too. Roll a few up in your tool bag. They just stick to a well oiled filter and peel off as required, stick on a new one.
KezzaJohnson Blue 06 DR650se,Yellow 06 DRZ250
Website: http://www.territoryon2wheels.com
"May the Road Never Rise to Defeat you..."
kezzajohnson is offline   Reply With Quote
Old 04-10-2014, 09:24 AM   #13991
motolab
motolab's Avatar
Oddometer: 2,777
I don't recommend the DynoJet needle that comes in the PC kit because:
1) It's a shape that is likely to produce significant variances in mixture strength throughout the rpm range (richer toward the bottom relative to the top).
2) It's made out of stainless steel which means more emulsion tube wear than with an aluminum needle.
3) It doesn't use the white plastic spacer under the clip, which means the needle is not preloaded in the downstream direction, and will therefore be more prone to orbiting/otherwise gyrating inside the emulsion tube. It also means that the needle will not be able to pivot out of the way as the slide guide wears. Both of these factors equate more emulsion tube wear.
Has the slide been drilled?
As others have noted, the K&N is not likely to filter adequately off road. The standard under-diaphragm vent filter is also inadequate and will contribute to accelerated slide guide, silde, emulsion tube and jet needle wear when the bike is ridden in dusty conditions. I recommend replacing the standard under-diaphragm vent filter with an oiled Uni UP-123.
Regards,
Derek
motolab is offline   Reply With Quote
Old 04-10-2014, 04:46 PM   #13992
dobbo
dobbo's Avatar
Oddometer: 1,007
Hi,
I thought I'd post this here, rather than the DR thread in the 'Thumper' section, where it would get lost in the pages rather quickly.
My 2008 DR650 (50,000 kilometres on the clock) has developed quite a rattle within the engine somewhere, which increases with an increase in revs (same if bike is warm or cold).
I never really noticed it, until a recent trip, where I had a couple of other DR650 riders comment about the rattle/noise in my bike's engine.
Bike has a High Compression piston fitted (From Procycles.us), which I did have trouble fitting the new cudgen pin, which took a little gentle persuasion to get it fitted.
The piston has been in the bike for about 20,000 kilometres now. (so I don't think this is the problem); although, I have notice it to be a little more 'rattley' since the piston went in, back then.
I always run a 10W-40 engine oil and 98 octane fuel.
Valve clearances are okay and within spec.
I remove the 'Bash-plate' to see if it was just the engine noise resonating from it; however, the rattle is still there.
NSU screws have been loctited in place.
Did anyone here, with a HC piston fitted notice an increase in engine noise...ie rattle ???
Can anyone give me a few suggestions on where to start looking, before dismantling the engine.
Any help would be appreciated,
thanks
Dobbo
dobbo is offline   Reply With Quote
Old 04-10-2014, 04:48 PM   #13993
BergDonk
BergDonk's Avatar
Oddometer: 3,825
Cam chain , cam chain guide, tensioner?
Old 04-10-2014, 05:38 PM   #13994
grrant1058
Motorcyclist 24/7
grrant1058's Avatar
Oddometer: 345
Hi Dobbo,
On my 3rd DR and they have all been very quiet mechanically - until I fitted a High Compression piston. Clearance and everything is correct (fitted at 5,000 km's) but surprised how rattly it is. Noticeably more power and no oil consumption problems. Apparently not uncommon when fitting a forged piston.
Found the best solution is always wear my earplugs, otherwise I started seeing dollar signs!
Cheers - Ron
Originally Posted by dobbo View Post
Hi,
thanks
Dobbo
grrant1058 is offline   Reply With Quote
Old 04-10-2014, 05:40 PM   #13995
dobbo
dobbo's Avatar
Oddometer: 1,007
Thanks Donks,
that where I am heading...
Cam chain or the Cudgen pin.
Either way, head is coming off when I get time.
cheers
Dobbo
Times are GMT -7.   It's 02:36 AM.
