Old 05-02-2014, 08:32 AM   #2746
pdxthmper
pdxthmper's Avatar
Oddometer: 408
THanks for the details. Of course it didn't do it on the way home last night, maybe it just doesn't like going to work?
Originally Posted by Loui€ View Post
most probably it is TPS.
hook on tuneecu, and adjust it to .60 V warm engine.
if it is less - e.g. less than .56V warm you get that behavior, for sure.
I had .46 warm, and 4500 - 5000 RPM idle, veeery nice in town...
removing air box:
if you have original airbox and torx screw to fix TPS - well well...
read earlier posts about that;
I have hexagon screw and ITG foam filter (I warmly recommend it, it is just fantastic!); so plenty of room to adjust TPS.
btw, basic EU 2008 Akramap (O2 on, SAI off, EPC off) for this setup:
2*Leo Vinces with baffles + ITG foam filter.
Perfect driving experience, power from 2500 RPM, torques 6 gear in 3000 RPM cruisin', MPG 47 best, 44 aver. !!! I'm happy to have this great beast to carry me to horizon!
KTM 990 ADV MAKING GROWN MEN ACT LIKE HOOLIGANS
XR 650"L"
pdxthmper is offline   Reply With Quote
Old 05-02-2014, 09:50 AM   #2747
bluesurf
en dos ruedas
bluesurf's Avatar
Oddometer: 1,012
Originally Posted by Gustavo.Ramos View Post
Load back the previous map and crosscheck if that idel issue remains. If it does, could be related to TPS... "could be"
Yep, that's now today's plan. Thanks
Ride Travel Explore Live
bluesurf is offline   Reply With Quote
Old 05-02-2014, 09:51 AM   #2748
bluesurf
en dos ruedas
bluesurf's Avatar
Oddometer: 1,012
removing air box:
Thanks for these details
Old 05-02-2014, 12:29 PM   #2749
bluesurf
en dos ruedas
bluesurf's Avatar
Oddometer: 1,012
I took a ride to run some errands and ensure that the bike was warmed up prior to reloading the previous map. At only one out of the dozen or so stops did the bike idle at ~1900RPM; the rest of the time was ~1400RPM.
I'll review some of the obviously very helpful information regarding TPS issues, but right now am just going to leave things as they are.
Old 05-05-2014, 09:18 AM   #2750
AJ990R
motorcycle guy
AJ990R's Avatar
Oddometer: 229
02 sensors shut-off with CPR map
new with the tune ecu thing & taking a big trip this weekend...
Shut the sensors off, is this ok? others doing it? even worth it?
trying to make her run as smooth as possible...
maybe even a little cooler
I know twins are thirsty bitches!
thanks guys
AJ
"saddle up or shut up"
KaTooM North
AJ990R is online now   Reply With Quote
Old 05-06-2014, 01:02 PM   #2751
Loui€
Rides With Reindeer
Loui€'s Avatar
Oddometer: 49
O2 off? why? really, I see no advantage in that?
my experience: with Akramap, O2 off takes 7-8 L /100kms, O2 on 5,4 L /100kms.
2008 KTM 990 ADV
Loui€ is offline   Reply With Quote
Old 05-06-2014, 01:57 PM   #2752
AJ990R
motorcycle guy
AJ990R's Avatar
Oddometer: 229
like i said before.
smoother running at lower rpms(around the city)
local superduke guys swears his runs better with them off.
common practice on ducati twins.
been running it with them off, it is smooth.
Gonna start monitoring fuel mileage.
KaTooM North
AJ990R screwed with this post 05-06-2014 at 02:04 PM
Old 05-06-2014, 04:51 PM   #2753
Dusty
Dusty's Avatar
Oddometer: 1,300
Originally Posted by AJ990R View Post
like i said before.
That right there is why people turn them off. If its muddy or your plonkin around shit in 1st and 2nd it has much better throttle control. It even gets better without the secondary flies.
edit;the second flies produce alot of engine braking also which i dont care for off road.
Good on ya for givin it a go, make your own conclusions.
Originally Posted by d0gWateR
Vagrant, vagabond, transient, hobo, bum. But park a motorcycle next to him and PRESTO! He's an advrider!
Dusty screwed with this post 05-06-2014 at 04:58 PM
Dusty is offline   Reply With Quote
Old 05-06-2014, 07:53 PM   #2754
Junglerot
Hodor!
Junglerot's Avatar
Oddometer: 3,436
Sorry if this has been answered, but Ive been searching and I can't seem to find an answer. I am unable to disable any of the "Devices" in TuneECU, including the SAI. Am I missing something? I have even downloaded other maps from the TuneECU site and haven't been able to uncheck the boxes
edit: apparently I figured it out. I had to click it precisely 3 times to uncheck the box....
What's the worst that could happen?
Junglerot screwed with this post 05-06-2014 at 08:01 PM
Junglerot is offline   Reply With Quote
Old 05-07-2014, 11:17 AM   #2755
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 935
Had the same issue, not 3 clicks, but 1 to select the item, and double click to activate/deactivate!
690R
Old 05-17-2014, 05:17 PM   #2756
The Gobbler
The Gobbler's Avatar
Oddometer: 194
High Altitude
Question for all you folks.
I had to remove my O2 sensor (it burned a hole in my tank and don't want that to happen again). Now the question, I live and ride above 8000 feet, do I need to create a custom map for altitude?
Thanks in advance.
You don't even want to know what the Gobbler is...
Current bike:
2007 KTM 990 Adventure
Past bikes:
2 97 VFR's,
2001 ZX9R,
2004 ZX10 and 3 (yes 3) 2006 ZX10's
2005 Vee
The Gobbler is offline   Reply With Quote
Old 05-17-2014, 05:58 PM   #2757
DirtJack
DirtJack's Avatar
Oddometer: 1,598
Never heard of that before. Running with O2 sensors off (if that is what you're doing) does not mean that A/F ratio is not altitude sensitive. It means that loopback mode of ECU operation (when applicable) will not be possible.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 05-17-2014, 06:28 PM   #2758
renogeorge
Oddometer: 1,395
I'm no expert. A lot of guys seem to be running without O2 sensors as a performance modification in conjunction with mapping changes. I haven't tried it but most seem to say that it hurts mileage. The system has ambient air temp and MAP sensors--1 in each intake manifold and 1 in the atmosphere under the headlight. So I would guess that the ECU would be getting the info indicative of your altitude and temps. I don't know if not having the AFR/Lambda info from the O2 sensors eliminates the ECU making the adjustments. Try it and see, I guess.
FWIW
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 05-20-2014, 01:54 PM   #2759
DirtJack
DirtJack's Avatar
Oddometer: 1,598
Loop back operation (with Kehin ECU's) occurs primarily in low throttle/cruise situations. Having O2 sensors on would tend to have a noticeable effect on mileage if there is a preponderance of that kind of throttle use during a ride. Less otherwise.
FWIW
2008 KTM 690 Enduro
Old 05-21-2014, 11:14 PM   #2760
1coolbanana
1coolbanana's Avatar
Oddometer: 1,446
Hey guys
Ive got a 2012 990 R in Australia, I believe its the same ECU and mapping as EU version.
My setup is:
Stock air box,
Akra slip ons
Unifilter Pre Filter
SAS removed
Secondary flies removed
Im using the Akra map, O2 on, EPC on, SAI off, 2nd Throttle off
Would the Power Tripp map be compatible and worth a try or is it only suitable for US models?
Cheers
Cowabunga dudes................Wuuuuka Wuka
2012 990 R
2004 950 A..........sadly missed
1coolbanana is offline   Reply With Quote
Times are GMT -7.   It's 07:39 AM.
