Old 01-09-2008, 02:07 PM   #1
Zombiedog OP
KTM enabled
Oddometer: 82
How high handlebar risers with stock cables?
Does anyone know how high I can go with handlebar risers without having to change to longer cables? I'm looking at the Rox Speed fx risers for my 950 Adventure. They add about 2".
Thanks, Mike
"I believe we are on an irreversible trend toward more freedom and democracy but that could change."
Dubya
Zombiedog is offline   Reply With Quote
Old 01-09-2008, 02:15 PM   #2
Rabid Dog
Rabid Dog's Avatar
Oddometer: 354
I got a 990 and that would be stretch.
Way around it is to reroute the 90 degree elbow at the hand grip so cables exit below the bars (basically by rotating throttle assembly 180 degrees per Roughidle, below).
Rabid
2007 KTM 990 Adventure (Black)
Rabid Dog screwed with this post 01-09-2008 at 07:50 PM
Rabid Dog is offline   Reply With Quote
Old 01-09-2008, 02:16 PM   #3
Roughidle
Super Star Destroyer....
Roughidle's Avatar
Oddometer: 1,494
Thanks, Mike
I have the Rox Risers on my 950 they add 2.25" with no porblems.
Beware though, dont just bolt them on, make sure you dig around under your headlight for more wire slack.
Flipping your throttle over 180deg. is a must aswell. no big deal to do.
I origionally had the TT risers on my bike and I was stupid enough to not re-arange the wires, eventually my Kill switch wires rubbed through on the steering lock lug and it started blowing fuses/ shutting the bike down when I turned right.
The Rox risers are better to start with becasue you can position them forward to reduce wire stress, but if you take care in regards to wire slack you will be fine, i've had mine since august and LOVE them.
Burninating the peasants.
Roughidle is offline   Reply With Quote
Old 01-09-2008, 02:43 PM   #4
Bearhugger
Bearhugger's Avatar
Oddometer: 96
Good info. I love riding standing up and the stock hight is just a bit too short.
Is it supposed to look like that?
Bearhugger is offline   Reply With Quote
Old 01-09-2008, 08:06 PM   #5
DakarNick
Swabee
DakarNick's Avatar
Oddometer: 6,973
950 or 990? I have a 950 and have the Rox. I didn't search for slack, I had enough, but I did do the reverse throttle housing mod.
They were tall at first but I am used to them now and standing up is lots better!
Nick
'06 KTM 950S Adventure
'12 Ram 2500, Cummins, 6-speed auto, Laramie Longhorn, RamBox.
DakarNick is online now   Reply With Quote
Old 07-28-2008, 09:42 PM   #6
viola-tor
Needs to ride!
viola-tor's Avatar
Oddometer: 2,071
So are 2" risers not an option with the stock cables on a 990? That's the direction I'd like to go, but it doesn't look like a lot of play on either side. The cost of new cables may be a deterent... Can anyone who has 2" risers on a 990 comment?
viola-tor is offline   Reply With Quote
Old 07-29-2008, 07:04 AM   #7
BajaBufeo
Oddometer: 24
I put the Scotts dampner/triple clamp combo along with the Touratech bar risers - approx 2" total rise on my 990. Like previous posts said, you need to rotate the throttle assembly 180 degrees so the cables are at the bottom. No need to do anything with the clutch cable. All wires seem to have enough play.
If it doesn't have handlebars, a steering wheel, a black diamond, or boobs, I'm not interested
BajaBufeo is offline   Reply With Quote
Old 07-29-2008, 08:11 AM   #8
woodchuckexc
Oddometer: 801
I also have Scotts triple clamp with added tour tech risers. Everything fits fine. I did not need to rotate the throttle cables like some others have said. My freind with rox risers on top of his Scotts triple clamp did rotate throttle cables under the bar but everything else fit fine.
woodchuckexc is offline   Reply With Quote
Old 07-29-2008, 09:43 AM   #9
viola-tor
Needs to ride!
viola-tor's Avatar
Oddometer: 2,071
cool! I think 2" will be perfect for me, I'm gonna get the ROX risers and can hopefully make 'em fit.
Old 07-29-2008, 10:08 AM   #10
skritikos
skritikos's Avatar
Oddometer: 122
990 (not S), Rox risers 2+", no problems at all. I just had to reverse the throttle and cut some zip-ties in the frame area behind the front light assembly. It is a 15min job.
KTM Adv: Brings out the wild child!
skritikos is offline   Reply With Quote
Old 05-21-2014, 08:22 AM   #11
Tyserie
Oddometer: 16
Hi, is there some kit for handlebars raisers over 5cm? I mean, I have SW-Motech handlebar raisers and I am not able to fully turn right, because of throttle wires and front brake hose.
Tyserie is offline   Reply With Quote
Old 05-21-2014, 08:56 AM   #12
ABuck99
0.0
ABuck99's Avatar
Oddometer: 627
Thanks, Mike
The 1.75" ROX Riser is intended/suited for the 950/990
KTM: 06 KTM950S & 10 KTM450EXC
ABuck99 is offline   Reply With Quote
Times are GMT -7.   It's 12:29 AM.
