Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 05-21-2014, 11:33 AM   #76
RobZorba OP
RobZorba
RobZorba's Avatar
Oddometer: 432
Originally Posted by SCflyer View Post
Thanks but you think there's potential for the wiring/computer to start having problems with that extra heat blanket? I don't care for the heat either or any "two" things getting toasty but also don't want the wires to melt or computer to fry.
The wiring and ECU are fine up to 100 C / 212 F, and the heat convected to that area only gets to around 60 C / 140 F. Can't give any assurances about the injection moulded airbox and lid seal at those temperatures, unless the Unifilter kit "lid seal" has been fitted to accommodate the distortion in the plastics.
KTM 1290 SA, KTM 1190R, Suzuki VStrom 650 ABS, Honda ST1300, Suzuki SV650, Yamaha RD250
RobZorba is offline   Reply With Quote
Old 05-21-2014, 05:34 PM   #77
Corsica101
Corsica101's Avatar
Oddometer: 426
Originally Posted by Bluesilver View Post
If the Cooler plate is as good as their pipe and heel plate which is PIG strong then I'll be placing an order!! Dumped my bike and the heel plate took ALL the rear impact at the rear, ZERO damage to the bike, exhaust only minor scratches to the CF heel plate and that was two people up and a topbox.
mmm couldn't say the same unfortunately:)
Corsica101 is offline   Reply With Quote
Old 05-22-2014, 09:51 AM   #78
straightline
Oddometer: 45
Another benefit of the seat coolers is that it seems to quiet some of the engine noise. Here is a picture of of the matt coolers
straightline is offline   Reply With Quote
Old 05-22-2014, 11:02 AM   #79
veesquared
Oddometer: 126
I like the matt finish.
Thanks for the picture. I like the way the matt looks like a factory part . Ordered a set yesterday.
KTM 1190 KTM 690 E KTM 200 Exc
veesquared is offline   Reply With Quote
Old 05-22-2014, 11:50 AM   #80
straightline
Oddometer: 45
The matt really matches the seat well. I did not put on the heat blanket since my seat already had the updated insulation. Quality pieces-well worth the money
Old 05-22-2014, 12:03 PM   #81
RobZorba OP
RobZorba
RobZorba's Avatar
Oddometer: 432
Although initially I fitted the heat blanket, I've now taken it off. The heat blanket causes quite a lot of "extra" heat to rise up in front of the passenger, between the front and rear seats, compared with not fitting the heat blanket. And I quite like the rider's seat being a little warmer.
With the heat shields, there is no noticeable heat hitting the riders legs, but there is "extra" hot air directed onto the passenger's lower legs compared with not having the heat shields.
I measured the contact temperature of the carbon heat shields after a long run today. The left hand shield was 75 C / 175 F, the right hand shield was 60 C / 140 F. Without the heat shields this would be the air temperature hitting the rider's legs.
Old 05-22-2014, 12:22 PM   #82
straightline
Oddometer: 45
I may cut up the heat blanket and use it on the inside of the shields
Old 05-22-2014, 12:34 PM   #83
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,983
Keeping the heat in Vs. letting it escape....time will tell ...
I am dropping my header off for ceramic coating today...will lower the A/F a tad next....Cooler running temps....
'14 1190R...Adventure Beast
'13 690 Quest...Rally Beast
'15 Husqvarna 501...Trail Beast
950SE......Desert Beast
Nowwhat is online now   Reply With Quote
Old 05-22-2014, 12:43 PM   #84
straightline
Oddometer: 45
The heat still comes out it just does it behind the riders legs. I never ride with a passenger but those who do may not like the shields.
Old 05-22-2014, 01:44 PM   #85
RobZorba OP
RobZorba
RobZorba's Avatar
Oddometer: 432
Don't think it's necessary ... CF withstands very high temperatures (used in Gas Turbine impellers) and doesn't radiate the heat much! But if you like to lovingly caress your new heat shields and not get your fingers "warm", it'll help with that :-)
Old 05-22-2014, 01:55 PM   #86
RobZorba OP
RobZorba
RobZorba's Avatar
Oddometer: 432
Yep, that was my conclusion as well. My passenger(s) feel increased heat on lower legs, but because it's low down and they wear riding boots, it's far less a problem for them to have the heat than for me having it directed at my inner thighs where it's quite sensitive
Taking the heat shield blanket off re-distributes the heat in quite a good way. My thighs are still "protected", my bum gets warmed comfortably through the seat, and there is less "hot air" directed at the passenger's lower legs.
From the "spy pictures" of the 2015 1190 Adv tourer, it seems KTM are introducing a heat shield lagging for the rear cylinder exhaust downpipe.
Old 05-22-2014, 07:00 PM   #87
Kevy511
Oddometer: 27
I ordered and paid for for my can and heat shield on the 19th. Did not get a shipping notice right away like some others here did and thought that it would not arrive in time for my long weekend of riding. Received tracking info today and it looks like I get tomorrow. I'm not sure about this but I think that because they did not ship right away that they did and overnight ship (Slovenia/ U.S. Customs/ New Jersey= $$) to make up the time. I would say that's a good lookout for the customer.
Scheduled Delivery:
Friday, 05/23/2014, By End of Day
Last Location:
Departed - Koeln, Germany, Friday, 05/23/2014
Additional Information
Multiple Packages:
2
Shipped/Billed On:
05/22/2014
Type:
Package
Weight:
2.50 kgs
Shipment Progress
What's This?
Location Date Local Time Activity
Koeln, Germany 05/23/2014 2:58 A.M. Departure Scan
Koeln, Germany 05/22/2014 11:29 P.M. Arrival Scan
Brnik, Slovenia 05/22/2014 9:37 P.M. Departure Scan
05/22/2014 7:43 P.M. Export Scan
05/22/2014 7:43 P.M. Origin Scan
05/22/2014 2:09 P.M. Pickup Scan
Slovenia 05/22/2014 3:56 A.M. Order Processed: Ready for UPS
Kevy511 is offline   Reply With Quote
Old 05-22-2014, 08:01 PM   #88
straightline
Oddometer: 45
Mine shipped Friday 5/16 and it arrived in SoCal on Monday 5/19...amazing
Old 05-23-2014, 04:17 PM   #89
SCflyer
SCflyer's Avatar
Oddometer: 1,638
FYI - I had my pipes coated as well. No change other than more general protection now and a better matching color.
What are referring to when you say "lower the A/F?"
"Not all those who wander are lost" J.R.R. Tolkien
SCflyer is offline   Reply With Quote
Old 05-23-2014, 05:26 PM   #90
veesquared
Oddometer: 126
Question BMW RA at Barber
Got a notification mine were shipped. Should have them for my ride down to Barber motorsports and the RA rally. Anyone here going to this event ?
Times are GMT -7.   It's 12:28 PM.
