Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 05-28-2014, 11:30 AM   #46
USPSATrevor
Oddometer: 35
I got my skid plate installed last weekend in about 2.5 lazy hours. It fit perfectly, and I'm very happy - great product. I bought a competitor's plate previously but didn't even bother to install it. The design just didn't make any sense. I can see the experience and real world priorities that have gone into the BDCW plate, and it was worth every penny.
Thanks, Kurt for getting it to me in time for the trip!
I haven't noticed any higher oil temps. Mine usually runs about 175 with or without the plate.
USPSATrevor screwed with this post 05-28-2014 at 12:48 PM
USPSATrevor is offline   Reply With Quote
Old 05-28-2014, 11:36 AM   #47
WickedKTM
Lost
Oddometer: 129
1190 black dog skid plate
Good to hear on your temps. I tested mine and its definitely less without the skid on. It runs about 15-30 degrees hotter when moving with it on and 35+ degrees hotter in slower traffic with it on for me. Confirmed this by removing and running the bike with no skid.
It will be interesting to hear other folks input.
WickedKTM screwed with this post 05-29-2014 at 03:31 PM Reason: edit
WickedKTM is offline   Reply With Quote
Old 05-29-2014, 02:46 PM   #48
Omaha Tenere
Oddometer: 22
My BDCW Skid plate is ordered....Kurt said shipping soon (second run)!
--Rob
--No matter where you go, there you are!
Omaha Tenere is offline   Reply With Quote
Old 06-02-2014, 02:42 PM   #49
KTMforget
KTMforget's Avatar
Oddometer: 856
Originally Posted by Nowwhat View Post
K...
Do you know the distance from the mounting holes on the cases to your bracket?...I don't run the ractory bars anymore...and will nee a spacer from the motor's case to your upper bracket....
Hi Mike
Sorry - have been off the grid for a while. Are you using the tank protectors from the Standard model or running naked? That will make a difference. Let me know. Thanks
Kurt
Kurt - Black Dog Cycle Works
Check out our new website: BLACK DOG CYCLE WORKS
We specialize in the best parts for BMW and KTM Adventure bikes. WE TEST WHAT WE SELL!! Not just MADE in the U.S.A., made BETTER!
KTMforget is offline   Reply With Quote
Old 06-02-2014, 02:53 PM   #50
KTMforget
KTMforget's Avatar
Oddometer: 856
Originally Posted by WickedKTM View Post
I have the black dog skid plate and installed this weekend. I noticed today my oil temp ran about 10-25 degrees warmer than normal. After getting home and looking the bike over it occurred to me that while this plate is very beefy and good coverage it does block all air flow and seems to concentrate the radiant heat from the exhaust, block, etc. has anyone else noticed this?
I will run the bike tomorrow on the same run in the same ambient temp and see if the temps go down.
For Kurt @ black dog. Any reason for no air holes on the front side to allow some air to pass though like other skid plate designs? Unless there was a good reason not too, I may take a drill a Swiss cheese the front a little if my test proves that temps go down without the skid on.
Hi WickedKTM - We have not experienced any heating issue with our testing in Baja nor has come of our customers that have run Death Valley at 106 degrees, nor have we felt any extra heat radiating off the bike.
Adding any "armor" to the bike will cut down on airflow but we feel the protection is worth the trade off. In our experience, holes in the skid plate do an excellent job of letting sticks, rocks, mud and other debris INTO the skid plate, and not such a good job letting them OUT, all while decreasing the strength and integrity of the skid plate. Given the bike is water cooled, we really don't feel this will be an issue, especially given the external oil cooler.
I find it hard to believe there would be a 30 degree difference while moving at any kind of speed. On the 950/990s with the temperature guard, I doubt any difference would even register, but with the new readouts it is easier to see minor changes.
We design our skid plates for maximum protection and durability and to withstand a LOT of abuse. Some other skid plates (which shall remain unnamed) are more of a design / style exercise without providing any real protection.
Thanks for your support
Kurt
Old 06-02-2014, 10:38 PM   #51
davehg
Oddometer: 51
Did my install tonite after the dealer drilled out the stripped bolt holding the stock kickstand mount to the engine case. They had used loctite on the original install, and the replacement bolt also came with loctite. Recommend that Kurt add a warning on the install instructions that heat may be needed.
Overall, super happy with the product and install instructions, but still working out the fit, as it seems I need to trim the rubber block to get the right front mount to line up to fit the bolt holes. Agree that the filing of powercoat of the kickstand mount should be done at the factory. This was a frustratingly irritating install, but once complete, the product quality is apparent. The kickstand relocation feature is worth the hassle.
davehg is offline   Reply With Quote
Old 06-03-2014, 12:09 PM   #52
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 5,011
Originally Posted by KTMforget View Post
Hi Mike
Kurt
Assume naked...and I will go from there....my set up will be the motor then a spacer then your bracket then a spacer then my new bars...
KTM 1190R...Adventure Beast, KTM 690 Quest...Rally Beast, Husqvarna 501...Trail Beast, KTM 950SE......Desert Beast, KTM 300xc...Woods Beast
Nowwhat is offline   Reply With Quote
Old 06-03-2014, 12:13 PM   #53
WickedKTM
Lost
Oddometer: 129
Kurt
Thanks for the input Kurt. I am continuing to monitor the temps. Even with the temps I am seeing they are still low enough IMO to be "normal" and the protection is worth it for me at this point. I mainly posted to see if anyone else has experienced it.
Your product is nice and the install was easy. I will agree with the original kickstand mounting bolts. The large bolt on the rear is on there good and heat should be applied as the torx head stripped on mine also. Since its not being used, I just used an angle grinder to cut the original kick stand mount there at the bolt and left it in there :) Maybe one day when I am down there and the exhaust is off ill spend the time removing the stripped bolt.
Old 06-18-2014, 11:25 PM   #54
KTMforget
KTMforget's Avatar
Oddometer: 856
Thanks for all the feedback. We appreciate everyone's patience while we have been trying to keep up with demand.
We just completed our next batch and all backorders have been filled. Come and get 'em!!
Old 06-20-2014, 05:01 PM   #55
Omaha Tenere
Oddometer: 22
It is 90 degrees here and 2 weeks since installing my BDCW skid plate. No heating issues at all.
Old 09-12-2014, 02:28 PM   #56
davehg
Oddometer: 51
Black Dog customer service rocks
Unsolicited, Kurt sent out an email inviting skid plate owners to switch over to a side stand relocating bracket that enabled greater lean angle with the sidestand down. Some owners complained about the lean angle, prompting the email.
I hadn't complained, though I had secretly wished for a bit greater lean, as parking the KTM in the dirt with a more upright lean can make it difficult to mount and dismount for those with shorter inseams.
I reply that I would like the upgrade, and less than a week later, it arrives at my mailbox. FREE OF CHARGE. Only requirement was to return the old one, or be charged $50. BLACK DOG EVEN PAID THE RETURN SHIPPING.
The KTM leans more noticeably, making it easier to mount and not as tricky to park in the dirt or hunt for level ground.
Love this level of customer service, and it's the first time a vendor sent me an unsolicited upgrade free of charge. Look forward to more of their products and highly encourage those looking for a skid plate to go with this one. Nice job, Black Dog!!
Old 09-12-2014, 02:36 PM   #57
WickedKTM
Lost
Oddometer: 129
x2 - I opted for the new part (not installed yet). Great proactive customer service!
Old 09-12-2014, 02:39 PM   #58
Black Hills
Oddometer: 1,323
they are always fantastic to deal with. I opted for the new part as well as mine stands pretty straight up on the side stand. I do love the skid plate, after initial install removing fo roil changes is a piece of cake.
Black Hills is offline   Reply With Quote
Old 09-12-2014, 03:45 PM   #59
carden260
Oddometer: 41
[QUOTE
Love this level of customer service, and it's the first time a vendor sent me an unsolicited upgrade free of charge. Look forward to more of their products and highly encourage those looking for a skid plate to go with this one. Nice job, Black Dog!![/QUOTE]
Kurt and Black Dog Cycles are the best. I got a set of soft bags along with all the usual gear for the 1190 and had a failure of a mounting ring on one of the bags. Kurt had a new set at my house before I even returned from my trip to Colorado. Not going to find better customer support then that.
Thanks Kurt for your ingenuity and customer service.
Jason
carden260 is offline   Reply With Quote
Old 09-12-2014, 06:23 PM   #60
mlyamkaw
Drill Baby Drill
mlyamkaw's Avatar
Oddometer: 572
I got it as well, but am opting to stay with it as is. Mine leans enough with the setup from Blackdog, but wondering if I will regret this if I want the larger foot for off-road...
14 KTM 1190R
09 KTM 300 XC-W
13 Ural Gear Up
14 KTM 500 EXC
mlyamkaw is offline   Reply With Quote
Times are GMT -7.   It's 07:44 AM.
