Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 06-03-2014, 04:16 PM   #16
Jean-Luc
Throttle committed
Jean-Luc's Avatar
Oddometer: 2,233
Originally Posted by coloktmGS View Post
How did you fix the ram ball to the bike? What ball is that?
I do have the exact same questions for Doug as I'm using RAM mounts for my GPS on all my bikes...
My ride reports
Jean-Luc is offline   Reply With Quote
Old 06-03-2014, 06:35 PM   #17
asphaltassassin
Oddometer: 6
Here's what I went with. Didn't feel like buying a GPS so I just got a phone case from SW Motech and the 1190 GPS mount and am going to use my iphone with Google Maps. Haven't got any seat time yet, but it's sturdy. Some mild drilling is required, but I could do it so just about anyone can. Only problem is that the windshield gets in the way of the quick release feature when mounted this way. I could have turned it sideways for mounting as well.
asphaltassassin is offline   Reply With Quote
Old 06-03-2014, 06:36 PM   #18
asphaltassassin
Oddometer: 6
Here's a side view.
Old 06-06-2014, 09:01 PM   #19
Doug Matson
Doug Matson's Avatar
Oddometer: 1,995
I used the standard ball with an angled end for the bolt, I drilled through the top[ of the dash and used a washer inside the headlight housing then drilled a hole just to one side of the split in the headlight shell then attached the wiring to acc1. Works great and is very stable, and simple!
04' 950 Adventure
03' 450 EXC
05' K1200 LT
93' XR 200
72' SL 100
67' Triumph Bonneville
70' CB 350
65' CB 160
Doug Matson is offline   Reply With Quote
Old 06-06-2014, 11:11 PM   #20
Jean-Luc
Throttle committed
Jean-Luc's Avatar
Oddometer: 2,233
Way cool, thank you Doug I guess that the plastic is pretty strong in this section... I did not know about that angled RAM but found it here: http://www.amazon.com/RAM-Motorcycle...RMPBDP9HBQ657N
My ride reports
Old 06-07-2014, 01:04 AM   #21
gunshot72
Knee down complete
Oddometer: 310
I tried the Touratech lockable mount on the 1190 along with the Touratech mount bar but it was awful. I couldn't see the screen because the shaking was so bad. So, I sent it back and went with the genuine KTM mount and it has been very good.
gunshot72 is offline   Reply With Quote
Old 06-07-2014, 01:29 AM   #22
striped tomato
striped tomato's Avatar
Oddometer: 133
Think I'm going this way next. I have the ktm mount with the touratech locking mount currently, but it's too much weight I think. Just have to remember to take the unit with me when I stop.
'13 1190R
'13 FE350
'13 KTM 1190R
'15 Husqvarna TE300
striped tomato is offline   Reply With Quote
Old 06-07-2014, 05:12 AM   #23
OhBoy
Got Out
OhBoy's Avatar
Oddometer: 1,169
At the top left of the tach there is a silver ring around a screw head (holds the whole assbly in place)
Used a "U" handlebar RAM mount with a long arm.
Start slow then easy off
OhBoy is offline   Reply With Quote
Old 06-07-2014, 07:49 AM   #24
Jean-Luc
Throttle committed
Jean-Luc's Avatar
Oddometer: 2,233
Great, another option that I'll try first since I have the U Ram. Thanks!
My ride reports
Old 06-07-2014, 07:52 PM   #25
NewToMe
safety 3rd
Oddometer: 1,072
Factory mount with Ram cradle. The bolts don't line up so the Lucite plate is drilled to allow a clean solution, once it's finished (I cable tied it for today's ride.)
NewToMe is offline   Reply With Quote
Old 06-08-2014, 02:00 AM   #26
NoSpam
Oddometer: 170
Nice work NewToMe - how/where did you connect the power supply for the GPS?
NoSpam is offline   Reply With Quote
Times are GMT -7.   It's 02:56 AM.
