Old 05-15-2014, 11:13 AM   #31
renogeorge OP
Oddometer: 1,486
Paid with Paypal.. $189.99 was the total--no tax, fees, duty or shipping
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 06-02-2014, 04:47 PM   #32
renogeorge OP
Oddometer: 1,486
Final Installment
OK. Got the high tech, super secret E bay/Chinese 320mm disc installed. The bracket is made for the early (pre-'09??) calipers. I don't know the exact years and anyone thinking of buying one should be aware that Brembo changed the spacing on the mounting bolts--caliper to bracket, not bracket to fork somewhere along the line. The stock caliper on my 2007 Adventure will not fit the bracket in the kit. What fits is an older KTM single (450/525, etc.) caliper. Measure closely as the spacing is only off by 4-5 mm and I am not at all sure when the calipers changed and which models fit!
Got the SE brake lines as I removed that too. Rear fine, front, a couple of inches too long but it works. Pulled the ABS wiring loom and both front and rear wheel sensors. Front needs the 950 speedo sensor.
Bolted it all up and bleed brakes. With this combo and stock Adventure front master it was rideable but good not a good braking feel up front.
Ordered and installed 2014 690 Enduro front master. SUCCESS!! I swear I have better front brakes than with the OEM dual disc setup. And a nice bit of storage under the seat where the ABS pump was. And the bike is so light I am doing triples out of my driveway....(NOT)
This ended up not being such a new idea. The HOW and other threads cover much of this and pointed me in this direction. Thanks to all who contributed there!
FWIW
KTMs--300, 518, 990
renogeorge screwed with this post 06-02-2014 at 05:13 PM
Old 06-02-2014, 05:02 PM   #33
FZcruzer
Oddometer: 599
Thanks for posting your progress. Have you ridden it enough or hard enough to induce brake fade? I am looking to follow your lead just not sure what options I want to take.
FZcruzer is online now   Reply With Quote
Old 06-02-2014, 05:14 PM   #34
MymoJoe
Ride Ride Ride
MymoJoe's Avatar
Oddometer: 2,962
good job.
post a picture or two if you don't mind.
so I am a little confused, which adaptor bracket did you use? and where did you get it? the one you mentioned on the ebay link, you stated Didn't fit, is that right?
Joe
This ended up not being such a new idea. The HOW and other threads cover much of this and pointed me in this direction. Thans to all who contributed there!
FWIW
Simpson Trip 2008
http://www.advrider.com/forums/showt...33#post7397233
Life should NOT be a journey to the grave with the intention of arriving safely in a well-preserved body, but rather to skid in sideways, body thoroughly used up, totally worn out and screaming "WOO HOO - what a ride!"
MymoJoe is offline   Reply With Quote
Old 06-02-2014, 05:25 PM   #35
renogeorge OP
Oddometer: 1,486
The one I ordered off E Bay, fit the fork side but not the caliper--off by 4-5 mm on mounting holes. That was using the stock Adventure caliper.
Tried an older dirt bike caliper and it fit the E Bay bracket. So I bolted it up and off I went.
I thought of this later. But a guy with an older (pre '09??) dirt bike could swap calipers with his Adventure. The Adventure caliper will fit the dirt bike bracket (I THINK??). Then use the dirt bike caliper with the E Bay bracket and 320 mm disc.
Then again, my brain may have turned to mush from prolonged exposure to brake fluid....
Haven't mastered pictures yet. But if you are really interested, PM me with your e mail and I will send some.
KTMs--300, 518, 990
Old 06-03-2014, 12:54 PM   #36
brents347
Trusting my Cape...
brents347's Avatar
Oddometer: 3,917
Keep in mind, this bracket (http://www.amazon.com/Braking-320mm-...vehicleType=46) does fit the Adv and SE caliper. It requires a Honda brake pad (with a small modification).
07 Yamaha R6
07 KTM 950 Super Enduro
04 KTM 250exc- plated two-stroke
01 Kawasaki KE100
74 Honda MR50
brents347 is offline   Reply With Quote
Old 06-03-2014, 01:52 PM   #37
renogeorge OP
Oddometer: 1,486
Good to know. I don't know how costs would add up. I paid $190 for big rotor and bracket. EXC calipers are pretty cheap and use KTM pads without modification---a six of one, half dozen of another deal, I guess....Unless the Honda pads are larger, better, etc..
KTMs--300, 518, 990
Old 06-03-2014, 05:33 PM   #38
kkm
Oddometer: 78
Don't the fast guys need TWO front rotors?
Kevin
2013 KTM 500XCW
2012 KTM 990R ADV
2009 Aprilia RSVR
2006 KTM 525EXC
2004 KTM 525EXC
kkm is offline   Reply With Quote
Old 06-03-2014, 06:13 PM   #39
renogeorge OP
Oddometer: 1,486
Fast Moto GP guys? Fast dirt riders? BMW wannabes?
KTMs--300, 518, 990
Old 06-03-2014, 06:46 PM   #40
MymoJoe
Ride Ride Ride
MymoJoe's Avatar
Oddometer: 2,962
hmmmm
fast like............ Fabrizio Meoni's Rallye 950
your statement is from someone who has never ridden a KTM Adventure with a large single front brake... the difference in feel and weight is very noticeable...
Kevin
Simpson Trip 2008
Old 06-03-2014, 06:53 PM   #41
renogeorge OP
Oddometer: 1,486
If someone seriously wants to know "why", there are other threads which discuss and debate it on and on and on. Not a mod for everyone I guess, just us slow guys.
KTMs--300, 518, 990
Old 06-03-2014, 08:25 PM   #42
Johnf3
Oddometer: 1,067
Glad to see you got it all installed and are happy. The Adventure caliper is bigger so it may offer a bit more stopping power and handle heat a bit better, but don't know for sure. I think I am going to go the way Brent did when I get around to doing my conversion. I asked CJ from CJ's Designs if he would consider making and selling an adapter that would be a no-modification bolt on conversion but he said he was too busy. He is running a custom bracket on his 950 that uses the stock caliper and pads with a 320mm rotor.
'06 950 Adventure S
'10 Husaberg FX 450
'01 KTM 520exc
Johnf3 is offline   Reply With Quote
Old 06-04-2014, 04:58 AM   #43
BykBoy
Meshuganeh
BykBoy's Avatar
Oddometer: 561
Where does this bracket fit? Inside the caliper? Or does it move the caliper away from the mounting holes on the fork leg?
Save $5 when you open a SmugMug account. Use the following coupon: 4l1hicJzWvYNE
BykBoy is offline   Reply With Quote
Old 06-04-2014, 07:52 AM   #44
renogeorge OP
Oddometer: 1,486
Any caliper setup, including stock, uses a bracket between the fork lug and the caliper. These aftermarket brackets replace the stock bracket and move the caliper out to align with the larger disc.
Hope that helps
KTMs--300, 518, 990
Old 06-04-2014, 11:43 AM   #45
brents347
Trusting my Cape...
brents347's Avatar
Oddometer: 3,917
My first 320 conversion was a modified stock bracket. I took the stock bracket and had the lower bolt hole filled/welded in. I then re-drilled and tapped a new hole with the proper spacing. Worked great, never failed.
Brent
07 Yamaha R6
01 Kawasaki KE100
74 Honda MR50
Times are GMT -7.   It's 02:02 PM.
