Old 04-04-2013, 11:07 AM   #1
The Griz OP
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
American light bulb designations for 990.
Hi. I've got a 2012 990 Adventure R. I want to replace the tail light, brake light, and turn signal lights with direct replacement LED bulbs. I've been browsing Super Bright LED's for bulbs but I don't know what to order. In the manual it says "W5W" for tail light, "RY10W" for turn signals, and "P21W" for brake light. I can't find those bulbs anywhere. Are they European designations? If so, what are the American bulb designations for these? Thanks!
From manual:
Old 04-04-2013, 01:15 PM   #2
DirtyADV
DirtyADV's Avatar
Oddometer: 2,285
It says socket type behind that is what you need to match first part is the strength of the bulb, 5W, 21W etc try to get a LED that matches or higher if you want to go brighter.
Going for led bulbs in the indicators might require a different relay or a resistor to go with each bulb.
EDIT: looked at it better and seems to be 2 different socket listings but the part behind the / seems to match fine with what listed on the site you linked to.
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 04-04-2013, 01:52 PM   #3
The Griz OP
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
/Johan
This helps, thanks!!
Old 07-11-2013, 11:45 AM   #4
Gil.caz
Oddometer: 24
hey griz, were you going for a brighter bulb? if so what did you go with and what do you think of the difference?
Gil.caz is offline   Reply With Quote
Old 07-13-2013, 07:06 PM   #5
BMacW650
BMacW650's Avatar
Oddometer: 747
Turn signal bulb
On my 08 these are the 'right' turn signal bulbs
BAU15S-x18-T: 18HP-LED 7507 (PY21W) LED Tower bulb
http://www.superbrightleds.com/morei...d-product/527/
They are super bright compare the the stock.
But I've gone overboard
BMacW650 is offline   Reply With Quote
Old 06-21-2014, 04:27 PM   #6
armourbl
Adventure Life
armourbl's Avatar
Oddometer: 626
I'm tired of people not seeming to see my turn or brake signals. I want to order some of these but don't know what color to order. Are you guys getting the White LED options and relying on the color of the lens cover to determine the light that is emitted?
Is it just a plug and play operation, no inline resistors needed?
Anyone use these for the brake light? Which model did you use?
ben
______________________________
2013 KTM 990 Adventure Baja Edition
armourbl is offline   Reply With Quote
Old 06-22-2014, 07:19 AM   #7
keener
Speed changes you.
keener's Avatar
Oddometer: 928
Putting a white led inside red behind red or amber plastic is inefficient. Most of the light will get reflected back and just the yellow or red part of the spectrum makes it through. Get a red or amber LED for better results.
Katoom comes with two tinny running LEDs in the tail light. But the main running/break light is old school.
http://www.manualslib.com/manual/904...R.html?page=57
I replaced mine with a red LED. I tried a couple. There is actually lots of room. you want something that projects light on the reflector around the bulb. This makes the whole housing light up. Some LED bulbs don't do that due to their shape and you will end up with a red dot. There is actually lots of room in side the housing. I ended up with a big one.
related threads:
http://www.advrider.com/forums/showthread.php?t=656184
http://www.advrider.com/forums/showthread.php?t=564090
http://www.advrider.com/forums/showthread.php?t=89344
04 ADV 950
keener is offline   Reply With Quote
Times are GMT -7.   It's 08:54 AM.
