Old 06-22-2014, 12:52 AM   #7966
KASUYAHO
Road Hog
Oddometer: 3,602
Originally Posted by cashelvale View Post
Don't know about a blast maybe a puff !! How have you been ???
SEALS ARE GONE !!
Not to bad mate, just working and being dad, out around Ballera at the moment playing rig pigs. Looking like heading back to WA just quietly.
I never know but one day i might have the time to go for a ride.
KASUYAHO screwed with this post 06-22-2014 at 01:12 AM
KASUYAHO is offline   Reply With Quote
Old 06-22-2014, 02:42 PM   #7967
cashelvale
Oddometer: 133
Busy being a farmer !! Season has been good for us.
Been doing the odd civil job for Senex out that way - Acrasia, Clifton Hills, Cordillo, Mungerranie They've got a fair spread on their leases now.
Not much bike time - although plenty on mustering bikes. Got a conference in Adelaide in July and hope to get the time to ride down.
cashelvale is offline   Reply With Quote
Old 06-23-2014, 01:35 AM   #7968
ditchwitch650
ditchwitch650's Avatar
Oddometer: 837
can someone / a couple of the guys with fluiddyne radiators post up a pic of the left side lower area showing the clearance between the header pipe and radiator please
ditchwitch650 is offline   Reply With Quote
Old 06-23-2014, 02:04 AM   #7969
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,368
does this help , i can take more now if you like
Sean-0 is offline   Reply With Quote
Old 06-23-2014, 03:32 AM   #7970
ditchwitch650
Oddometer: 837
nah that's good sean, My left radiator (stock) has always been close but the bottom tank rubbed through on the header today mutafuta
white bros e series headers
Old 06-23-2014, 03:38 AM   #7971
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,368
that is xr's only header , over size from stock . its close bout 10mm away , but the bend would be different from yours
Old 06-23-2014, 04:03 AM   #7972
AussieDaz
Oddometer: 59
Quick question: Do you have to pull the radiators off to take the header off?
AussieDaz is offline   Reply With Quote
Old 06-23-2014, 04:13 AM   #7973
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,368
no just loosen them up leave em connected . you can then have the room you need
Old 06-23-2014, 04:33 AM   #7974
ditchwitch650
Oddometer: 837
yes it's all in the bend mine is shorter/sharper which has cause this problem,
but something must be out as i had these header on my old xr for years without fault my rad guards aren't bent though
Old 06-24-2014, 06:05 AM   #7975
Burkey
Burkey's Avatar
Oddometer: 259
Bwahaha
That's bullshit, there's no way your radiators would be that straight
Multi-banned
Burkey is offline   Reply With Quote
Old 06-25-2014, 02:33 AM   #7976
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,368
thanks for the seals cashevale
burkey i aint crashed on these 1's yet
Old 06-27-2014, 07:00 AM   #7977
Perthite
lost so deal with it
Perthite's Avatar
Oddometer: 300
the rego'd 650R needs valve stem seals replaced... only prob is I can't get the swingarm bolt out of a donor bike (so I can swap motors over n still ride rego'd one while workin' on it's motor)....... tried swingin' a sledge onto it (with nut on) but it hasn't moved............... any pointers??
faster ya go closer to nirvana
XR650R weapon of choice
Perthite is offline   Reply With Quote
Old 06-27-2014, 07:45 AM   #7978
Russ
Russ's Avatar
Oddometer: 16,466
Heat
Russ is offline   Reply With Quote
Old 06-27-2014, 07:49 AM   #7979
Growelly
Growelly's Avatar
Oddometer: 146
They freeze between the crankcase bush and the swing arm pin. Had to cut my swingarm off to get it out and then replace the swingarm. Good luck.
Growelly is offline   Reply With Quote
Old 06-27-2014, 07:53 AM   #7980
Perthite
Perthite's Avatar
Oddometer: 300
shit a brick and I thought bashing it with a sledge hammer was drastic
Times are GMT -7.   It's 09:00 AM.
