Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 06-26-2014, 03:08 PM   #1
mhpalin OP
Hippy
mhpalin's Avatar
Oddometer: 53
1190S shift light going on at 6500
Hi guys My shift light started going on at 6500 just like during brake in the bike has 8000kms on it.I took it to the dealer on Vancouver Island they don't have a clue has any one had this to them.The Dealer contacted KTM Canada but they have not got back to them.It's running good should I just put a piece of tape over it and not worry about it till I get home to Alberta.
Thanks Mike
mhpalin is offline   Reply With Quote
Old 06-26-2014, 03:55 PM   #2
Black Hills
Oddometer: 1,138
the instructions to set it are in then manual. it's pretty simple, did you try that yet?
Black Hills is offline   Reply With Quote
Old 06-26-2014, 05:32 PM   #3
mhpalin OP
Hippy
mhpalin's Avatar
Oddometer: 53
Yes I turned every thing off this is just like when the bike is new and the light comes on at 6500 and stops automatically at 1000kms now it comes on again.It started as I was riding.
Mike
Old 06-26-2014, 06:23 PM   #4
Harold Waikiki
oldfatdumbbrokeoutof
Harold Waikiki's Avatar
Oddometer: 391
Thanks Mike
Mine does that before it's warmed up. After it reaches temp it goes back to normal. HW.
'14 KTM 1190R
'12 KTM 350 EXC
'82 Honda CT 110
'09 KTM 950 SE Erzberg
'15 KTM 1290 SA ordered.
Harold Waikiki is offline   Reply With Quote
Old 06-26-2014, 06:29 PM   #5
mhpalin OP
Hippy
mhpalin's Avatar
Oddometer: 53
Mine does it all the even after 2hrs on the road
Mike
Old 06-26-2014, 10:52 PM   #6
Bluesilver
Bluesilver's Avatar
Oddometer: 337
Originally Posted by harold waikiki View Post
mine does that before it's warmed up. After it reaches temp it goes back to normal. Hw.
+1
Bluesilver is offline   Reply With Quote
Old 06-27-2014, 12:23 AM   #7
MarchHare
Oddometer: 102
Mike
But have you followed the instructions in the handbook to adjust the point at which the shift light comes on?
MarchHare is offline   Reply With Quote
Old 06-27-2014, 02:28 AM   #8
OrangeV
OrangeV's Avatar
Oddometer: 580
Page 58 of the manual, go to the Settings screen, then go to where the shit light is, there you set your shift light, simple as..
75 V perky peak power from around 5000rpm and loves to be worked through the gears.
When you hit that sweet spot, it is simply electrifying. Stoner
A smile is a curve that sets allot of things straight..
OrangeV is offline   Reply With Quote
Old 06-27-2014, 07:25 AM   #9
Black Hills
Oddometer: 1,138
Mike
is the engine temp gauge working properly?
Old 06-27-2014, 08:31 AM   #10
mhpalin OP
Hippy
mhpalin's Avatar
Oddometer: 53
Okay guys first the shift light is off.I have the owners manual in hand for the 1190S on page 66 I followed the instructions and turned the shift light off.The bike was hooked up to the comp, at the dealer and showed no faults or codes.
When the light turns on at 6500 rpm it is steady does not flash.The temp guage shows 4 bars when warmed up.So what it looks like to me is that the cluster has reverted back to brake in mode and I will see if it stops after another 1000kms witch should happen on the ride home.
Mike
Old 06-27-2014, 08:33 AM   #11
Xphile1999
Oddometer: 10
Full Break in
The light will come on until you have completed the break in period, after that the shift light will automatically go to it's default. I believe the period to be 1000km.
Edit: Also found this reference in another thread
"Go to your owners manuel to page 72 part 9.2
Running in the engine
Guideline:
During the first 1,000km (620mil) 6,500 rpm
After the first 1,000km (620mil) 10,25 rpm"
http://www.advrider.com/forums/showthread.php?t=951265
Xphile1999 is offline   Reply With Quote
Old 06-27-2014, 08:45 AM   #12
mhpalin OP
Hippy
mhpalin's Avatar
Oddometer: 53
The bike has over 8000 klms on it
Old 06-27-2014, 10:19 AM   #13
Xphile1999
Oddometer: 10
Ooops, sorry, misread that as 800km....coffee, need coffee.
Old 06-27-2014, 04:12 PM   #14
mhpalin OP
Hippy
mhpalin's Avatar
Oddometer: 53
Okay guys I got a phone call from the dealer this morning he programmed my service interval wrong so I went back and he did it right this time.I guess when you go past your service interval the light goes on at 6500 rpm to tell you to take it easy.Well anyways it is still doing it so I will have to take it to my home dealership and maybe they can figure it out.
Mike
Old 07-05-2014, 03:56 PM   #15
mhpalin OP
Hippy
mhpalin's Avatar
Oddometer: 53
Okay finally figured it out the oil temp sensor has gone out of adj. just by chance when I started the bike today I checked the oil temp. 0C and the air temp was 21C. So I guess the bike thinks it's cold all the time and the light goes on at 6500.So will take it to the dealer for them to confirm this.Does any one think I am hurting the bike by taking it over 6500 rpm.
Mike
Times are GMT -7.   It's 01:03 AM.
