Go Back   ADVrider > Riding > Face plant
Old 07-03-2014, 05:25 AM   #826
atomicalex
silly aluminum boxes
atomicalex's Avatar
Oddometer: 2,982
Like I said, you really want change? Reform the bodies that govern this stuff.
Want better drivers? Campaign for better driver training/stiffer testing. Heck, MI has gone to 24 hours of theory and minimum 6 hours of one-on-one in-car instruction for just a Level 1 license. And only with a licensed instructor. Practically freaking Germany. Thank the FSM!
In this case, what is not particularly clear to everyone is that with NHTSA and BMW unable to find a clear failure mode and mitigation strategy, there is no path to a recall. The public is better served by being able to sue BMW in the event of damages, a path that would basically disappear if a recall was forced through. NHTSA is holding BMW's feet to the fire by exposing them to lawsuits. This puts the onus on BMW to find out why this failure continues to occur. Until they can do so, they are going to be subject to lawsuits.
If you don't like how the process works, go argue with NHTSA or your local legislator who can change it.
Katherine, in words - F650GSa - CBR250R (sold) - Super Sherpa - Nine Days in the Alps - More Alps: Finding GS Land
atomicalex is offline   Reply With Quote
Old 07-03-2014, 07:39 AM   #827
zig06
zig06's Avatar
Oddometer: 163
An easier fix
If you ever experience "unintended acceleration" in a car, there is a fail safe method of dealing with it ~ assuming that you don't forget or just simply panic (both easy to do under those circumstances).
The fail safe is to just put the car in neutral (automatic) or push in the clutch (manual). This will keep the power steering operating correctly and prevent the need to stomp on the brake pedal to over come the engine. Keying the engine off would work, but then you'd lose power steering and brake boost plus you risk turning the key off too far and locking the steering wheel. Once you've come to a stop then shut the engine off ~ if it hasn't already blown...
BUT, if the front wheel of your G650 falls off the only thing that you can hope for is a soft and gentle "unintended stop".
2012 KTM 300XC-w & a DR650 for adventure rides.
zig06 screwed with this post 07-03-2014 at 07:50 AM
zig06 is offline   Reply With Quote
Old 07-03-2014, 05:27 PM   #828
JettPilot
ADV Fanatic !!!
JettPilot's Avatar
Oddometer: 786
Originally Posted by PT Rider View Post
Many drivers do not realize that they must muscle the steering when the power steering stops, and that they may need to put two feet on the brake pedal when the power brakes quit. They weren't taught this, but they should be. They aren't a dumbass, they're untrained. And, the air bags don't deploy when the car crashes after the ignition switches itself off.
It does not matter if they have been " Trained " or not. If you need to stop the car, and pressing the brakes does not have the normal effect, any person with any intelligence at all is going to press harder, or as hard as they can... Same with steering, I don't care what the failure is, if I need to turn the wheel, and it is stiffer than normal, I am going to try to turn it harder. Only a total dumbass would just give up if they could not turn the wheel with their fingertips as normal.
I was test driving a car once, and the accelerator stuck to the floor. I just turned the key off and stopped. I was never " Trained " in this, I am just not a dumbass that would crash a car over a small unexpected failure.
The people that crashed the cars when the ignition got turned off = Dumbasses, training or not...
Mike
JettPilot is offline   Reply With Quote
Old 07-03-2014, 06:27 PM   #829
DrPepperz
Oddometer: 35
Originally Posted by _cy_ View Post
soooo .. what was the final solution?
sorry have not read this massive thread ..
agreed so much arguments filled too many pages, what was the result, new bike? compensation for injuries? did they take care of you at all or just try to lay all the blame on you?
DrPepperz is offline   Reply With Quote
Old 07-04-2014, 04:24 AM   #830
R0CKETMAN
R0CKETMAN's Avatar
Oddometer: 36
agreed
What was the outcome?... I've actually considered picking up a G650
Bones Heal, Chics Dig Scars, Pain Goes Away
Ducati Multistrada 1200s Pikes Peak
R0CKETMAN is offline   Reply With Quote
Old 07-04-2014, 04:36 AM   #831
WayneC1
Oddometer: 2,629
For the record there is only 1 instance of failure in 2011 or later model, it is this one, AntiqueWidow claimed insurance, replaced machine with another make/model and moved on with her life, what action the insurance Co took, if any, is unknown, it is up to them to take action. The BMW Dealer was informed at the time
We also now know these 2011+ forks are not made by showa, we do not know which manufacturer produces them for BMW
650GS Info - www.f650gs.crossroadz.com.au
WayneC1 is offline   Reply With Quote
Old 01-29-2015, 10:49 AM   #832
wild
Oddometer: 319
what makes you think it is the only case??? I have read about few cases already from different years including not only this model but other as well like e.g. F800GS.
and here another interesting BMW stories...
http://www.asphaltandrubber.com/reca...ension-defect/
wild screwed with this post 01-29-2015 at 11:47 AM
wild is offline   Reply With Quote
Old 01-29-2015, 11:47 AM   #833
Max Kool
Xtankteam™
Max Kool's Avatar
Oddometer: 3,239
a. where did you read that?
b. doesn't the F800GS have totally different forks?
Max Kool is offline   Reply With Quote
Old 01-29-2015, 04:35 PM   #834
wild
Oddometer: 319
so that makes them ok to break?
Old 01-30-2015, 07:39 AM   #835
Badjuju
Badjuju's Avatar
Oddometer: 354
That appears to be a frame/steering stem/triple clamp failure, NOT a fork failure. Not desirable, but completely unrelated….
Some people will tell you that slow is good, and it may be on some days, but I am here to tell you that fast is better... Being shot out of a cannon will always be better than being squeezed out of a tube. That is why God made fast motorcycles, Bubba.... Hunter S Thompson, Song of the Sausage Creature
Badjuju is offline   Reply With Quote
Old 01-30-2015, 09:13 AM   #836
Max Kool
Xtankteam™
Max Kool's Avatar
Oddometer: 3,239
Ditto that ^^
totally unrelated
Old 01-31-2015, 12:03 AM   #837
AlwaysRolling
AlwaysRolling's Avatar
Location: Sometime under the rain, sometime under the shade.
Oddometer: 278
On that R1200GS is looks as though the telelever unit is missing. What's the story behind that picture?
AlwaysRolling is offline   Reply With Quote
Old 01-31-2015, 06:41 AM   #838
SilkMoneyLove
SilkMoneyLove's Avatar
Oddometer: 2,305
2011 bmw g 650 gs fork failure
BMW co-branding with West Coast Choppers? :-)
SilkMoneyLove is offline   Reply With Quote
Old 02-10-2015, 08:47 PM   #839
DualGrampy
Oddometer: 24
In 2009 a friend of mine had the front fork fall off of his r1200. He was going about 45 mph around a curve when he dumped. The right fork was put on with a regular nut. This was a brand new bike. Dealer and BMW claimed "it could not have been them." He explained that he would not have ordered $5k in options if he was going to work on the bike, let alone take the front fork off for no reason. End result was that his insurance covered it and he had to pay $1000 deductible.
I really thought the dealership should have picked up the $1000, but he doesn't have any hard feelings against the dealer. He recommended I buy my latest bike from them and I did. Wish me luck. Maybe I will have my girlfriend ride that one (just kiddin')
DualGrampy is offline   Reply With Quote
Old 02-11-2015, 04:48 PM   #840
Max Kool
Xtankteam™
Max Kool's Avatar
Oddometer: 3,239
What is a regular nut?
Times are GMT -7.   It's 11:39 PM.
