Old 07-04-2014, 06:16 PM   #1
prince OP
prince's Avatar
Oddometer: 95
weird throttle response
it seems that my engine isn't responding to my throttle right away around the 4500/5000 rpm, it's a bit "jerky".
i tightened the chain and i do have a loose graphite ring around one pipe but i can't think that that could be the cause. my chain and sprockets have about 3500 miles on them so i don't know what it could be. The chain was an expensive one and its in good condition, i do have a G2 throttle.
It is something i' ve noticed recently, in the last 1000 miles.
Any ideas, suggestions?
thanks in advance
07 KTM 990 adv
06 Triumph Scrambler
04 1150 GSA (sold)
02 1150 GS ( crashed and stolen)
00 750 Ducati monster ( sold)
prince is offline   Reply With Quote
Old 07-04-2014, 07:19 PM   #2
Racer111v
Racer111v's Avatar
Oddometer: 851
An exhaust leak can mess with the O2 readings at the sensors. I would fix that first.
2004 KTM 950 ADV ...............................1979 Suzuki RM400 VMX Race bike
2006 DR-Z400E plated........................... 2001 Ducati ST2 944
2001 YZ250N 2T plated.......................... 1986 Yamaha FJ1200
Racer111v is online now   Reply With Quote
Old 07-04-2014, 11:24 PM   #3
TheRog
Dirtylittle funhaver
Oddometer: 75
Snatchy throttle
I have a 07. 990 adv. and they seem to have the freaky deaky throttle response.
The transition from off throttle decel to on throttle accel is a big jerky affair..
Riding along at steady cruise throttle has a bad flat spot when you role it on to accel.
It's not the chain. It's Ktm's inability to sort a proper fuel map for a bike that's 7 bloody years old. Disgraceful if you ask me.
The dealers don't give a shit.
About the only thing that's worked is a custom map from a pro tuner with a Dino and a exhaust sniffer.
TheRog is offline   Reply With Quote
Old 07-04-2014, 11:26 PM   #4
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,137
I would guess you need to check the TPS sensor or other adjustments, valve clearance, throttle body balance, etc.
"Son, you can't do both"
Old 07-05-2014, 02:25 AM   #5
ADVill
Oddometer: 609
I just adjusted the valves on my '08. I can't believe it made that much difference in how smooth the bikes is. I still think it's something else but I did nothing else.
'08 990 Adventure Orange of course
'00 520 EXC
'14 500 XCW
ADVill is offline   Reply With Quote
Old 07-05-2014, 07:41 AM   #6
prince OP
prince's Avatar
Oddometer: 95
the valves were adjusted 3000 miles ago, so i'll start with that ring and go from there. Also after i switched to FMF can i only did the 30 mns "running adjustment" on the bike, it hasn't been properly tuned with a map. I guess that will be my second thing to do ( not looking forward to it since there in an extensive thread on it which means its unresolved).
07 KTM 990 adv
04 1150 GSA (sold)
Old 07-05-2014, 08:31 AM   #7
Bighat
Oddometer: 39
Check with the dealer, there has been a map update but I'm not sure when it was issued....my 07 runs great all stock...
Bighat is offline   Reply With Quote
Old 07-05-2014, 10:12 AM   #8
crashmaster
ow, my balls!
crashmaster's Avatar
Oddometer: 5,298
Jerky throttle and a flat spot around 4500 rpm? My 07 has been that way for 70,000 miles.
Riding the Americas: No Fumar Español
_____________________________________________
crashmaster screwed with this post 07-05-2014 at 10:26 AM
crashmaster is offline   Reply With Quote
Old 08-08-2014, 04:55 PM   #9
prince OP
prince's Avatar
Oddometer: 95
ok so i took my bike to my mechanic, inside line moto in OC, he tries the bike and then the bike dies. It turns out it's a broken spring retainer.and it's a complete engine rebuilt. around $4200. i am at a loss here, my mechanic told me he never saw this before, does anyone? see attached photo of the culprit.
07 KTM 990 adv
04 1150 GSA (sold)
Old 08-08-2014, 07:30 PM   #10
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,452
Why a complete rebuild? Did the valve drop on the piston? Not sure why that would require a complete rebuild.
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Times are GMT -7.   It's 07:52 PM.
