Old 07-04-2014, 03:03 PM   #2161
grant22
grant22's Avatar
Oddometer: 478
950 Super Enduro "Quick Question(s)" Thread...
Ok sweet! No heat shielding for me then. Looks like I saved $50.
Thx again
grant22 screwed with this post 07-04-2014 at 03:03 PM Reason: spelling
grant22 is offline   Reply With Quote
Old 07-04-2014, 07:31 PM   #2162
JRod152
will work for tires
JRod152's Avatar
Oddometer: 347
Originally Posted by johnno950 View Post
Mate i got a set of akros on the se,i have not got the heat insulation shielding fitted (new oem rear cowl) and there has been no melting or heat damage done to my bike.
This is true w/ no soft luggage usage or luggage used w/ racks.
However, if you use a Giant Loop or similar "rackless" luggage system, you'll want shielding, even for where just the heat shield touches the plastic. I use a GL Mojave & Great Basin & the foil combined w/ their included heat shield does the trick.
"Never let the things you want make you forget the things you have"
JRod152 is offline   Reply With Quote
Old 07-06-2014, 06:16 PM   #2163
River6822
Fat kid on a 950 SE
River6822's Avatar
Oddometer: 361
heat shielding
You can get the self adhesive stuff from Summit Racing or Jegs. It makes a HUGE difference. I ran it under my seat for a while and I even added some to the voltage regulator bracket to help deflect the heat.
2013 KTM 1190 Adventure
2007 KTM 950 SE
2004 KTM 450 EXC
1979 Suzuki GS850
1993 Harley Café Project
River6822 is offline   Reply With Quote
Old 07-06-2014, 08:54 PM   #2164
Monterey_BS
On or Off - not sure
Monterey_BS's Avatar
Oddometer: 244
I'd also recommend using their (Summit) hose sleeves on fuel lines. It completes the heat protection, especially when running a vacuum pump.
Bob in Monterey
Monterey_BS is offline   Reply With Quote
Old 07-10-2014, 09:17 AM   #2165
Brown Dog
North Georgia Dual Sportr
Brown Dog's Avatar
Oddometer: 1,956
Originally Posted by grant22 View Post
...I'm replacing rear plastics (after a subframe failure)
Black or Orange ?
Brown Dog is offline   Reply With Quote
Old 07-10-2014, 10:34 AM   #2166
grant22
grant22's Avatar
Oddometer: 478
Plastic?
Black
If there's an option let me know please
Old 07-10-2014, 01:36 PM   #2167
Brown Dog
Brown Dog's Avatar
Oddometer: 1,956
ORANGE 950SM rear fender & headlight mask
Old 07-10-2014, 10:10 PM   #2168
grant22
grant22's Avatar
Oddometer: 478
Ahhhhh
That's Kewl
Old 07-11-2014, 06:39 AM   #2169
SpeedyR
SE in the SE
Oddometer: 911
now all it needs is some black wheels and it would look great!!!
SpeedyR is offline   Reply With Quote
Old 07-11-2014, 05:30 PM   #2170
pizzaboy
retiring tomorrow
pizzaboy's Avatar
Oddometer: 1,108
You shouldn't have gone there.
'09 BMW R1200GSA
'09 KTM 950SER Erz 03/08 BD
'14 KTM 1190 Adventure R 03/14 BD
pizzaboy is offline   Reply With Quote
Old 07-12-2014, 12:21 PM   #2171
ADV67
Alsace rider
ADV67's Avatar
Oddometer: 139
Plastic?
Black
My riding buddy's orange SE:
950SER '08 - XT1200Z '12- XLV750R '86 - XR600R ' 90 - XR350R '86 - DRZ400 '06 - Grizzly 700 '07
ADV67 is offline   Reply With Quote
Old 07-14-2014, 05:25 PM   #2172
Brown Dog
Brown Dog's Avatar
Oddometer: 1,956
Old 07-16-2014, 08:49 AM   #2173
todaystomsawyer
GNARLY ADVENTURER
todaystomsawyer's Avatar
Oddometer: 6
I have a center stand to install on my 07 SE . Can anyone tell me the size and length of the nuts bolts and washers bushings needed to bolt it on. I have looked for diagrams and part numbers but couldn't find the info.
todaystomsawyer is offline   Reply With Quote
Old 07-16-2014, 08:56 AM   #2174
Monterey_BS
Oddometer: 244
Which one do you have?
Bob in Monterey
Old 07-16-2014, 09:33 AM   #2175
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,408
22 6000302240030 CENTER STAND L=333MM 05 $219.29
23 60003030000 SPRING FOR CENTER STAND 03 $10.89
24 60003022115 SPRING TENSIONER 03 $34.09
25 0125080003 WASHER DIN0125-A 8,4 $0.29
26 0015080303 HH COLLAR SCREW M8X30 TX40
superceeded by
0025080306
$2.49
27 56503093000 SPECIAL SCREW M10X55 WS=17 $2.99
28 0125100003 WASHER DIN0125-A10,5 $0.29
29 60003022020 BEARING BUSH CENTER STAND 03 $33.69
30 60003022021 SPACER 10X16X38 MM 03 $26.09
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Times are GMT -7.   It's 10:44 PM.
