Old 09-13-2012, 09:39 PM   #1
fire1998 OP
Oddometer: 58
83 YZ 250 Suspension rebuild ?'s
How good were the stock forks on shock on an 83 YZ 250. Have the bike stripped and need to figure out what to do about suspension. I can rebuild forks but not shock, never done one before. Do the forks need the Gold Valves for vintage racing? Does the rear need the Gold valve. I called Race Tech and got a quote of $1100 for rebuilding front and rear with gold valves. Thats some expensive suspension!! What have you guys been doing and who would you recommend for work?
thanks
fire1998 is offline   Reply With Quote
Old 09-14-2012, 02:18 AM   #2
Reino
Reino's Avatar
Oddometer: 212
You can do those yourself its very simple all you need is a seal driver, fork seals, dust wiper and fork bushings.
Do you have a owners manual? If not get a clymer manual.
You can save a lot of cash by doing these thing's yourself and as for gold valves. Just buy them and install them yourself. they come with shim instructions (so i am told).
If you don't have time to do it, go local.
here is the link to the manual http://clymer.com/Book.aspx?bid=559&...hock+1976-1984
Reino screwed with this post 09-14-2012 at 02:28 AM
Reino is offline   Reply With Quote
Old 09-14-2012, 05:46 AM   #3
anotherguy
anotherguy's Avatar
Oddometer: 6,631
For the shock contact MX Tech. The shock is a Kayaba/KYB 43MM (I think) and if you want to update a lot of later KYB stuff retrofits. If you just want a service,i.e. fresh oil and a charge any good off road shop should have a suspension guy on staff.
On the forks. I have an '80 YZ465 w/'82 forks. I did the Cartridge Emulators and what a difference. The install is doable by anyone w/ a sense of how to drill a hole and deburr it. Well worth the effort for racing.
If you haven't yet upgrade the springs for your weight for starters.
you don't see luggage racks on a hearse..........act accordingly
Old 09-14-2012, 08:04 AM   #4
Shocktower
Shocktower's Avatar
Oddometer: 9,479
I put the golds on my RD, it is simple as pie, the rear shock needs service, find a shop who knows their stuff and get it done, for the front seal driver a 30mm socket worked great for me
Alexa Drew Nov 9 1995- Oct 28th 2004 Miss you baby
'08 KTM 530 EXC
79 RD 400 Daytona
Shocktower is offline   Reply With Quote
Old 07-16-2014, 05:30 AM   #5
athomerecords25
Vintage YZ *****
Oddometer: 145
I know this is a very old thread, but if you are around, how did the Suspension turn out?
athomerecords25 is offline   Reply With Quote
Times are GMT -7.   It's 11:13 PM.
