Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 07-24-2014, 06:21 AM   #20821
g容g
Canadian living in exile
g容g's Avatar
Oddometer: 6,667
Originally Posted by lmychajluk View Post
Is it set at the factory, or is the dealer supposed to set it as part of their prep?
good question.
I think it just comes on based on the odometer.
mine came on around 500 mi (IIRC) and I took it in for service around 1000 mi (dealer said anything between 500 & 1000 would be ok) so went to VT first
picked it up, light off, good to go.
I think it's just a "dumb" light, like my Moto Guzzi had, that comes on at set odo intervals, not a smart light that counts up from last reset... but could be wrong on that.
the other thought is.... can you reset the wrench using Tune ECU? if so, he may have reset it himself
Greg
Europe 2013 Europe 2012 Europe 2011 England 2010 Gaspe PQ 2008 Nova Scotia 2007
Try to see the world beyond your front door.
g容g is online now   Reply With Quote
Old 07-24-2014, 06:30 AM   #20822
Yossarian
Deputy Cultural Attach
Yossarian's Avatar
Oddometer: 9,680
When I use DealerTool to reset the service spanner, the range in number of miles until the spanner appears again is user-selectable in increments of 100 miles.
For instance, when changing oil, I can set the spanner to appear again in 3000, 3500, 6000, etc., miles from the current odo reading.
I'd be willing to wager that the dealer is putting in a value that they deem appropriate. Whether that's appropriate for you the owner, or for their service department revenue, who knows.
TuneECU will NOT reset the service icon.
Yossarian is offline   Reply With Quote
Old 07-24-2014, 06:32 AM   #20823
lmychajluk
Oddometer: 2,100
Originally Posted by g容g View Post
good question.
Oh, I'm almost positive it comes on based strictly on the odometer. I vaguely recall the tech at my dealer telling me that he set it to remind me to bring it in around 8k miles, rather than the scheduled 6k, or something along those lines.
-Lee
NE ADV Event Calendar (Request Additions here.)
2013 Triumph Tiger 800
2008 Suzuki SV650n (Sold... I miss that bike...)
lmychajluk is offline   Reply With Quote
Old 07-24-2014, 06:35 AM   #20824
MotoTex
Miles of Smiles
MotoTex's Avatar
Oddometer: 1,733
Originally Posted by mikeysduck View Post
I'll change the oil tomorrow, just because. I adjusted the chain today. I'm just curious about the Wrench icon.
First Mod: I pulled out the plastic stop in the fuel filler neck. Some reported having pushed the little bugger into the tank.
Better to have too much slack in the chain than not enough. When a chain wears it doesn't "stretch." What happens is that the rollers wear out allowing overlap that eats up the sprockets when they no longer fall "on center" between the teeth. The distance between the pins doesn't change from wear, the distance between the leading and trailing edges of the rollers change as the bearing surface between the roller and the pin wears. At your mileage I seriously doubt that there is any appreciable wear on the chain.
Again, better to be on the slack side of adjustment than on the tight side. To know for sure, you can use a ratchet strap to compress the rear suspension until the axle, swingarm pivot, and the counter shaft centers are aligned, then adjust the chain to have an inch or so of play. This position is the tightest it will be in operation.
The "mod" to the gizmo on the fuel filler is not really a concern. I don't think that, should it fall in, there would be any issue worth taking this preventative measure. The thing to think of is why did Triumph put it there?
It is to prevent contact between the fuel nozzle and the fuel pump which could eventually cause damage to the pump. Understanding this, I am very careful when filling and avoid putting any pressure on the gizmo, just using it as a guide, as intended, to place the end of the nozzle.
You now have no guide for reference, so take care when filling and avoid letting the nozzle rest on the fuel pump body, as the designers clearly felt it enough of a concern to attempt to prevent this.
This is The Internet. Confirm for yourself anything you may see while visiting this strange and uncertain land.
MotoTex screwed with this post 07-24-2014 at 06:41 AM
MotoTex is offline   Reply With Quote
Old 07-24-2014, 06:46 AM   #20825
lmychajluk
Oddometer: 2,100
My fuel tank ring is rattling around in the tank. It's already been replaced once under warranty. At some point, I'll try and fish it out, but won't replace it. I use a McCuff now when filling to prevent the nozzle from going too far down in the tank.
As for the chain, check out the Triumph Service Data Sheet (found it here - http://www.aspowersports.com/triumph..._schedules.htm). One method (which was new to me) was to measure the 20 links along the top of the chain with a weight hanging on the chain. 20 Links should not be more than 319mm. (Though I guess this measures whether the chain needs replacing more than proper adjustment...).
Since we're speaking of service, I'm coming up on my 12k service. I just recently did brake pads and tires. Given that there are very few valves out of spec at the first service, can I skip this step in the service? I can replace the plugs if needed on my own and save some $$$.
-Lee
Old 07-24-2014, 06:55 AM   #20826
Yossarian
Yossarian's Avatar
Oddometer: 9,680
Unless you are uncomfortable with removing the cam cover and at least measuring the existing valve clearances, I'd go ahead and do it while you are in there. I'm of the opinion that if you find any valves out of clearance, it will most likely be at the first check (12K miles) and will probably be stable thereafter. YMMV.
Old 07-24-2014, 08:18 AM   #20827
HerbTarlek
meh.
HerbTarlek's Avatar
Oddometer: 59
Is there a Tiger 800 FAQ anywhere? Ive looked and cant find one so I started making my own.
I thought I would share this if anyone needs it.
I plan on using the factory fog light harness with some 2" 10W cree LED lights.
For the plug & connector pins I put this parts list together.
TYCO/AMP 070 SERIES MULTI-LOCK 4-WAY CONNECTORS
-- FEMALE (PLUG): 174922-2(BLACK) ***fog light connector plug***
-- CONNECTOR PINS: 175026-1 24-22AWG or 175027-1 16-20AWG
And if you want to use the heated grips for aux power. I believe the male (cap) is needed for your accessory.
ECONOSEAL(TYCO) 3 POSITION
J series
-- MALE: 174359-2(cap), 174360-7(lock plate), 173600-1(20-24AWG connector)/171661-1 (digikey.com 16-20AWG connector), 172746-1(wire seal)
All parts can be found in stock at Mouser.com except the connectors noted above at digikey.com, which are stocked as well. Mouser has them too but only in a minimum of 100.
HerbTarlek screwed with this post 07-24-2014 at 08:25 AM
HerbTarlek is offline   Reply With Quote
Old 07-24-2014, 06:19 PM   #20828
The Haymaker
The Haymaker's Avatar
Oddometer: 645
you guys must all be short...
6'2". When in Adventure mode, I always mount via the peg.
Haymaker who?
https://www.facebook.com/groups/adventureridemaine/
The Haymaker is offline   Reply With Quote
Old 07-24-2014, 06:28 PM   #20829
The Haymaker
Oddometer: 645
Sooooooo...... long story short, when you doodinkins wear into the thingamabobbies, it changes the circumferential disastometer of the bilingual lines of forcifications.......... you say what any normal biker understands, "my chain stretched."
Haymaker who?
Old 07-24-2014, 08:12 PM   #20830
MotoTex
Miles of Smiles
MotoTex's Avatar
Oddometer: 1,733
Well translated.
Old 07-24-2014, 10:47 PM   #20831
MapMaster
Human Compass
MapMaster's Avatar
Oddometer: 925
Well translated.
Yeah, but if you want to keep the nitpickers at bay on this issue (a hopeless cause I know), just say "it wore out"
Actually, I've never had a chain 'stretch' beyond service limits. Link binding is what's done all of mine in, even the ones that lasted 40 and 50K miles.
MapMaster is offline   Reply With Quote
Old 07-25-2014, 01:20 AM   #20832
KildareMan
KildareMan's Avatar
Oddometer: 681
Cool2
To answer in reverse. No TuneECU can not reset the spanner. You need "Dealertool" for that
Using the description above the service light counts as a "smart" light, in as much when the spanner is reset, using "dealertool" you enter the distance in miles or Kilometres to the next service interval. So it's smartness depends on the users smartness to enter the correct interval.
KildareMan is offline   Reply With Quote
Old 07-25-2014, 07:06 AM   #20833
doxbike
Oddometer: 279
You missed a few of the little nibs, I see
Originally Posted by blacktiger View Post
You have chicken strips?
doxbike is offline   Reply With Quote
Old 07-25-2014, 11:35 AM   #20834
leo66
Oddometer: 16
Chicken strips. Well it's kinda of a knobby tire?
He could use sand paper like some of the pics I have seen. Lol
Sent from my iPad using Tapatalk
leo66 is offline   Reply With Quote
Old 07-25-2014, 11:43 AM   #20835
MapMaster
Human Compass
MapMaster's Avatar
Oddometer: 925
Sandpaper is too much work, just drop the tire pressure and ride it around the block.
Times are GMT -7.   It's 10:04 AM.
