Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 07-24-2014, 02:58 PM   #3091
kag
Wander Lust
kag's Avatar
Oddometer: 1,689
1190 Adventure Graphics Now Available
They just became available here in the US. It's the same graphics that are currently on the 1190 including the back panels. I ordered a set as my new paint set is almost complete.
Cost was $170.00
“Always drink upstream from the herd”
2007 Yamaha TW 200 / 2008 Buell Ulysses
2013 Triumph Tiger 800r / 2014 KTM 1190 EDS
kag is offline   Reply With Quote
Old 07-24-2014, 04:13 PM   #3092
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,949
Originally Posted by mvonkaenel View Post
Gotta like it NoWhat?...
How well does it work? Or shine? Or like, light up the road???
It is magic....Love Rigid products
Have them everywhere...
'14 1190R...Adventure Beast
'13 690 Quest...Rally Beast
'15 Husqvarna 501...Trail Beast
950SE......Desert Beast
Nowwhat is online now   Reply With Quote
Old 07-24-2014, 04:35 PM   #3093
mmckenna
Oddometer: 5
I have the BDCW kit, the light is really bright, but I don't have anything to compare to except for the high beam.
You have to use the SR lights; I made the mistake of buying the E series and there's not enough clearance for the suspension. Even with the SR kit you can't raise the fenders. I also wasted some money on the Skene IQ-175, which isn't compatible with the SR series.
Wiring is simple, but if you want to do a clean job you have to strip off all the molding and remove the headlight and fuel tank.
mmckenna is offline   Reply With Quote
Old 07-24-2014, 06:25 PM   #3094
alongat
alongat's Avatar
Oddometer: 1,186
And here are some pictures of my install: 1190 standard, givi crash bars, rigid industries sr series 6" combo led light bar, Piaa crash bar light mounts:
Since the light bar doesn't hang below the crash gaurd, there's no concern with clearance when the suspension compresses - still, it's tucked right under the snout quite nicely and protected, out of harm's way just in case...
Originally Posted by alongat View Post
Some pictures of what I'm doing will help. I will say though that if you want to use an led light bar of some sort and you want to keep it tucked in and up, you're somewhat limited to 6"-8" in width. If you want a bracket solution that would work with a 6" wide light bar and you're not using crash bars that pass right under the nose like my givi bars, check out blackdog and look at the light kit Kurt has developed using a 6" light bar. You may want to reach out to him to see if he will sell you just the brackets and source your own light. As for the acc wires, ktm is kind enough to provide additional electro connections (one set up front and one set at the rear). The one I tapped into is switched power so when the ignition is off, the acc1 wire goes dead. This is ideal for lighting and I used it to trigger a relay since the amperage rating of that acc1 connection is too low to run the light I'm using. The relay itself will require to be wired to the battery itself for power (with a fused circuit), ground (at the battery or the ground post just in front), I out wire from acc1 and a high amperage 12v output to power the lights themselves. I can provide a wiring diagram if you want...
Here's a link to the blackdog solution:
http://blackdogcw.com/black-dog-shop...-r-detail.html
Toronto, Canada
KTM 1190 ADV, KTM 530 EXC
Gone: Ducati 999R, KTM 530EXC, KTM 990ADV-R, KTM 950ADV, KTM 690, KTM 640ADV, kTM RC8R, Ducati 996S, Yamaha R1
And how can this be? For he is the Kwisatz Haderach!
alongat screwed with this post 07-24-2014 at 06:32 PM
alongat is offline   Reply With Quote
Old 07-24-2014, 06:26 PM   #3095
alongat
alongat's Avatar
Oddometer: 1,186
What do you mean graphics set? Do you mean the original decals / logos that ktm clear coats over or are you talking about alternative graphics?
Cost was $170.00
Toronto, Canada
Old 07-24-2014, 07:07 PM   #3096
Bosky
Long Haul ADV
Bosky's Avatar
Oddometer: 250
The crash bar mount is the best option. My main concern is if these lights bars could be used in trafic. I have 5 pairs of HID lights in my truck and 95% of time I use only one. So over doing it is not the trick but waist of money.
I'll think I go with Rigid or that 50Cal led bar.
This time next year we'll be millionaires.
Sr Del Boy Trotter
Bosky is offline   Reply With Quote
Old 07-24-2014, 08:55 PM   #3097
kag
Wander Lust
kag's Avatar
Oddometer: 1,689
Old 07-24-2014, 09:21 PM   #3098
youngblood
Oddometer: 354
Another option is HID. I had an amazing result on my 990S. Seeing shadows during the daytime is amazing! Bright as the sun and avoids extra weight of the crashbar and aux lights.
2014 KTM Adv 1190R
2007 KTM Adv 990S Dakar 7k miles FOR SALE
2005 KTM 525 SX Supermoto/Rally
2002 KTM LC4 Supermoto (old GumbyDave-mobile)
youngblood is offline   Reply With Quote
Old 07-25-2014, 03:45 AM   #3099
alongat
alongat's Avatar
Oddometer: 1,186
What colour are you painting the 1190?
Toronto, Canada
Old 07-25-2014, 04:46 AM   #3100
CHRIS_D
CHRIS_D's Avatar
Oddometer: 954
Have they made them yet so they can be dimmed? I really like the Rigid products but I need to be able to run them with my low beam.
2014 KTM 1190 Adventure R
2011 Victory Cross Country
CHRIS_D is offline   Reply With Quote
Old 07-25-2014, 04:46 AM   #3101
antirich5
Oddometer: 537
Originally Posted by Nowwhat View Post
Black Dog Cycle Work's light solution...
Also doubles as a low cost fork stabilizer
I like this idea, bit i think for bikes, you want the beams to be a little off center; focusing more on the side vision for cornering. I would want to see if there's a pot hole or other obstruction during a maneuver/turn.
Unless this bar gives you the ability to angle the side bulbs a bit; or does it just throw a very wide pattern?
antirich5 is offline   Reply With Quote
Old 07-25-2014, 05:56 AM   #3102
alongat
alongat's Avatar
Oddometer: 1,186
The black dog solution mounts to the forks so lighting turns with you. Mine is mounted to the bar so it doesn't move but it is the combo unit - providing distance output in centre and flood lighting at the sides so I can spot the glowing eyes of animals to the sides.
Toronto, Canada
Old 07-25-2014, 05:57 AM   #3103
alongat
alongat's Avatar
Oddometer: 1,186
I don't know.
Toronto, Canada
Old 07-25-2014, 07:28 AM   #3104
DirtJack
DirtJack's Avatar
Oddometer: 1,580
Use something like a Skene relay/dimmer circuit, triggered by your high beam switch (full power with high beam), and a programmable (off to full power in 10% increments) for low beam. Here's how I used a Skene IQ-175 to control my aux LED lights.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 07-25-2014, 04:06 PM   #3105
reenmachine
Rain or Shine
Oddometer: 525
Unless you're going reeeeeaaaaalllly slow the lighting turns opposite the direction of travel!
'14 KTM 1190 Adventure
'11 BMW G650GS
'02 Yamaha FZ1
reenmachine is offline   Reply With Quote
Times are GMT -7.   It's 04:23 PM.
