Stripped Exhaust Threads Advice
Discussion in 'Airheads' started by rockitdoc, Aug 9, 2014.
  1. rockitdoc
    rockitdoc Been here awhile
    Aug 29, 2009
    403
    Ft Collins, CO
    Just got a new to me R100RS. Tried to remove the exhausts and the left nut galled and stripped out the threads on the head. The other side looks to have been repaired once upon o a time. So, I need to repair or replace both heads. What 's the advice? Are they repairable or should I just lok for new heads?
  2. Wirespokes
    Wirespokes Beemerholics Anonymous
    Jul 26, 2002
    9,677
    Jackson's Bottom Oregon
    The one previously repaired looks ok - why replace it?
    There are a couple options (in my book) for the mushed threads. I've recently heard that it's possible, using a thread file, to bring the threads back to new condition. Never tried it myself, but it's easy and cheap enough, just purchase a thread file.
    The other solution is to send it to Paul Sturges in Newberg Oregon. It'll look brand new (functionally as well) when returned and shipping both ways will likely be a third the total cost.
  3. Box'a'bits
    Box'a'bits In need of repair Supporter
    Sep 26, 2008
    5,217
    Wellington, New Zealand
  4. rockitdoc
    Aug 29, 2009
    403
    Ft Collins, CO
  5. Pokie
    Pokie Love, build, ride. Supporter
    Apr 4, 2013
    16,052
    Fort Collins, CO
    I don't know who does it around here but when I was with the BMW dealer in Canada, we used to have the threaded area built up with weld then have new threads turned back on. It looked quite good and wasn't very obvious. The real trick is to stop trying to force off the nut, as soon as it starts to bind STOP and split the nut. This will save the threads at only the cost of a new nut. When the threads get stripped off by the nut galling, both the threads and the nut will need to be replaced. Yes, when you look inside the nut the threads will look ok but when you try to "work" the nut onto the new threads, there's a good chance you will now trash the new threads.
  6. 100RT
    100RT Long timer
    Nov 4, 2009
    2,163
    NEWTON FALLS, OHIO
    What condition are the valve guides ,valves and seats? No sense sending them out unless the rest are ok. Or have them reworked and repaired at the same time.
  7. rockitdoc
    Aug 29, 2009
    403
    Ft Collins, CO
  8. rockitdoc
    Aug 29, 2009
    403
    Ft Collins, CO
    They 'look' fine, but this is going to be a frame off resto, so I will have them completely done over while the threads are repaired. Hopefully, Sturges can do the whole enchilada. I'll do the rings and check the barrels for wear while I'm at it.
    #8
  9. One Less Harley
    One Less Harley OH.THAT'S GONNA HURT
    Nov 16, 2006
    6,791
    Bowling Green, Ky
    #9
  10. ML WYDELL
    ML WYDELL NED
    Apr 10, 2009
    570
    Looking for fuel
    #10
  11. Bill Harris
    Bill Harris Confirmed Curmudgeon
    Sep 20, 2008
    9,874
    backwoods Alabama
    And also:
    Randy Long
    Long's Mechanical Services
    R.D. 1, Box 685-K
    74 Risbon Road
    Honey Brook PA 19344
    610-286-5870
    to give plenty of choices for future Searchers.
    The big secret? yearly, back the nuts off, clean the threads with a brass-bristle brush and reassemble with plenty of anti-seize.
    --Bill
    #11
  12. Screaming Chicken
    Screaming Chicken Long timer
    Nov 29, 2007
    2,400
    Netherlands
    +1. They work great, I've had them on my GS since 2008...
    #12
  13. Wirespokes
    Jul 26, 2002
    9,677
    That's how Paul does it - cuts off the junk threads, welds up the area, then cuts new threads in the lathe. Like I said, you won't be able to tell it was ever repaired.
    As for the previously repaired head, he can fix that too. And yes, he replaces guides and seats if needed, as well as fin repair. He's been doing this for 35 years. I hate to mention his name because I don't want him so swamped he can't get to my stuff reasonably quick! :wink:
    #13
  14. airhead_irl
    airhead_irl Airhead addict
    Jan 20, 2010
    1,218
    Eire (Ireland)
    I have used these and they work well.
    #14
