Old 02-01-2008, 08:35 PM   #676
woody's wheel works OP
Built to Last
woody's wheel works's Avatar
Oddometer: 3,443
R100G/S...R1100GS...R1150 GS,,,are the front wheels interchangeaable????
Originally Posted by KLRTucson
Hi Woody,
I did a search and posted in G spot with ambivalent results. Can I put wheels from a 95 100GS with ABS on my 2002 brembo ABS 1150 GS?.....I'd just like an extra set for offroad.......I don't mind if the ABS doesn't work, I don't use it off road anyways. Is it cut and dry?.........Thanks for all the advice you've given.........
Mike
mike ,,,a '95 R100GS,,now what is that??? i've heard of a R100G/S prdecessor to the R1100 GS,,which begat the R1150GS,,which sired the R1200GS,,,
if it's an R100G/S you can't use it,,besides those would be 1.85x21'' x laced wheels up front and 2.5x17 on the rear,,,the R1100GS wheel whould work with R1150 GS up to sept-02 after That they went to stamped ABS rings mounted under the brake disc,,,as opposed to the earlier cast rings which mounted on their own casting spots,,,so theoretically if you leave off the stamped ABS ring 1mm/..040'' your disc would be in the same spot...to confirm,,,measure between your 1150 discs and the discs on your 1100 and i bet they are the same...if that's so
and celebrate...everything else is interchangeable
lateR wody
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
woody's wheel works screwed with this post 02-02-2008 at 09:22 AM
Old 02-02-2008, 06:07 AM   #677
KLRTucson
Hey, a bright shiny thing
KLRTucson's Avatar
Oddometer: 208
Sorry about the typo it was an 1100GS not a 100......my bad.......Sounds great, I'll check the build date of the bike and move from there, appreciate the timely response!......
2008 GSA ,........."You in with Smalls? Leonard Smalls?"
-Lone Biker of the Apocalypse-
KLRTucson is online now   Reply With Quote
Old 02-04-2008, 09:38 PM   #678
msGizmo67
g@@ber
msGizmo67's Avatar
Oddometer: 34
My new Woody wheel 19" front for HP2, thanks Woody Marv.
msGizmo67 is offline   Reply With Quote
Old 02-05-2008, 06:28 AM   #679
Built to Last
Oddometer: 3,443
so tell us about the handling,,,,
just curious,,,is this the hot set-up for ALL-around fun cruising????
ya know i tout it as such,, 'tis your thoughts that matter!!!!!!!
...woody
Old 02-05-2008, 10:35 AM   #680
ducky950
Gnarly Water Fowl
ducky950's Avatar
Oddometer: 1,642
Dirt Rims on a KTM SM?
Woody,
Have you heard of anyone having any success putting 21" front, 18" rear spoked rims on a KTM 950SM?
Nutin like a $30,000 pile up!
ducky950 is offline   Reply With Quote
Old 02-05-2008, 01:32 PM   #681
Built to Last
Oddometer: 3,443
950SM to 950ADV conversion....hmmmnnnn
Originally Posted by ducky950
Woody,
someone did it before,,,,however i think from what i've read,,,that we could pull off a more elegant solution,,,possibly use my new superlite hub that i developed for the HP-2 crowd...it uses a KTM disc bolt patternmmmhalfway there and is 1/4'' wider per side than the stock 950 adv....intriquing
looks like this...
http://www.advrider.com/forums/showthread.php?t=288592
the rear is interchangeabl i believe
Old 02-05-2008, 09:16 PM   #682
USMCG_Spyder
RPOC pilot
USMCG_Spyder's Avatar
Oddometer: 5,124
Talking
Got my Gear-Up pusher, hack and spare back from Woody today
During the course of the work we decided to punt the Rooskie steel rims in favor of Excel's, then decided instead of color-matching the OD green for the rims we'd see what a full camo job would look like (rims, spokes and hubs). I'll let the pictures speak for themselves:
These are the best I can do for now - had to go over to the storage joint and put 'em on by the light of my trusty USMC moonbeam, then park the Pig against the bulkhead in my crowded garage to install the freshly painted OD green hack windscreen. Tomorrow I gotta work on the brakes, and I'll take some pix of the pusher and whatnot.
Then I'm gonna go FLOG 'EM
On the 7th day God rested... Marines filled sandbags
"Why you buy motorcycle is broke from factory?" - Ukranian vendor representative at work referring to my Ural
"Take a chill pill, manboobs. Jo momma is the wrong place to be if you can't take a smacking." - jamesbrown
USMCG_Spyder screwed with this post 02-14-2008 at 01:10 AM
USMCG_Spyder is offline   Reply With Quote
Old 02-11-2008, 10:39 AM   #683
Zen Slug
Spineless Adventurer
Zen Slug's Avatar
Oddometer: 5,947
Question rim recommendations for 950 adventure?
woody,
i bent up the soft stock rim on my 05.5 950 adventure recently and want to replace it with something stronger. saw pyndon posting HERE that the 1.60" excel A60 is the strongest 21 inch rim available for the LC8, but i'm thinking i might wanna go with the 1.85" width for better on-road performance.
is there any advantage of going with D.I.D. or Sun or Excel in the 1.85x21 size in terms of strength and resistance to dents and dings? are all available in anodized black?
thanks!
-eran
"The female ass is a mysterious creature." Sir David Attenborough
Zen Slug's Rides
Join the ADV TooL PooL!
Zen Slug is offline   Reply With Quote
Old 02-11-2008, 03:29 PM   #684
Built to Last
Oddometer: 3,443
fyi A-60 or double signature EXCEL for the 950????
Originally Posted by Zen Slug
woody,
thanks!
-eran
Pyndon was right that the A-60 appears to be the toughest rim out there,,,unfortunately it is has the wrong indexing for the 950 front hubs,,,
he lucked out because we had a protype 950 Adventure hub floating around that was mis-indexed....good news for him,cuz we were able to use it and superlace it...
the 1.60 size is best suited for super rigorous dirt riding,,,for all around strength and practical use on the highway and the fire roads,,,we've had the greatest success with the aftermarket double signature Excel 7000 series aluminum rims.... we custom drill them in a euro indexing and our x3 superlace pattern...no problems yet,,,,the one or two that have been through the mill had definitely been tacoed at warp speeds
woody's wheel works screwed with this post 02-16-2008 at 03:19 PM
Old 02-12-2008, 10:18 AM   #685
Design4D
User Awaiting Email Confirmation
Design4D's Avatar
Oddometer: 172
KTM 950SE stock nipple wrench????
Woody
What size wrench do i need a 7mm or a 6.8 spoke wrench ??????? from pro motion???
I measured my nipples they are 6.87mm (yes i know .07mm = .003")
I have about a .06" potato chip going on 2 highs 2 low 90deg apart.
its on a 2nd wheel and was going to give it a shot, used to be pretty good with bicycle wheels.
Michael
Design4D screwed with this post 02-12-2008 at 10:50 AM
Design4D is offline   Reply With Quote
Old 02-12-2008, 05:01 PM   #686
woodysrookie
Oddometer: 41
KTM 950 stock nipples are 6.9 wrench.
I would say go with the 6.9 wrench!
woodysrookie is offline   Reply With Quote
Old 02-12-2008, 05:03 PM   #687
woodysrookie
Oddometer: 41
I would get the 6.9 wrench!
Old 02-12-2008, 05:28 PM   #688
MountainClimber
Snipe
MountainClimber's Avatar
Oddometer: 472
Woody
Thinking about doing the TAT over the summer on my 12 GS and would like some beefier rims. What sizes would you recommend?
2005 R1200 GS
There's no place like roam.
MountainClimber is offline   Reply With Quote
Old 02-13-2008, 06:37 AM   #689
Sir Not Appearing
That's no ordinary rabbit
Sir Not Appearing's Avatar
Oddometer: 1,111
I have a KLR600 front wheel that I would like to have resized from 21" to 19" using the original hub. I'd like to run a 100/90-19 tire. If you could give me some pricing options, I'd entertain a new rim and spokes but if the price could be kept down by using a used/reconditioned rim you might have that would work. Trying to do this bike on a budget. Feel free to PM me with details.
Sir Not Appearing is offline   Reply With Quote
Old 02-13-2008, 11:56 AM   #690
Springs
Shipping Wars
Springs's Avatar
Oddometer: 2,272
Woody's wheels Rate big!!!
Here is an unsolicited review for an outstanding company! These folks are a pleasure to work with. Every encounter with anyone who is speaking with the public has just plain been great!
They helped me with a custom wheel to use for my Baja trip with my son and I would not have been able to afford it at that time. The wheel was a vast improvement to my stock wheel. This was 21" front wheel for my 2004 GSA. If you need or want to talk about it PM it!
I wouldn't run anything else after having ridden 6000 on an off-road miles with it.
Their products are very nice and as good as I have seen. Remember you get what you pay for.
Chris and Woody are very straight shooters and I thank them publicly for all of their help.
I will be a return customer and have referred them several times already.
Top notch company and people!
Springer
Snortn Boar Transport
Finisher 2009 42nd running S.C.O.R.E Baja 1000, 313 X
Finisher's 2008 41st running S.C.O.R.E. Baja1000 202 X
http://www.snortnboarracing.com/
http://sidestandup.com/default.aspx
http://www.riderdown.org/forum/
RIP Jeff, and now Gary. I miss you both!
Springs is offline   Reply With Quote
Times are GMT -7.   It's 01:02 PM.
