Old 03-02-2008, 09:09 AM   #1
Roeligan OP
Belgium power!!!
Roeligan's Avatar
Oddometer: 504
G2Ergo throttle cam & 990 adventure
1 word for it: SMOOTH!!!!!
Installed the 400 cam a few days ago... Very smooth now...
Next week I'll try the 200 for onroad (think it will be little better for road only).
Roeligan is offline   Reply With Quote
Old 03-02-2008, 01:07 PM   #2
stanbloke
stanbloke's Avatar
Oddometer: 228
I fitted one of these with a K300 cam, brilliant.
Best farkle ever, so much control on the throttle now. .
Don't laugh, it's your turn next !
Sometimes it's better not to ask questions.
stanbloke is offline   Reply With Quote
Old 03-02-2008, 03:37 PM   #3
Cpt.Crashtastic
Cpt.Crashtastic's Avatar
Oddometer: 135
I have the 200 in mine and the 300 in front of my kboard. I feel another experiment coming on as the 200 is still snatchy.
Cpt.Crashtastic is offline   Reply With Quote
Old 03-02-2008, 06:33 PM   #4
Scrotie
Chuck U Farley
Scrotie's Avatar
Oddometer: 1,658
Has anyone tried the 300 and 400 back-to-back? If so, what are your thoughts?
I am about to install the 400, and was wondering if the 300 would be enough to relax the throttle a bit.
Scrotie is offline   Reply With Quote
Old 03-02-2008, 06:49 PM   #5
KrustyKustom
Lets Go....
KrustyKustom's Avatar
Oddometer: 633
My G2..
I bought the G2 that was private labeled by KTM hardparts, I guess it is the same. I installed the 400 cam on my 07, and all I can say is sweet! My bike was not terrible as some have posted, however the G2 added alot of control and finesse that I think will translate to better drivetrain wear and more traction on slippery conditions.
I paid like 95 bucks, but I can say it is a very well built piece. Nice install when you go to do heated grips, but be sure to install a plug on your wiring so that you can remove the heated element if you want to change cams. I like the 400.
Krusty Kustom,
Houston Texas
2013 KTM 500exc
KrustyKustom is offline   Reply With Quote
Old 03-03-2008, 12:50 AM   #6
Roeligan OP
Belgium power!!!
Roeligan's Avatar
Oddometer: 504
Will be installing heated grips late this week... thanks for the tip, hadn't thought of that yet
Old 03-03-2008, 04:14 PM   #7
hilslamer
2XRedheadedstepchild
hilslamer's Avatar
Oddometer: 1,785
uh-huh!
I have G2 throttlecams on all of my bikes. I prefer the 300 cam for all but the dunes on my 450 XC-F.
You would be amazed at how many professional supercrossers, off-road and streetbike riders use them but don't tell anyone about it...
hilslamer is offline   Reply With Quote
Old 05-17-2008, 09:23 AM   #8
viatormundi
Citizen of the world
viatormundi's Avatar
Oddometer: 644
How difficult, easy is to install this cam? Does anybody have a picture illustration?
viatormundi is offline   Reply With Quote
Old 05-17-2008, 10:14 AM   #9
fridayn2
RFV Adventurer
fridayn2's Avatar
Oddometer: 83
Install
Installation was at most maybe a few minutes. I have the ktm heatead grips intalled and there is enough slack in the cord that I did not have to instal a plug as some have suggested. Switching cams is just as simple.
Kronreif & Trunkenpolz Mattighofen
2008 KTM 990 Adventure Black
fridayn2 is offline   Reply With Quote
Old 05-17-2008, 05:55 PM   #10
Michhub
Major Medical
Michhub's Avatar
Oddometer: 3,836
So what are folks ordering/getting?
Is it the Throttle Cam System...
Item #: G2-40-300
or just the tube and cam of choice to save $$$....???
Mike
Reinheitsgebot
'07 990ADV '08 530EXCR '04 XR650L
Bonsai Elephant - "
Life without a 990 is no life at all!"
Michhub is offline   Reply With Quote
Old 05-17-2008, 06:08 PM   #11
cool dude
cool dude's Avatar
Oddometer: 272
Mine
I have tried both the 300 and 400 cams on my 2006 Euro 990. The 300 does take the majority of the small throttle opening sensitivity away and the 400 improves it further. Obviously the sensitivity reduction is at the expense of throttle action. i.e. you have to give the throttle more of a twist to achieve the expected acceleration. At small to no throttle openings I still find that the it is sensitive to bumps and I can sense the surging at constant throttle.
When I fitted the throttle tube (with KTM heated grips) I found that the throttle tube was fairly loose around the bar. I then wrapped the bar with a single layer if insulating tape to try to remove some of the play. This worked fine for about 6 months until last week. The tape finally slipped, wrinkled up and took all of the slack out of the throttle, inducing positive friction. This made if VERY difficult to twist the throttle in either direction. It was so bad that my hand/wrist cramped half way through a 7 hour 2 up ride. On removing the tape the problem was solved but I did notice that the throttle response was far lighter. So much so that now find it difficult to ride smoothly.
The upshot is that I found that lightly wrapping the bar (under the throttle tube) provides just enough friction to further help smooth out the throttle action. All I have to do now is to find a thin tape (or heat shrink) that will provide the required level of friction without slipping and locking the throttle. Any suggestions would be welcome.
cool dude is offline   Reply With Quote
Old 05-17-2008, 06:46 PM   #12
wee tee cee
Oddometer: 170
MECHANIC AT MY LOCAL DEALER WAS GREASING THE BAR AND INSTALLING THIN O RINGS,APPARENTLY ITS AN OLD MOTO CROSS TRICK.
wee tee cee is offline   Reply With Quote
Old 05-18-2008, 04:18 AM   #13
Triwi
Oddometer: 42
Installed G2 cam (400) then used a sheet of copper shim (Engineers supply store) full length of throttle tube and cut to wrap once round bar with edges meeting. Grease tube and have eliminated all play as well as grease damping the sensitive twist action. Vast improvement in low speed rough terrain control.
Hope this helps
Triwi
Triwi is offline   Reply With Quote
Old 07-08-2008, 11:45 AM   #14
Michhub
Major Medical
Michhub's Avatar
Oddometer: 3,836
I just installed the throttle tamer essentially just the tube with only the 400 CAM....its fantastic!!!
Mike
Reinheitsgebot
Bonsai Elephant - "
Old 07-09-2008, 10:17 AM   #15
Footprint
Rat race Dreamer
Footprint's Avatar
Oddometer: 2,886
Remove the grip (I used compressed air to slide the rubber off the stock plastic handle).
Loosen and pull out the the bolt on the outside of the hand guards.
Undo the 2 bolts holding the case around the cables to the throttle.
Pull the throttle cam out of the housing and remove the two cable ends (slotted and there is enough play).
Attach chosen throttle cam (100 (stock), 200, 400 come in the kit or get the 300 separate) to the throttle handle body (has a shape that only goes on a certain way).
Put the new assembled throttle cam/handle back on the bar.
Re-attach the cables and bolt the cover back on.
Replace the rubber grip (again compressed air or use a little alcohol).
replace the bolt for the hand guards.
I took this time to also add a Kaoko throttle lock to work as a cruise control. Good time to also add heated grips, or change out the hand guards.
Really easy to do! Good luck.
2007 KTM 990 ADV
2008 URAL Patrol
"If you sit around waiting for death to take you, you will miss life. Die living life to the fullest, don't live dying!" -patient
Footprint is offline   Reply With Quote
Times are GMT -7.   It's 12:01 PM.
