Old 08-10-2008, 11:06 AM   #61
nave
Nave
nave's Avatar
Oddometer: 353
Originally Posted by Molgan
Oh holy sh*t, that is a sweet one! Wan't to know more about it, what is the weight, engine modifications etc? And more (and bigger) pics please! =)
Hello all BIG lovers…
So, some more details-
For now I haven’t done any modification with the engine and carbs' (will prop' replace them to mikuni fcr) the air filter is an open uni filter with the original air box (with some modification).
The bike dry weight (the real weight- not like Suzuki…) is- 170 kg.
Next to come- changing the rear of the bike- swing arm, rear frame (to aluminum), wheel hub and rim (original is so heavy!), led lights and more…
15-20 kg less and I will be very happy.
Because of some small problem 10 years ago (the bike is 1993 model) I had to open the engine (about 80K then) and decided to give it a full overall. The bike has now more then 200K on the same engine!!!
Excellent bike!
the pic' is from about 2 years ago and it's not updated.........(many changes since then)
nave screwed with this post 08-10-2008 at 11:11 AM
nave is offline   Reply With Quote
Old 08-10-2008, 03:14 PM   #62
Molgan
nub
Molgan's Avatar
Oddometer: 234
Now I'm inspired, keep us updated if you continue the transformation. =)
Molgan is offline   Reply With Quote
Old 08-10-2008, 03:19 PM   #63
elephant man
Oddometer: 60
great bike- more in person.
nave, good to see you join in
the project on my bike is slowly taking shape- ordering parts is the first step.
prepper for a lot of questions...
elephant man is offline   Reply With Quote
Old 08-10-2008, 03:47 PM   #64
bluesman
Oddometer: 3,330
it's great bike and great work!
I feel inspired now to buy second DR and turn it into that kind of machine.
My current DR just have to be long-distance 2-up capable, so lots of stuff I can not get rid of. But I think I should buy second one and turn it into 160 kg offroader.
Please keep us posted, it's really inspiring!
One question - for front forks - did you have to make custom yokes to fit or you used CRF tripple tree?
bluesman screwed with this post 08-10-2008 at 03:58 PM
bluesman is offline   Reply With Quote
Old 08-10-2008, 07:43 PM   #65
arrowrider
Oddometer: 16
Yes "ZTAJ" the bike i brought was the one off TradeMe. The bike is in better Nic than the photo's showed .If only he had washed it , the bike would of presented its self better than it was on the auction.
arrowrider is offline   Reply With Quote
Old 08-10-2008, 11:31 PM   #66
nave
Nave
nave's Avatar
Oddometer: 353
thanks,
i used the CRF tripple tree and worked the CRF steering axle to fit the BIG. they are allmost the same (same length, and lower bearing)...i was looking for a very rear bearing (top bearing) that will save me that, didnt find...
the front wheel is the original and the caliper was adjusted to fit the CRF fork.
some pix from the way later on.
and- hello elephant man
Old 08-11-2008, 12:33 AM   #67
bluesman
Oddometer: 3,330
Originally Posted by nave
thanks,
Thanks! I am off to ebay searching for CRF front! :)
Old 08-11-2008, 01:49 AM   #68
MCmad OP
Oddometer: 7,842
Nave, Welcome, thats inspiring stuff, I will record your details on post 1, think I will also record which size bikes you all ride, see if we get more 750s or 800s
Also hows it going in Israel at the moment, a lot of my friends have been there, they say its a very spiritual place with all the history and every thing and out of interest New Zealand is the futherest country in the world from Israel, aant the internet cool
MCmad screwed with this post 08-11-2008 at 02:01 AM
MCmad is offline   Reply With Quote
Old 08-11-2008, 04:52 AM   #69
nave
Nave
nave's Avatar
Oddometer: 353
look for CRF450R the F spring will be to soft...
fixing a flat tire...
nave screwed with this post 03-20-2009 at 12:51 AM
Old 08-11-2008, 05:26 AM   #70
nave
Nave
nave's Avatar
Oddometer: 353
I would love to be in new zealand now
all is true about Israel...
It's like a 2 stroke motorcycle- small, fast, noisy, lots of fun and...can kill you
the original bike and in the middle of the way- still with the original fork...
nave screwed with this post 03-20-2009 at 12:52 AM
Old 08-11-2008, 07:08 AM   #71
Manos
Oddometer: 17
And these motors produce the highest hp off any thumper (non turbo production based ) with Up to 94 rear wheel horsepower ( over 100hp at the crank) in there most modified form
Hello,
Would you elaborate a bit more on the above?
How? what? who? where? etc
Links????
Manos
Manos is offline   Reply With Quote
Old 08-12-2008, 03:00 AM   #72
MCmad OP
Oddometer: 7,842
Can relate to those motorcycle analagies but you probably wouldn;t like it here in NZ we dont have anything nuclear here
How have your mods affected the DR on the road, for example losing the fairing, and did you notice a performance increase with the loss off wieght
Old 08-12-2008, 04:04 AM   #73
MCmad OP
Oddometer: 7,842
Originally Posted by Manos
Hello,
Links????
Manos
Hi Manos we are honoured, you have been a member for 2 years and we get your first post, I quess better try and answer well
Try this Link http://www.thumperpage.com/articles/UKmono.html
Details as below
1998 European Season Ended
Our European season ended with a very nice 21yr old German lady named Katja Poensgen winning the championship riding a BMR-Suzuki. She achieved this by winning 4 out of seven races with one second place & 2 DNFs.
The BMR-Suzuki she rode is a very interesting tool. It may have started life as a DR800 motor but that was long ago & far away! It's creator is Rupert Bainzel, and apart from a lot of bottom-end work, the motor features a machined-from-the-solid top end, with an Apfelbeck type of cylinder head where the valves are arranged radially, with exhaust & inlet ports placed diagonally. As you can imagine, this calls for some hairy machining of cams, they are conically ground. It's watercooled and fuel-injected & gives over 90BHP from 741cc at 8000 & peaks at something like 9300rpm. Since this represents a BMEP figure of something in the order of 215psi it is a considerable achievement.
Of course, this didn't happen overnight, it's taken some years to develop it to the present pitch and I know that Rupert won't even think about how much it's cost!
Engine
Based on DR Big Single Cylinder Four-Stroke
Capacity
741cc
Valves
4-Radial
Spark Plugs
3
Camshafts
Twin, Conical, External Belt Driven
Carburation
Downdraught Electronic Fuel-Injection
Power
94bhp @ 8100rpm
Chassis
Aero-Space Quality Tube And Plate Steel Frame
Italian Supermono Championship, wins Constructor Championship and Title, racer M. Lucchiari
Were are you from and what sort of bike do you ride
MCmad screwed with this post 08-12-2008 at 04:37 AM
Old 08-12-2008, 04:58 AM   #74
Manos
Oddometer: 17
Hi and thanks for the info. Not much available on the net Iím afraid.
Yes, Iíve been a member for quite some time now but havenít posted for various reasons, which I donít think are important or interesting enough for publishing. Thanks for the welcoming note.
Iím from Athens, Greece and I ride a Honda CB1300.
I also have an NX650 Dominator which is presently in pieces and will be heavily modified. This is part project and part experiment.
Thanks again
Manos
Old 08-12-2008, 06:03 AM   #75
bluesman
Oddometer: 3,330
I think if remember right they also got rid of balancer shafts too.
That's what I read on Inet about it. They also mentioned that attempt to use aftermarket cranckshaft was failure (aftermarket or self-made item could not survive race) and they came back to original cranckhaft which suprisinly had no probems or failures.
There is still Turbo as an variant of boosting power.
Times are GMT -7.   It's 09:05 PM.
