Old 08-18-2008, 07:08 PM   #1
Gimmeslack OP
furthur
Gimmeslack's Avatar
Oddometer: 2,508
airheads and water crossings.
With my D/S thumper, I can pretty much go as deep as the airbox or exhaust pipe. That started me wondering about airheads which seem to have lots of "holes" considerably lower. Can I dunk my G/S or will I regret it? How deep is deep?
"If you hold a cat by the tail, you learn things you cannot learn any other way."
Twain
Gimmeslack is offline   Reply With Quote
Old 08-18-2008, 07:52 PM   #2
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,651
I've had my R75/6 up past my ankles.
My dad claims to have had his R75/5 up to the tank(!), but his memory might be a bit fuzzy.
crazydrummerdude is offline   Reply With Quote
Old 08-18-2008, 08:49 PM   #3
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,646
I've been wondering the same thing. The electrics are high up and the breather for the final drive can have a snorkel fitted but I have slots in the my front cover, I'm assuming to allow some air out of the alternator for cooling? There's the speedo cable, and the hole on the left side where you can see the fly wheel. Can those be plugged safely? The place I usually go offroading at has two creeks I have to cross or my riding area is very limited. I remember having water almost to my knees on my KLR when crossing them, I'd hate to have to avoid things like that on the G/S.
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is online now   Reply With Quote
Old 08-18-2008, 11:53 PM   #4
AliBaba
AliBaba's Avatar
Oddometer: 375
If plug cables are healthy the engine will run as long as the airintake is above water.
The electronics behind the front cover seems to work fine, but the gen-light often starts to flicker when the alternator gets to wet (no worries).
I think the clutch is the worst problem, the clutch housing gets full of water and if you use the clutch (esp going uphill) it might start to slip.
It might be smart to find another way to vent the gearbox and final drive,
but itís not strictly necessary if you check/change the oil pretty soon.
When you drive in salt water you should clean your bike asap, corrosion starts fast (cables, bearings, leverage, electronics ++)
AliBaba is online now   Reply With Quote
Old 08-20-2008, 10:11 AM   #5
bikerlt
Oddometer: 60
I destroyed the output shaft on my '83 R65 with injudicious use of a pressure washer. I figured I knew well enough what to avoid, bearings, electrical, instruments, etc. I didn't know enough about boxers tho. I got too much spray up under the engine and into to clutch and splines and stripped the lube out of the spline. About 5k later I was left stranded on the road. It was an expensive repair and now I know much better. New bikes must have fixed this weak spot, but I'd be wary of dunking this part of the bike on any model like mine.
bikerlt is offline   Reply With Quote
Old 08-20-2008, 10:55 AM   #6
Gimmeslack OP
furthur
Gimmeslack's Avatar
Oddometer: 2,508
Originally Posted by AliBaba
What fairing is that? And I might as well ask what bike (G/S or GS)?
Twain
Old 08-20-2008, 10:58 AM   #7
Gimmeslack OP
furthur
Gimmeslack's Avatar
Oddometer: 2,508
My G/S which lead to this question is essentially the same as your 83 as far as "achile's heels" goes.
Did you get that much water in the speedo boot/hole? Or where? I.e. what do you mean "under the engine"?
Twain
Old 08-20-2008, 12:10 PM   #8
bmwblake
upside down parker
bmwblake's Avatar
Oddometer: 3,274
i'm having a really hard time figuring out how you got a pressure washer to ruin your output shaft. care to elaborate?
bmwblake is offline   Reply With Quote
Old 08-20-2008, 02:12 PM   #9
P B G
Oddometer: 10,001
Pressure washers are for driveways, bilges, decks, and stucco.
They really do push water where it shouldn't be, the clutch is an odd one, I don't think I could get significant water to strip the lube out of there.
Old 08-20-2008, 04:27 PM   #10
camgregus
riding gently now
camgregus's Avatar
Location: on the banks of the mighty mississippi, AR side
Oddometer: 3,010
care to elaborate?[/QUOTE]
no boot?
got to get it on the good foot
camgregus is offline   Reply With Quote
Old 08-20-2008, 04:54 PM   #11
Frank Warner
Traveller
Frank Warner's Avatar
Oddometer: 6,593
A problem area is the carby breathing/drain hole .. it is on the bottom of the float bowel.. if that is block by water long enough (say 50 - 100 metres) than it drags water into the float bowel and the bike trys to run on water rather than petrol. HPN/Tortech (sp?) offer a solution .. pricy but if you want to run submerged ...
Water into the final drive and gear box won't stop the bike running .. you can later drain off the water .. let it settle and than drain untill oil starts to come out.
As noted above - water on the clutch can be a problem .. as it is for 4WDs (manuals). Don't use the clutch while submerged and you won't have a problem. Use it once and it should not do too much harm, the more you use it the more problem (slipping) you will have.
Water into the alternator/ignition bean can area is not a problem. Nor should it be a problem with eht electics - they should be sealed ...
Frank Warner is offline   Reply With Quote
Old 08-20-2008, 05:39 PM   #12
postaldave
gone postal
postaldave's Avatar
Oddometer: 796
on my toaster i had it shut down due to water under the charging cover in the front. i pulled it off, water rushed out and then it started and was on my way.
imo: airheads don't like water.
postaldave.com
5united.net
facebook.com/slash5
1972 BMW R75/5 toaster
1995 BMW GS 1100
2001 yamaha kodiak 400
2002 HONDA VFR interceptor
no one is promised a tomorrow but one more ride would be nice.
postaldave is offline   Reply With Quote
Old 08-20-2008, 11:25 PM   #13
AliBaba
AliBaba's Avatar
Oddometer: 375
Itís originally a GS Basic (last airhead build in Europe) which was converted to a Kalahari (upper pic). Itís now converted to a HPN Rallyesport (lower pic).
The fairing fits both a standard GS and G/S with a HPN-tank.
Old 08-20-2008, 11:37 PM   #14
AliBaba
AliBaba's Avatar
Oddometer: 375
Itís 13.50Ä from HPN, but I guess you can make it yourself
I havenít tried it but I guess a ceramic clutch like this will work better.
Old 08-21-2008, 09:54 AM   #15
bmwblake
upside down parker
bmwblake's Avatar
Oddometer: 3,274
yeah, i dont use one on my bike, but i was trying to figure out how he could get the lube off the clutch splines with one. i'm guessing that's a WAG for an explaination on why his splines failed.
Times are GMT -7.   It's 08:58 AM.
