Old 09-27-2008, 08:28 PM   #1
PackMule OP
love what you do
PackMule's Avatar
Oddometer: 19,441
Question The 800GS tire thread (oh, no you di-'nt!)
Discuss.
Wheel Specs:
Rim, front 2.15 x 21"
Rim, rear 4.25 x 17"
Tyres, front 90/90 - 21 54V
Tyres, rear 150/70 - 17 69V
I'm wondering if anyone has yet fitted a 130 width rear to the 800 yet. There are substantially more (and cheaper) knobby options in the 130 vs the 150. With a 4.25" rim, that may be stretching it a bit (literally), though?
Also, what are the implications of changing tire sizes WRT the ABS system?
Nate in N.E.
Yes, I have a Dakar problem -- that there are 50 weeks of the year without Dakar!
They don't expect you to finish. That's why it's the Dakar. -- PPiA
Get your sweet Pyndon DakARTwork here
Pyndon '13
PackMule is offline   Reply With Quote
Old 09-28-2008, 10:47 AM   #2
zaner32
In over my head
zaner32's Avatar
Oddometer: 620
Glad you asked the question
I think anything skinnier than a 140 will be a problem. loooking at the microfiche on Max BMW website indicates the 800GS as having a wider rim than the R1200GS, but they share the same size tire.
It would be nice to be able to fit a Pirelli MT-21 or a Dunlop D606. My experience is both of these tires are not that great at highway speed though.
For the riding i'll be doing with the f800, the Conti TKC-80 will more than likely work ok. But there'll always be the time I wished I had a better knobby.
F800GS 4.25" X 17"
Rear wheel assembly:
36314644852 spoke wheel, rear (4.25X17)
R1200GS 4.00" X 17"
Rear spoke rim only:
36312320005
wheel rim rear (4,00X17 MT H2)
XCountry 3.00" X 17"
Rear rim only:
36317696784 wheel rim rear (3,00X17)
I'm not worried about ABS b/c mine was ordered without it.
Woody's will more than likely have a solution for people that are interested.
97 DR350SE
09 F800GS
"When nothing goes right, go left!
zaner32 is offline   Reply With Quote
Old 09-28-2008, 12:10 PM   #3
Motoriley
Even my posing is virtual
Motoriley's Avatar
Oddometer: 2,513
Tires
Street tire options.
They make an ME880 in 90/90-21 for road trips.....
Lazers are available for fr and rear
04 Toyota Sienna, new wipers for 2011!!
Electricity (120 AC), Indoor Plumbing, new kitchen tap for 2010!!!
Color tube TV, Microwave Oven (yes she rotates!),Washer & Dryer,Paved Driveway,
Website - http://www.apormc.com/
Vids - http://www.youtube.com/user/Motoriley?feature=mhum
Motoriley is offline   Reply With Quote
Old 09-28-2008, 02:14 PM   #4
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 987
I'm just going through the websites to find tires that may work.
Metzler Karoos
Michelin Deserts
Dunlop D606
Conti TKC80
Unfortuneately these seem to be R rated tires.
David
'07 VFR800, '09 F800GS, 07 CRF250X
Riding roads in Montana - Big Sky Country
www.mtrider16.smugmug.com
Alaska Trip Report
MTrider16 is offline   Reply With Quote
Old 09-28-2008, 02:53 PM   #5
Motoriley
Motoriley's Avatar
Oddometer: 2,513
R rated
How often do you cruise over 106 mph with knobbies?
Metzler Karoos
Michelin Deserts
Dunlop D606
Conti TKC80
David
Old 09-28-2008, 05:46 PM   #6
zaner32
In over my head
zaner32's Avatar
Oddometer: 620
Front D606
Front D606 at 120 Km/h on the front of the KLR was a bit scary. It would wander side to side in an oscillating motion. Could have been the pressure I had them pumped up to (32PSI), or it could have been suspension geometry, but I don't recall it doing that with ony other tire (Dunlop 950, Mefo Explorer, or MT 21).
Things could be different on the F800GS though.
A quick search the other day on Karoos, kinda let me down. The consensus is that they wear quite fast.
How's about using a knobby on the front ie: MT21, D606, or other, and a 50/50 tire on the rear (Tourance, Anakee)? I don't care too much if the rear moves around on gravel, or hard pack, but it's a pain when the front doesn't stay planted. Me thinks that both would wear out at about the same mileage.
97 DR350SE
09 F800GS
Old 09-28-2008, 06:00 PM   #7
Motoriley
Motoriley's Avatar
Oddometer: 2,513
606s
My last KLR had 606s on it when I sold it. Never noticed any weirdness at highway speeds. Of course the KLR always felt less than rock solid at 120. What I really didn't like was the TKC80 front I ran for a while. Felt good on road but I never really liked it on gravel.
Old 09-28-2008, 08:51 PM   #8
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 987
The specs Nate put in the original post said they had are to be V rated. Just following the conversation.
I don't think I would mind having R rated tires myself if they kept the bike planted on gravel roads. I don't run mfg speed rated tires on the VFR.
The idea of more road type rear and knobby front sounds interesting. I had heard someone mention it before.
Just so you don't get what I'm saying wrong, I have very little experience here to draw on. I'm just reading the mfg sites and repeating what I've heard others say.
David
Alaska Trip Report
Old 09-28-2008, 10:08 PM   #9
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 987
Here is the tire sizing information page from Dennis Kirk Catolog Company.
http://www.denniskirk.com/jsp/tpl/ti...izeexplain.jsp
This helps a little with Nate's original question:
I don't think they would recommend 130 on a 4.25" rim.
David
Alaska Trip Report
Old 09-29-2008, 03:39 AM   #10
zaner32
In over my head
zaner32's Avatar
Oddometer: 620
Thanks, this has good info. Added this link to my favorites.
97 DR350SE
09 F800GS
Old 09-30-2008, 11:08 PM   #11
Keystone
Oddometer: 201
Not sure about tires, but the manual is pretty emphatic about wheel sizes.
It says the wheel size is programmed into the ABS system and that "in some cases the data in the control unit can be adapted to the new wheel sizes."
I suspect you'd potentially have similar issues if you switched to a tire with a markedly different diameter than stock, in that the ABS system would see a different "in sync" front-to-back rotation ratio than it is expecting to see in normal tire wear range.
Cheers,
Tom
'09 F800GS (Yellow)
'05 F650GS (Sold)
'04 K1200RS (Sold)
'03 F650GS (Crashed)
(formerly hyperiate)
http://www.shoottheapex.com
Keystone is offline   Reply With Quote
Old 09-30-2008, 11:14 PM   #12
Keystone
Oddometer: 201
For what it's worth, I'm running a TKC80 on the back and a D908 Rally Raid in the front. I went with this choice because I was looking for a front that would be good on rock, mud, and sand, but wanted a longer-lasting back knobby so they would hopefully wear out about the same time.
I had read about weak sidewalls on the TKC80 which also led me to try the 908rr. I've had it out the day after an all-day rain and ran it through sand, mud puddles, and rocks and they performed just great.
I'm not exactly an A class rider though, so my experience may not be worth much.
Cheers,
Tom
'09 F800GS (Yellow)
'05 F650GS (Sold)
'04 K1200RS (Sold)
Old 09-30-2008, 11:29 PM   #13
atgreg
Africatwinarama
atgreg's Avatar
Oddometer: 9,761
give Mitas E07's a try, great universals or for something more knobby try the E09's. They both come in 140/80 x 17 and 90/90 x21. I run them on my AT and love em.
1990 RD04 Africa twin 750
350,000km and still going strong
atgreg is offline   Reply With Quote
Old 10-01-2008, 02:35 AM   #14
mrpete64
Oddometer: 546
Avons?
Does Avon make a tire that will fit the new GS's?
Mr. Pete--->
mrpete64 is offline   Reply With Quote
Old 10-04-2008, 11:59 AM   #15
Wolweseun
Oddometer: 23
I have a Michelin T63 on the front and a Heidenhau 140/80-17 K60 on the back
Works great done roughly 4500Kms with them
I still want to try a more agressive Knobbly on the back
Wolweseun is offline   Reply With Quote
Times are GMT -7.   It's 03:07 PM.
