Old 10-04-2008, 08:56 PM   #1
itsatdm OP
itsatdm's Avatar
Oddometer: 4,858
F800GS Toolkit needs
The 800 fasteners are just about all Torx vs hex or Allenhead.
So to work on the bike you need the following:
Torx T10 left control housing
T20 throttle assembly
T25 fairings, control, body work
T30 muffler mount, signals, motor chassis, rotor
T40 triple clamp, brake pivot, rear rotor, brake line
T45 body, exhaust mount, fork axle pinch bolts, controls
T55 Bar Ends
Torx socket
E10 handlebar clamps
E12 Front Caliper brakes
Wrench
13mm Chain tension sprocket
17 mm Front Axle
24mm Rear axle
24mm Drain plug.
PackMule screwed with this post 10-16-2008 at 01:22 PM Reason: Corrected rear axle size (24mm)
itsatdm is online now   Reply With Quote
Times are GMT -7.   It's 05:08 PM.
