Thread Tools | Rate Thread | Display Modes |
11-23-2008, 05:00 PM
#1 |
Raoul Duke Lives
Oddometer: 18,824
more in the Mutt is a dope series of dumb questions - the Volkswagen Thing chronicles
you know those questions that you know are going to make you look stupid when you get the answer and it was staring you in the face
well I am about to look mechanically inept, if not outright dumb first I mount the VW on this stand which means you can't check the valves or set it to TDC because the flywheel is bolted to the stand ![]() fine I get most of it put together then I order one of these ![]() but my work benches wont support the weight so I weld that motherfucker to my regular engine stand (ignore the super sloppy welds, I am new at that too) ![]() so now I am feeling all clever and shit which is how I usually know I am in trouble well dammit once you wrestle the goddamn engine supprt on to the motor mount stud (which comes damn close to mangling the threads because the support is so far out of spec) ![]() the threads do not go all the way down the stud so how in the hell do you get the sucker securely mounted? ![]() and don't even begin to ask me what a pain in the ass cleaning the damn oil screen was because someone did have enough threads out on one of the bolts so I ordered the special wrench from Bernzomatic/Grinder industries to fix that ![]() so how do I secure that damn motor without breaking a stud since the threads don't go all the way down and by loosening up a oil screen bolt with new spiffy single purpose special 10mm wrench cranking the oil screen bolt down from outside the case how long before it works loose from the inside and frags the whole fucking motor
"Life is as good as you let it be" - Chain "well . . . it ain't for everybody" - Goonie |
11-23-2008, 05:04 PM
#2 |
Hanging on
Oddometer: 14,665
Spacer cut out of tubing, washers welded to each end?
11-23-2008, 05:05 PM
#3 | |
adventure imposter
Oddometer: 14,891
You sir, are an idiot.
ImaPoser Save $5 when you open your own smugmug account. Use code: DeAGMxYPTdjUA Quote:
11-23-2008, 05:06 PM
#4 |
Woolf Barnato
Oddometer: 29,324
Do you have something that could act like a spacer? Like a piece of pipe or a deep socket or a hunk of petrified shit. Maybe a couple nuts that have a larger i.d. than the stud?
Or maybe you're using it upside-down?
'Gonna get me a six pack...push people off the highway!' "they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood." "I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!" "Yeah, that guy sure is terrible at touching moms" |
11-23-2008, 05:07 PM
#5 | |
Easily trainable
When in doubt bush it out.
Or you could get a tap n die set and MAKE the threads go all the way down the rod.... Oh, and is there a locktite product that'll work in oily environs?
11-23-2008, 05:08 PM
#6 |
Oddometer: 1,036
IIRC, there isn't enough room for a stack of washers between the flywheel and the studs. If you've got some tubing of the correct diameter that'll work. Gotta hacksaw? If you don't have the right tubing, then I'd use some 3/8s sockets. Deep sockets would be the ticket but a coupla regular length sockets will do. I would SUGGEST you choose sockets you aren't going to need for the upcoming fun and games...
11-23-2008, 05:09 PM
#7 |
Under Da Sea
You don't need a question to make you look dumb, Puppethead.
I've got stay the fuck out of it written on a stone tablet in my bedroom. - Con Stapleton
11-23-2008, 05:11 PM
#8 |
Raoul Duke Lives
Oddometer: 18,824
got nothing no tubing of the right diameter
kicked my mess of garage apart looking for something of course maybe I was a little fucked up from breathing flux cored welding wire in an enclosed garage for a while on a positive note that hobart welder is badass
11-23-2008, 05:13 PM
#9 |
Woolf Barnato
Oddometer: 29,324
Look at the way the engine will load those studs if it's mounted that way. It will probably break two chunks out of the crankcase and we will see a "I dropped a VW engine on my foot call 911" thread.
#10 | |
Raoul Duke Lives
Oddometer: 18,824
do you even have a car any more 'cause there may be a dilapidated shitbox sale around here soon if this shit doesn't start going right
#11 | |
Idiot Royalty.
you should change out those studs anyway.
![]() just pull them out and use a bolt until you go to mount the mill.
11-23-2008, 05:15 PM
#12 |
prominent underachiever
I have a rolling engine stand for my VW motor
2011 Magadan (I hope!) (03 Harley 1200 Dirtster) 2010 Europe & the Middle East (75 Harley Bobber) 2009 Around the World ('62 Harley Chopper) 2008 Europe (TDM & Guzzi Falcone) 2007 Europe (TDM850) 2006 Around the World ('48 Indian Chief) 2005 Europe & N Africa (KLR650) 2004 Europe (KLR650) www.motosapiens.org My bike hotel in Bulgaria. ADVriders get 1st beer free! |
#13 | |
Raoul Duke Lives
Oddometer: 18,824
I was gonna put the mount flush and the spacer behind the mount there has to something obvious I am missing here which is usually the case
11-23-2008, 05:17 PM
#14 | |
Raoul Duke Lives
Oddometer: 18,824
still, and I mean still , waiting on my fucking parts from my painter before I start back on my R100I owe Kbasa a good bottle of hooch I have yet to to send, but mailing stuff out months late is SOP for me
#15 |
Accredited Jackass
Oddometer: 43,003
Mutt, after all the electro/mechanical fuckups you've had, I can say with confidence that you are fully qualified to be one of my officers.
For Christ's sakes man, quit trying to be a wrench.
Life is not measured by the number of breaths we take, but by those moments that take our breath away. George Carlin |
| Thread Tools | |
