Old 01-03-2009, 10:14 PM   #1
chunter OP
chunter's Avatar
Oddometer: 41
My F800gs STALLS LIKE ITS RUNNING OUT OF GAS! PLEASE HELP!!
Hi Everyone,
I have a new F800gs that now has 350 miles on it. I have been having an issue with it stalling for the last few days. The first time it happened, my display showed about 65 miles range remaining, and it happened at low RPM. I started it back up and made my way to a gas station. On the way there, it cut out about 10 more times at various speeds and RPMs. When I got to the gas station, I put 2.5 gallons into it (full), and after a few minutes, it ran fine. No further issues.
Puzzled by this, I drained the tank down (with a pump) nearly to the point of the light coming on. It ran with no issues for about 20 miles.
I wondered if there may have been a clog in the air-inlet to the gas tank or something. I filled the tank back up, and did some more riding. I emailed the dealership to ask if there were any software updates or open items for my bike, and they said there were not. He said that I should try opening the gas tank if it happens again because there may be negative pressure there.
Today, when the tank got back down to about 65 miles range (again), the bike sputtered out (again). It had run perfectly for the entire tank of gas until that point. I opened the gas cap, closed it, and started it up again. The bike did run for about 3 miles but then had the same issue. From that point on, it didn't matter how much I opened the gas tank, it made no difference. I filled the tank back up to the top (3.2 gallons), and have run another 50 miles since then with no issues.
Does anyone have any idea what could be going on? I am skeptical about the vent tube to the gas tank being the issue because wouldn't opening the gas tank solve that? If that were the issue, would it run perfectly until the tank got down to 65 miles range? Please give me your thoughts.
Aloha,
Charlie
chunter is offline   Reply With Quote
Old 01-04-2009, 02:10 AM   #2
Bigem
Bigem's Avatar
Oddometer: 2,366
If its at the point where it plays up at the moment, take it for a ride with the tank "open" but taped over. So it should not play up if the breather is actually blocked, but, I thought they where a pressurised system?
It could be that the valve in the cap has failed and does not allow the tank to adequately pressurise when the fuel quantity gets low. I could be completely off track but it might be worth a go? Sounds very odd. Best of luck and keep us posted when you find out what is causing it.
"I'm a thousand miles from nowhere,
Time don't matter to me,
Cause I'm a thousand miles from nowhere,
And there's no place I'd rather be!!
Bigem is offline   Reply With Quote
Old 01-04-2009, 08:03 AM   #3
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,297
one of the reasons to buy a new bike is because of the warranty.
Take it back. Document everything.... twice
Robert
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 01-04-2009, 08:22 AM   #4
One Eye Mike
One Eye Mike's Avatar
Oddometer: 653
Mine has done this as well as eveyone I know who bought one before it snowed. To date, I have not heard the reason why.
One Eye Mike is offline   Reply With Quote
Old 01-04-2009, 09:00 AM   #5
cisco
old fat guy
cisco's Avatar
Oddometer: 270
Pissed Same here
Mine did this on the way to my 600 mi. service. I road it from Flagstaff to Tucson with one stop for gas. As I got close to Tucson the traffic slowed for the construction. The engine died as if I shut it off,Would not re-lite with the tire turning at 60mph in the fast lane. I pulled over and it restarted in neutral. This happened one more time on the freeway, and again at the exit. Then at every stop lite on the way to the shop. It finely would not restart. I got a free ride on a tow truck to the dealer that was waiting for me to show up after hours.They found me a room for the night( thanks John). The next a.m. I went to the shop,my bike was on the work stand. After completing the service the tech started in on the stalling. NO codes. They let the the bike sit running until the fan came on, it ran and ran. The tech went on a short ride, still running fine. They let it run an other 30 min. , Finally it stalls! The whole shop started to cheer. Ok lets bypass the charcoal canister. Restart.... runs fine, " this must be the problem", no sooner did he say that the thing dies. OK maybe that wasn't it. Let's check the relays. This one doesn't sound right. Change the relay, runs and runs.Cool I can make it back to Flagstaff before the snow sticks. It dies again. Only thing left is the fuel pump, not in stock. The dealer sets me up with a scooter to get home( thanks again John) and I got there just as the snow starts to stick.That was three weeks ago, and still no fuel pump. The service manager informed me on Friday that BMW has the pump on back order! with 40 inches of snow on the ground and more on the way it's not urgent, but what if I was traveling. The only thing the dealer can do is diagnose the problem and order parts. It seems that BMW keeps hamstringing their dealers, first the delay from March to Sept. now not backing them with parts. I got rid of a 950 Adv. because of this kind of BS. I hope this is the end and not the beginning.
Cisco
cisco screwed with this post 01-04-2009 at 09:02 AM Reason: spelling
cisco is offline   Reply With Quote
Old 01-04-2009, 09:11 AM   #6
chunter OP
chunter's Avatar
Oddometer: 41
Cisco
Thanks Cisco,
Would yours run normally on a full tank of gas? If it were the fuel pump, would the fuel level matter?
I hope to hell that my local dealer can fix the problem. They don't get many of these bikes out here. I want to go armed with a list of possible causes to the issue.
Aloha,
Charlie
Old 01-04-2009, 09:12 AM   #7
chunter OP
chunter's Avatar
Oddometer: 41
Robert
Thanks Robert. I'll follow that advice.
Aloha,
Charlie
Old 01-04-2009, 09:36 AM   #8
cisco
old fat guy
cisco's Avatar
Oddometer: 270
Originally Posted by chunter
Thanks Cisco,
Aloha,
Charlie
The bike ran flawlessly up until the first stall. The tank was low.
Cisco
Old 01-04-2009, 01:22 PM   #9
Bayner
Oddometer: 1,237
Obviously this is just a guess, but I had a similar fault on a car in my shop once ... In that case the intake for the fuel pump had become detached from the pump. I don't know how your pump is positioned, but most FI pumps have a screen/filter on the intake side that sits at the lowest point in the tank. If the pump and strainer became separated, you could have fuel in the tank but it would not be drawn up because the pump is sucking air as it sits slightly higher in the tank. Obviously if this is the case, the symptoms will repeat at the same fuel level every time.
If it were a venting issue you could run with a low fuel level and the cap off and be fine...
From a diagnostic point of view, I'd be looking into whether it looses spark, fuel pressure or injector pulse when it dies, or perhaps some combination, but you'd be best to let the dealer sort it out I think. If their answers seem vague then try to takle it yourself.
Bayner is offline   Reply With Quote
Old 01-04-2009, 06:54 PM   #10
cisco
old fat guy
cisco's Avatar
Oddometer: 270
charcoal canister.
Thanks for your help everyone. I believe I have corrected the problem. It was with the charcoal canister. As per another post elsewhere, I just plugged both of the fittings on the canister (so that dirt won't get in there), put a filter on the vent-tube to the tank, plugged the other tube that was connected to the canister, and I'm good to go! It will be easy to put back if I decide to have the dealership fix it, but frankly, the canister seems like a failure point that doesn't really add anything.
Thank you everyone for your help. I will check in after a few tanks of gas for a final confirmation that this was a cure.
Aloha,
Charlie
The first thing the dealer did was to bypass the canister on my bike and it made no difference. I asked the tech if there was a fuel filter and he said that he did not know. The common thing here is the low fuel levels. I have taken mine to the warning lite. The level was above it when it stalled.
Cisco
Old 01-04-2009, 08:16 PM   #11
chunter OP
chunter's Avatar
Oddometer: 41
Cisco
Yeah, mine was well above the warning light when it happened.
Another 20 miles with no issues...keep your fingers crossed.
Old 01-04-2009, 10:09 PM   #12
tmex
tmex's Avatar
Oddometer: 2,039
Interesting. I wonder if altitude or barometric pressure changes are somehow fooling the FI system and leaning the bike out to the point of stalling. It would be prudent to get the latest firmware version installed. I have heard lots of reports about bikes stalling in rain which usually occurs in conjunction with low barometric pressure.
That explanation fails to explain the correlation of the problem with fuel level, but perhaps there is some tie in that is not obvious. It would seem unlikely that it is a cannister problem, but certainly possible. Cisco, are you sure the tech by-passed the cannister properly? Did you see him do it?
my favorite bike - R1200GS
tmex is offline   Reply With Quote
Old 01-04-2009, 11:38 PM   #13
bxr140
Flame Bait
bxr140's Avatar
Oddometer: 937
Stupid question, but did you verify that it wasn't a faulty fuel light? Like...how many miles were on the tanks when the bike started acting wonky?
FWIW, I'm of the opinion that you didn't actually "correct the problem"...
bxr140 is offline   Reply With Quote
Old 01-05-2009, 05:07 AM   #14
cisco
old fat guy
cisco's Avatar
Oddometer: 270
The tech pinched off a hose under the seat (vac?). The bike had the latest specs. It would die as if I cut off the switch, no stumble just off.
Cisco
Old 01-05-2009, 06:55 AM   #15
One Eye Mike
Oddometer: 653
Mine would cut out regardless of fuel level. I would be riding along under acceleration and the bike bike would just die. Pull in the clutch, hit the starter, and she fires right back up. Would be deadly going into a corner on a wet road, however.................. I've got 950 miles on my 800, and in that time it's cut out at least 5-6 times, all at different speeds / altitudes.
My riding partner has had the same problem. Dealer has no answers.
Times are GMT -7.   It's 07:55 PM.
