Old 01-29-2009, 04:31 PM   #1
gary138 OP
Oddometer: 98
F800 GS chain
Hi, What is the 800 gs chain size?? I would like to bring a spare for one i'm renting. What brand does BMW use ?? Would a DID work ??? I have a 520 and 525 hanging around
Gary P
04 V-Strom 1000 42K, ,01 KLR650 24K,04 H-D Road King 8K
Sold but not forgotten 98 concours 110K
gary138 is offline   Reply With Quote
Old 01-29-2009, 06:50 PM   #2
jessehere
Ridin'
jessehere's Avatar
Oddometer: 782
525 116 links , bmw use a cz chain. DID x ring
jessehere is offline   Reply With Quote
Old 01-29-2009, 11:09 PM   #3
tedder
irregular
tedder's Avatar
Oddometer: 8,797
how long are you renting it for? the odds of it failing are slim. Are you carrying all the other, more likely spare parts too?
tedder is offline   Reply With Quote
Old 01-30-2009, 03:36 AM   #4
Schlug
JockeyfullofBourbon
Schlug's Avatar
Oddometer: 7,444
two things:
+1 on the likelyhood of that chain failing. it's so rare... it'd be like carrying a spare rear wheel. unless of course you're attempting to put 10k miles on her. if you're REALLY that worried, carrying some extra links and a chain tool would be the most i'd go.
+1 on the DID x-ring. good for 15k. most excellent chain.
"So what makes this protest different is that you're set to die, Bobby?"
--May well come to that.
"You start a hunger strike to protest for what you believe in. You don't start already determined to die or am I missing somethin' here?"
-- It's in their hands. Our message is clear. They're seeing our determination.
Schlug is offline   Reply With Quote
Old 01-30-2009, 04:20 AM   #5
Magile
"What exit?"
Magile's Avatar
Oddometer: 479
You must have heard about the chain/sprocket failure & recall. If you can get the VIN of the rental bike, any BMW dealer can check to see if it's in the effected group.
See -http://www-odi.nhtsa.dot.gov/recalls...rue&refurl=rss
Where ya riding to?
Cheers - M.
Magile is offline   Reply With Quote
Old 01-30-2009, 03:33 PM   #6
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
Question
So this D.I.D. 525 VM2 Gold X-Ring Sealed (116 links) would work?
http://www.sprocketcenter.com/p/1037...led-chain.html
Old 01-30-2009, 03:42 PM   #7
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
Originally Posted by Monkey_Boy
WTF is with BMW anyway? I mean, are the simply unable to build a final drive system that's reliable? Shaft or chain. What boneheads.
The BMW F800GS chain drive has proven flawless so far. The few (and I mean 1 or 2) cases of failure on the F800GS are from bad chain maintenance (user error). i.e. loose chain, which caused the chain to jump on the sprocket. This would tear apart a chain on any bike.
The V-Stroms have just as many problems as the BMW's as the KTM's as the Kawasaki's........
On the DL650 and DL1000 I've heard of the ABS failing, Swingarms not lubed from the factory, Fuel Injection/Engine Management problems, etc. No different than any other bike.
A lot of us just choose a BMW F800GS because they ship with higher quality parts (better suspension - Sachs and Marzocchi, Rotax engine, Brembo brakes, better ground clearance, etc.), are far more reliable, and they're more fun to ride and more capable than a V-Strom!!
The Griz screwed with this post 01-30-2009 at 03:58 PM
Old 02-02-2009, 10:22 AM   #8
gary138 OP
Oddometer: 98
chain
Originally Posted by BobbySands
two things:
That's all I plan on taking... I'm not sure how many miles are on the rental or how well it's been taken care of, I did let them know I will be putting 5k miles on it. Did I forget to mention that I'll be in remote areas of South Africa??
And what other spares do you think I should take besides tire tubes ? When I travel on my bikes afar I take throttle/brake cables, all sensors that do not have a fail-safe mode etc. BUT I don't want to buy all kinds of thing for a bike I don't even own..
Gary P
Times are GMT -7.   It's 08:24 AM.
