Old 10-03-2008, 03:09 AM   #1
J C OP
J C's Avatar
Oddometer: 9
1200GSA fog lights harness on 1200GS
Hi, I'm planning to add fog lights on my standard 1200GS 05, mounted on the hepco tank crash bar (Adventure like), for this I got the complete OEM fog lights harness (relay, fuse, switch, cables, connectors) coming from a 1200GSA 06.
Could somebody help me with the following:
-What are the original locations/mountings for relay and fuse box and wires on the bike ? (a couple of pictures would help a lot).
-I've identified a 4 pins connector as the "entry point" of the OEM fog lights harness, I'm now missing where to connect on the bike principal harness, again a picture would help.
Thank you foryour help.
Cheers
J C
J C is offline   Reply With Quote
Old 10-03-2008, 06:45 AM   #2
Reverse
Armchair Tough
Reverse's Avatar
Oddometer: 1,262
On a GS Adventure, the fuse box is located on the right front side of the fuel tank, under the black cover. There's a picture of it somewhere on the forum.
Can't help you with the relay and harness.
Found a pic:
2007 R1200 GS Adventure
Reverse is offline   Reply With Quote
Old 10-03-2008, 11:25 AM   #3
J C OP
J C's Avatar
Oddometer: 9
Hi Reverse, thanks for the pic , so I'm still missing relay location and the connection access to the main harness...Would be great if somebody could further help!
Old 04-03-2009, 03:58 PM   #4
J C OP
J C's Avatar
Oddometer: 9
So, I finally completed the mounting of the fog lights using BMW OEM stuff only (switch/harness/fog lights) from the Adventure on my standard 12GS.
Here are some pics:
-Fog light mounting details:
-Switch integrated:
-Overall view of my "Adventurized" 12GS:
Old 04-03-2009, 09:42 PM   #5
AherreraGS
Oddometer: 53
Getting the wire harness
Where did you get te wire harnes for this I am interested in doing the same to my bike
AherreraGS is offline   Reply With Quote
Old 04-03-2009, 11:15 PM   #6
rookierider
Oddometer: 22
Lcd?
What is that device on the windshield? Never seen that??? Please share. Thanks.
rookierider is offline   Reply With Quote
Old 04-04-2009, 12:43 AM   #7
J C OP
J C's Avatar
Oddometer: 9
AherreraGS: you can buy the harness from your BMW dealer, it is far from being cheap...
05 61127699826 wiring harness, auxiliary driving light BUY 1 $152.20
I've got a used one from ebay at much better price, but then you need to be patient, it is not a quick hunting.
Note that on my 05 GS, this harness do not plug straight into the bike main harness, you will have to connect the +/- power wires (feeding the relay contacts and the fog lights) to the battery, while the +/- command wires (feeding the switch and the relay coil) can be connected to the rear light to benefit from the CAN bus when switching on/off the bike.
May be the more recent GS's are already equipped with the right plug to directly coonect the fog light harness, to be checked...
rookierider: this is a LCD clock/thermometer which is powered by 12V for the temp. and gets light for night driving, a tiny battery is keeping the clock running while the ignition is switched off on the bike. I just replaced the original green lighting by an amber/orange one to match the light color from the main dashboard.
J C screwed with this post 04-04-2009 at 01:04 AM
Old 04-10-2009, 04:52 AM   #8
802mike
802mike's Avatar
Oddometer: 416
Anyone know if there is a plug on the newer bikes for this?
802mike screwed with this post 04-11-2009 at 04:13 AM
802mike is offline   Reply With Quote
Times are GMT -7.   It's 05:53 AM.
