Old 03-28-2009, 02:42 PM   #16
The Griz OP
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
Originally Posted by rockinrog
I have a Recall/campaign for Chain Sprocket fasteners sent to me by BMW.
Must be a 2008 MODEL YEAR bike then. I promise, I just called my dealer and gave them my VIN. The only recall bulletin out for my 2009 MODEL YEAR was a coolant hose clamp. Check the tenth number in your VIN. If it's an 8, you have a 2008 MODEL YEAR bike. That's what we should be paying attention to here: whether it's a 2008 or 2009 MODEL YEAR.
The Griz screwed with this post 03-28-2009 at 02:48 PM
Old 03-28-2009, 02:46 PM   #17
The Griz OP
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
Originally Posted by huckleberry
sproket bolts , discbolts,and caliper bolts too!! i think there was something else also but i didn't get it
Not necessarily on 2009 MODEL YEAR F800GS's. Remember that MODEL YEAR and whether it's an F650GS or and F800GS matters.
Old 03-28-2009, 02:51 PM   #18
rockinrog
rockinrog's Avatar
Oddometer: 2,905
2009
10th number is a 9
rockinrog is offline   Reply With Quote
Old 03-28-2009, 02:58 PM   #19
The Griz OP
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
10th number is a 9
Interesting, there must be a limited number of 2009 MODEL YEARS with this rear sprocket issue. Also, it's good info to know that BMW is capable of singling out a problem with even 1 VIN with their bulletin network and mailings.
Example: They know 10 2009 MODEL YEAR F800GS's left the factory with an issue. They could put out a bulletin or send out a mailing to just those ten owners.
Old 03-30-2009, 12:40 AM   #20
Nemesis
just ride the damn thing
Nemesis's Avatar
Oddometer: 422
You guys crack me up.....
Forget model year, forget 10th digit. The only meaningful indicator of an applicable recall or campaign is the result of a service history VIN inquiry from your dealer, or a letter directly from BMW in the case of a recall.
Darken the door at you dealer's service department occasionally and you will receive the improvements BMW develops for its customer's bikes.
"I can tell you with no ego, this is my finest sword. If on your journey, you should encounter God, God will be cut." - Hattori Hanzo
"Every normal man must be tempted at times to spit upon his hands, hoist the black flag, and begin slitting throats " - H. L. Mencken
Nemesis is offline   Reply With Quote
Old 05-08-2009, 06:20 PM   #21
rockinrog
rockinrog's Avatar
Oddometer: 2,905
3 recalls
I called to make an appointment to get my Chain Sprocket fasteners recall taken care of and was told there were 2 others. Replace radiator hose and reroute ABS sensor.
Old 05-08-2009, 07:38 PM   #22
Roonie
Roonie's Avatar
Oddometer: 389
My VIN shows it is an 09. It is currently at dealer for 600 oil/filter and they replaced the front axle and radiator hose at the same time. My bike came up with those recalls. I have the original manufacturing info and it says my bike was made 9/20/08. It didn't get to the dealer until mid Nov when I took ownership the day it rolled off the truck.
Roonie is offline   Reply With Quote
Times are GMT -7.   It's 10:40 AM.
