Old 05-04-2009, 06:55 PM   #1
giodog2000 OP
Oddometer: 245
F650GS twin front brake issue
Hi all , I had my gs twin for a month now and never liked the feel of my front brake. The problem is not when I make agressive stops , the problem is when I'm slowing down gently to a full stop . When I do that , something doesn't sound or feel right. They squeel alot (that could be normal not sure) but when I'm at the last few feet I feel some vibration (as if somehting isn't straight and the grinding is intense (with the sqeeling). I have a little over 600Miles on it and brakes should be settled by now. Anyone else with a F650GS twin feel this? Is it normal ? Thoughts?
First one out..last one in.
2011 KTM 690 Enduro R
2009 KTM 530 XC-W
giodog2000 is offline   Reply With Quote
Old 05-04-2009, 07:24 PM   #2
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,490
Grinding is not normal. When you take it back in for the 600 mile service, tell them about the brakes.
Old 05-05-2009, 05:43 AM   #3
JRWooden
Oddometer: 4,249
+1
Yeah, I agree something sounds hosed up....
Be sure to point it out, to service tech.
I have 658 and think the brakes are just about perfect.
Old 05-05-2009, 08:26 PM   #4
lrd2sea
Turned orange,...
lrd2sea's Avatar
Oddometer: 46
Your brake probably has probem
I agree with the other responses,
My 650 twin is a bit over 2000 km, the brake works well so far - both straight line, into the bend. I always turn the ABS off.
It never make any noices. Good suggestions for you to have it look at.
lrd2sea is offline   Reply With Quote
Old 05-05-2009, 09:47 PM   #5
Navaho
Navaho's Avatar
Oddometer: 1,042
Did you check all the bolts good? There is a recall on the front brake disc bolts.
'07 450EXC, '06 950 Supermoto, '09 YZ450F
Navaho is offline   Reply With Quote
Old 05-05-2009, 10:48 PM   #6
]I)Money
D NOT I
]I)Money's Avatar
Oddometer: 3,694
caliper bolts, I thought
Originally Posted by wxwax
Yes, but everything you've ever posted in the basement indicates that you're certifiably crazy, so you don't count.
"Another road remains, but it provides no more. It can only take us away"
]I)Money is offline   Reply With Quote
Old 05-05-2009, 11:25 PM   #7
Bike4Fun
Smooth IS Fast
Bike4Fun's Avatar
Oddometer: 1,740
break in! have you truly broken in the pads! my dealer told me to be easy on them in the beginning but to definitely "sinter" the pads! Sinter, what the hell is that... glad you asked.
To cause (metallic powder, for example) to form a coherent mass by heating without melting.
v. intr.
To form a coherent mass by heating without melting.
basically you want to wear through that new brake pad shiat! heat them up and burn them down to get rid of that initial layer!
If you are really feeling griding and not just getting the newnest of the pad, then certainly talk to the dealer. However, IMO you haven't worn the pads enough to smooth things out. Oh and the rotors need some wear too!
Ride the Beatch! Wear her in a little and then report back in!
Bike4Fun is offline   Reply With Quote
Old 05-07-2009, 05:24 PM   #8
JRWooden
Oddometer: 4,249
I first thought it was the caliper bolts also, but on my F658 what was replaced was the bolts that hold the disk to the front rim.
Jim
Old 05-07-2009, 07:05 PM   #9
giodog2000 OP
Oddometer: 245
Sinter
I have about 800miles on it done so far (200 more than last time) , are you saying I should make a few really hard braking on them to burn stuff up..makeem come really hot a few times?
v. intr.
2009 KTM 530 XC-W
Old 05-07-2009, 08:13 PM   #10
Bike4Fun
Smooth IS Fast
Bike4Fun's Avatar
Oddometer: 1,740
yes. that is what my dealer told me. slow break in but at around 600 miles make sure you wear them in with some hard stops.
Old 05-07-2009, 08:41 PM   #11
giodog2000 OP
Oddometer: 245
I'll try that...makes sence. Thanks
2009 KTM 530 XC-W
Old 05-12-2009, 07:01 PM   #12
giodog2000 OP
Oddometer: 245
hard brakes
Well for those of you who have been following , the hard braking did not help . I brought the bike to the dealer today for the 1000km and they will take a look at it. I'll keep you posted on the result in a few days...
2009 KTM 530 XC-W
Old 05-12-2009, 08:15 PM   #13
dsavage
Oddometer: 299
650GS brakes
I have 2,500 miles on mine and have beat the hell out of it going off road in New Mexico and Arizona. No problem with the brakes, just wish I had more on-road stopping power up front. Brakes work great with the ABS turned off.
dsavage is offline   Reply With Quote
Times are GMT -7.   It's 05:43 PM.
