Anyone have the stock skid plate rub through the hard oil lines?
Discussion in 'Dakar champion (950/990)' started by Airhead, Nov 20, 2009.
  1. Airhead
    Airhead More human than human
    Nov 22, 2004
    2,103
    Fear and Loathing in Maine
    Just wondering if anyone had ever actually had the OE plate rub through the hard oil lines that run under the engine. My plate is rubbing on them...enough that they have worn a groove in the plate. I need to replace my skid plate with a Black Dog anyway, since it is cracked...but just curious. It seems like a pretty serious design flaw to me that those lines actually touch the OE plate...:huh
  2. brents347
    brents347 Trusting my Cape...
    Mar 5, 2006
    4,390
    Where the hell is Truckee, CA?
    My bike was the same way when the PO noticed it. Didn't rub all the way through, but definately enough to cause concern.
  3. Airhead
    Nov 22, 2004
    2,103
    Yeah...if you look at almost any 950 with an OE plate the lines show some wear...just wonder if the lines have ever worn through. I think the material out of which the skid plate is made is significantly softer than that out of which the lines are made...
    :norton
  4. K2m
    K2m Long timer
    Feb 27, 2005
    2,262
    Sydney
    Take an angle grinder to the skid plate where it rubs. Problem solved
  5. Airhead
    Nov 22, 2004
    2,103
    I'm more curious than anything else...my stock plate is cracked anyway, so I am going to be replacing it with a Black Dog in the spring...
  6. Bonsai Elephant
    Bonsai Elephant Banned
    Jun 12, 2007
    18,756
    The Hills
    My stock plate didn't last long enough to wear through anything - holed first time off-road.
    Replaced it with a Black Dog!
    :lol3
  7. Boatman
    Boatman Membership has it's privileges ;-) Supporter
    Mar 9, 2005
    15,985
    Mill Spring, NC
    Hi Jeff, same here and I agree with you about the design flaw. I used an arbor press and "bulged' the area where the lines contacted. But after a couple trail riding excursions it's rubbing again. I'll be changing out the OEM skid also.
    BTW check your PM's
  8. jsrider
    jsrider Long timer
    Jun 30, 2004
    3,495
    Does anyone know for sure that the Black Dog doesn't rub the oil lines?
    #8
  9. Airhead
    Nov 22, 2004
    2,103
    I exchanged a few emails with them, and they said that they designed their skid plate specifically to not rub on the lines...
    Communication with them was very good...they seem like a class act.
    #9
  10. Bonsai Elephant
    Jun 12, 2007
    18,756
    The Hills
    They are one of the most customer service oriented companies I have ever dealt with and I cannot say a single neutral thing, never mind bad thing, about Black Dog or their product.
    You will not be disappointed in what you buy or the process you go through to purchase it.
    :thumb
    #10
  11. RumRunner
    RumRunner Sit there, turn that
    Aug 10, 2001
    9,193
    Great White North
  12. Airhead
    Nov 22, 2004
    2,103
    He didn't actually have the plate rub through the lines...which goes to my question. It appears to me that the plate will rub the finish off the lines, but that the lines are made of a harder material than the plate, and so will wear a grove in the plate rather than being worn through themselves. My lines look just like his...finish rubbed off, but no damage to the actual metal of the line.
    Not that that is a good thing, either...just curious if anyone had actually had the lines fail on them. I know Ricky did, but that was because his Touratech plate was hitting them. The stock plate is made from a very soft material...I know, because I had to grind it down to make room for my Facet pump. The angle grinder went through the stuff like it was warm butter...
    #12
