Call all XR600R!!!
Discussion in 'Thumpers' started by CSMonte, Dec 8, 2008.
  1. elsalvadorklr
    elsalvadorklr southern xr rider
    Nov 5, 2008
    4,158
    Columbus, GA
    yes!
    however they are semi new! they have 500miles on them...so it already was broken in if you will, how much I will find out soon I guess
  2. elsalvadorklr
    Nov 5, 2008
    4,158
    Columbus, GA
    THAT WOULD BE A BIG NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!
    I have opted for no zddp...
    I have done 4 oil changes since my last clutch slip scenario
    I ws told since its a semi new oem clutch kit that it might take a few rides for the plates to get to know eachother
    I also used 4 ebc springs instead of 2 oem and 2 hd....
    they are noticeably stiffer but not as bad as I thought....my oem springs measured just over 44mm well within spec, and they were exactly the same length as the new oem xrl springs AND ebc springs...
    however my old fiber plates were signifucantly thinner and glazed looking when comparing to the new xrl plates...
    thanks guys
  3. elsalvadorklr
    Nov 5, 2008
    4,158
    Columbus, GA
    im no enduro rider but I thinkI got one taken during a race...nothing too exciting, jajajaja:D
  4. Royal Club
    Royal Club Been here awhile
    Jul 18, 2012
    393
    The Netherlands
    show me!!!
  5. mrfixit54016
    mrfixit54016 Wisconsin Dual Sporter
    Jan 19, 2008
    966
    Hudson, WI
    I hear you...I don't think that stuff was ever meant for a wet clutch engine. Expensive lesson learned.
  6. elsalvadorklr
    Nov 5, 2008
    4,158
    Columbus, GA
    i guess it depends on who you ask...it did not work for ME on my old clutch thats for sure...I think I also abused it a little as I was using it to prevent overheating and thinning out of the oil...
    it worked great but over rthe 2 or 3 months i consistently used it probably did too much to the fiber discs...
    I guess? dunno
    Ill get some rides in hopefully and see what happens, thats all I can do
  7. elsalvadorklr
    Nov 5, 2008
    4,158
    Columbus, GA
    so Im going out for MY FIRST RIDE with a pregnant wife on the mind! jajajaja
    I have done a lot to the bike and am very thankful for those who again have helped me out
    tm38 flatslide is back on with an XRL boot(thanks steve. old time gift) it pushed the carb angle a bit down so now I dont have any fitment issues with the cable adjuster
    put in a leaner pilot jet 17.5 versus 20, I had kickback, so far so good
    replaces complete clutch pack and installed ebc hd springs...with an xrl clutch. we will so how this goes after some easy rides
    also changed oil twice and inspected my oil filter(by taking it apart) details about that later...in any case my engine is happy
    soooooooooooooooooooo
    wish me luck
    thanks dudes
    blessings!
    christian:D
  8. elsalvadorklr
    Nov 5, 2008
    4,158
    Columbus, GA
    SUCCESS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!:D:D:D:D:D:D:D:clap:clap:clap:clap:clap:clap:clap:clap:clap:freaky:freaky:freaky:freaky
  9. Mike the Yank
    Mike the Yank Long timer
    Jun 27, 2012
    1,298
    MILLJURAH Vic. Aus
    Thank God for that! :rofl
    Now, part numbers????? :ear
    I want to do my XR clutch too.
    Last time out it was slipping, ether the synthetic oil or the clutch has to change, I thinking maybe both. :wink:
    Only want to do it once though.
    :1drink
  10. MCCOYBOY
    MCCOYBOY Been here awhile
    Jan 17, 2012
    384
    Swanton, MD
    Anyone have any experience with the Edelbrock carb on the xr600?
    Never mind. I used the search option lol.....
  11. rod.whayt
    rod.whayt Adventurer
    Aug 4, 2012
    11
    omfg cold starting bitch .. yes i know its 34* out but really that many kicks and that long .....uuuggghhhhhhh wtf .. perhaps it needs a re-jet
  12. creaky
    creaky Been here awhile
    Apr 4, 2008
    188
    Indiana
    Yes, had Eddys on 2 stock 600s and an HRC 628, big performance improvement across the board. Unfortunately, Edelbrock no longer markets these carbs and does not provide parts and support. If you can find a new or good used one (Edelbrock # 3113) for a reasonable price, they do last quite a long time with proper maintenance.
  13. JAB
    JAB Unsprung Weight Supporter
    Dec 2, 2004
    1,941
    Beautiful Monrovia
    Yeah, it is cold. Be sure to keep the throttle closed, choke on and have at least enough fresh gas it the tank fill the bowl. If everything is in order, it should start. Any mods or other problems before this?
  14. elsalvadorklr
    Nov 5, 2008
    4,158
    Columbus, GA
    yeah it rocks,
    clutch kit get an oem xr/xrl clutch pack
    springs are ebc csk116 springs...
    Also I can now vouch for the cheap WINDEROSA clutch cover gaskets...they fit better than the k and s gaskets, however they have no glue...but I fitted dry with a dab on the grommet as usual and tight as can be
    these gaskets are about half the price of other aftermarket gaskets but nice quality I also traced the gasket on some cardboard so Im good to go there in case anything happens.
    cheers:D
    ps It appears my slipping was a combination of oil contamination(stp) AND slightly worn/glazed fibers...my steel plates were OK yet they had some discoloration and grooving...they were not warped however
    lastly my stock springs were perfect at 44mm, they did however feel softer at initial travel, the ebc are hard and stay hard throughout(thing fork springs straight rate versus progressive)
    my old ones felt soft the hard...aka progressive
    good luck mike!
    christian
  15. elsalvadorklr
    Nov 5, 2008
    4,158
    Columbus, GA
    hey creeky1
    I was looking for the eddys way back when I got my xr, I just could never find one...they were great I heard, I remember asking you about them a long time ago...
    in any case I can now positively say that on the cheap you can get the MIKUNI TM38 flatslide carb that after jetting for my altitude is now working great.
    I got mine for free, imagine that? and I can say that its definitely a better performer than the stocker...maybe not as good as some other carbs out there...but $$$$$$$$$$$$ value is sky high with this carb.
    In fact it was used on some model atk, with the xr engine so that means something, not to mention the old australian safari guys, and ballards, etc...
    you can get them used for as little as $50, however xrsonly sells them for about $250, jetted...
    If anyone is interested in aftermarket carb jetting with the tm38 there are a couple of good threads over on TT.
    cheers
    P.S. I finally have no kickback!
  16. elsalvadorklr
    Nov 5, 2008
    4,158
    Columbus, GA
    Hey dudes, for all those that helped with my kickback scenario a few months back...after getting my clutch installed and all here is what I concluded.
    1. It appears I was both lean and rich on the idle circuit, how I had some small cracks on the xr intake boot, what was weird is the many air leak tests did not alter the idle, however when riding the idle would creep...I also had too fat a pilot jet on the mikuni, a 20, instead of the 17.5 now...so that made hot starting worse too...I would kickback every 3 or 4 solid kicks....If my jetting would of been leaner I might of not had enough time to get a kicker...jajaja
    2. The xrl boot I have now installed was newer than both xr boots I had, one had a brocken lower bolt mount and the second developed these weird cracks.
    3. If you decide to use an aftermarket carb that has fitment issues I found out through reading many threads that the xrl boot has a slight DOWNWARD angle to it that points a bit down and to the right when facing the bike from on top...thise helps with the different cable adjusters or pulleys on some carbs...it is also slightly shorter, pulling the carb towards the head...
    THINK FCR41, TM38, etc...they have big bodies and addons that make fitment somwehat of an issue
    Finally, jetting
    for my altitude changes of about 3500feet from up in the city to the sea I had to compromise...
    so for my tm38(xrsonly) flatslide my jetting is:
    pilot 17.5 2 turns out(in is rich out is lean on these carbs)
    6fj41(leanest needle) in second from leanest clip(I need to be lean since I have cw hrc cam which requires less fuel at this position)
    220 main jet
    I beleive my throttle slide is the #2
    Hope this helps anyone in a similar situation, although I dont hear of many guys switching to these old school carbs anymore
    To notes is these carbs are what all the ballards guys and mostly asutralian racers used in the 80s and 90s, they were the defacto carb for big bore racers...
    Christian
  17. Clebner
    Clebner Lurkin Slacker
    May 19, 2008
    592
    Michigan's little finger
    I was having some trouble starting my bike when its cold too. I put a heat gun (glorified hair dryer) on the carb boot/ head for five minutes and it started first kick.
  18. lookfar
    lookfar from the land of OZ Supporter
    Feb 13, 2011
    1,504
    D'aguilar
    Mike, you have to use an oil that has NO friction modifiers in it. I used to use Shell Super SF back in the day when the bikes were new......
  19. husky123
    husky123 Long timer
    Nov 17, 2005
    1,508
    Leesburg, VA
    Hey guys,
    I'm finishing up my little XR project and after a couple rides my thoughts are turning to springs. A buddy of mine give me 2 "big boy" springs from his XR6R. One is an Eibach straight rate and the other a Progressive 1187 600/700.
    Is anyone running the Progressive springs here? Like them? If so, is the sag setting the same? Here's a little pic of her:
  20. husky123
    husky123 Long timer
    Nov 17, 2005
    1,508
    Leesburg, VA
    Well there goes that idea for a cheap spring. The shock/spring my buddy gave me was from his '89 XR600R and mine is a '99. I guess Honda made the switch to a bigger bodied shock at some point? Either that or is it possible this one (on the right) is from a 650L? Eye to eye length is the same on both it's just the newer one (right) has a shorter/wider spring. Thanks for any help fella's. Just want to make sure I order the right spring.
