Rallye navigation bracket photo thread
Discussion in 'Racing' started by wrk2surf, May 4, 2011.
  1. Seth S
    Seth S My avatar is ok. Your screen is broken
    Jul 19, 2004
    6,204
    Bridgewater VT
    Most rallies require a front number plate holder. This is what we fabbed up for my bike in Australia. Just a flat piece of lexan held in place with zip ties.
  2. redbastard
    redbastard Long timer
    Apr 23, 2008
    1,141
    Rat City
    Makes sence, looks no worse than my cut up rear fender :D. I like your hybrid front fender, the solution to the "high fender / low fender " debate is found.
  3. Seth S
    Jul 19, 2004
    6,204
    Bridgewater VT
    Thats the...its going back in the crate in 10 minutes to be shipped home front fender. :D
  4. theantipaul
    theantipaul Reforming Neandertal
    Nov 2, 2008
    1,865
    Niwot
    This is where I am now and will wait to hear feedback for the guys testing it.
    I've moved the connector rack back to the upper triple it allows for the horn and later a USB port to be mounted on the clutch side and then I can remove the throttle side for access and all the components will still be mounted up undisturbed. Also can switch between the Nav Tower and stock headlight within minutes. The whole thing comes off with 3 bolts/side and disconnect the wiring. then strap on the headlight mask.
    There are a series of holes for both the lights and the roadbook mount bracket.
    The lights are in the upper holes, but can be rotated 180deg and be 1 5/8" higher and of course lower using the lower holes. Using that the headlight mask could be moved all over the place depending on where you want it.
    I have the bracket mounted with 2 bolts/side, but have been riding with only 1 per side and it hasn't moved, I made the roadbook mount .005" wider then the rest of the parts such that when the bolts are all tightened up the roadbook mount is already under tension. It is in the 2nd of 4 holes on it, so it can be moved higher or lower or more forward as well as the headlight mask can be moved higher or lower.
    I've made it so I can take it off and put the headlight in the stock/lower Squardon position, but I've been riding it with the nav tower side plates in place, but the roadbook and mounting bracket removed.
    I'll be moving onto the fairing soon.
  5. Seth S
    Jul 19, 2004
    6,204
    Bridgewater VT
    Looks great Paul...very clean and compact.
  6. DaveRMS
    DaveRMS 404 Not Found
    Jul 20, 2005
    1,528
    0x00000000
    Paul,
    That kind of setup was very popular in Brazil at the Dos Sertoes. I like it a lot. Nice work!
    Dave
  7. Yellow Pig
    Yellow Pig Allergic to asphalt! Supporter
    Oct 28, 2004
    10,574
    Thousand Oaks, CA
    Very nice. I like how easy it is to go from RB set-up to dirtbike set-up.
    Will this work w/ a non HDB handguard mount. Say a BRP/Scotts damper mount?
    Can you show us a detailed picture of the top mount?
  8. crankshaft
    crankshaft Guns are for pussies
    Aug 12, 2004
    14,035
    Burlingtron,VT
    Looks excellent Paul, I like the fact that it's removable so easily. It's a great solution for the masses that don't want a full on "Dakar" set up and prefer to keep things simple. Easy access for repairs in the event of a crash and carrying a spare at a rally would be easy and would take up very little room.
    :clap Kick ass:lol3
  9. theantipaul
    Nov 2, 2008
    1,865
    Niwot
    Thanks Guys,
    Dan this is the only part that needs to be different the Scott's mounting plate, but for KTM's with this design and all 4 M10 bolts attaching the assembly down, I really don't think I'll be making a lesser version, it's proven to be very solid. I will look at making the Scott's mounting plate for 12mm setups like the CRF, WR's and aftermarket upper triples,
    The Scott's mount is adjustable,
    It's a variant of this, and will allow for any height risers needed for a comfortable position while standing.
  10. crankshaft
    Aug 12, 2004
    14,035
    Burlingtron,VT
    I want that for my 690^:lol3 I need a damper mount.
  11. barrier
    barrier Says who?
    Oct 27, 2008
    685
    North Wales UK
    Hey Crankshaft,
    The 690 version was signed off for production last year! Havn't you ordered one yet!
  12. crankshaft
    Aug 12, 2004
    14,035
    Burlingtron,VT
    I didn't know Airstream made rally fairings:lol3 Respect to you English folks, you get pretty creative in your sheds.
    Gryphus1 likes this.
  13. drc42
    drc42 Rally Dreamer
    Apr 13, 2009
    1,901
    New Hampshire
    Airstreams have more curves, reminds me more of the VW thing :lol3
    But yeah, gotta respect the "git r' done" method of fabrication.
  14. Yellow Pig
    Oct 28, 2004
    10,574
    Thousand Oaks, CA
    Or the slice & dice quality of the fairing.
  15. barrier
    barrier Says who?
    Oct 27, 2008
    685
    North Wales UK
    You want more curves! :lol3 More to your liking Sir!:wink:
  16. crankshaft
    Aug 12, 2004
    14,035
    Burlingtron,VT
    :rofl I love it!
  17. Baja Dad
    Baja Dad Long timer
    Jan 3, 2011
    2,736
    Norco California
    Scotts is so old school
    IMO; Go with the V4 GPR
    I have THOUSANDS of miles on both Stablizers and the Scotts is the same TODAY as it was back
    in 1997 when Ohlins was the maker
    Just a note: GPR has the Patten on the under bar mounting system.
    All the guys out there making Under Bar Mounts are in Violation. ( check it out)
  18. crankshaft
    Aug 12, 2004
    14,035
    Burlingtron,VT
    Yea but I have three Scotts dampers and they work great
  19. theantipaul
    Nov 2, 2008
    1,865
    Niwot
    I'm pretty old school and I guess I'm just a "if it ain't broke" kind of guy, I've had a Scott's since the early 90's.
    Let me know what GPR's patent number is as I'll need to include it as prior art and I didn't see anything that applied.
  20. KZJohn
    KZJohn Been here awhile
    Aug 15, 2008
    581
    Anaheim Hills
    So what is it you like better about the GPR? Does it feel better/different than the Scott's?
