Sydney to London on a105cc Honda callled Dot
Discussion in 'Ride Reports - Epic Rides' started by nathanthepostman, May 4, 2009.
  1. monkeywaythere
    monkeywaythere Scooter explorer
    Jul 4, 2009
    90
    soon to be sask Canada!!
    right i had a sim prob with a 110 monkey first check your manifold and carb are connected prop ie no leaks then set your needle to the middle setting (circlip in middle of needle) the start her up and screw the mixture screw in until she dies then out 1 and a quater to 1 and a half turns then in theory she should be running sweet as?!
  2. 396
    396 low-post lurker
    Dec 23, 2005
    209
    Simi Valley, Ca.
    Agree with checking the slide for free movement. Make sure it opens & fully closes smoothly. Pinching the cable when getting it back together may have caused it to stick.
    As said above, make sure the slide is not in backwards. It's easy to do, and will usually end up stuck wide open.
    When closed, there will be only a small gap at the bottom for air to pass. Maybe 1/16-1/8 inch. (1-3 mm)
    Did you remove the idle adjustment screw? If so, maybe it is screwed in too far.
  3. DC950
    DC950 Microadventurer
    Mar 1, 2004
    3,623
    Oz
    great carb advice, but look for the simple first. Are you sure the throttle cable isn't binding somewhere, causing the slide to stick open some? The grip may seem to roll back all the way but it may not. Put your eyeball on the carb as you work the throttle to make sure the slide goes all the way up and down, perfectly smoothly.
    This is not uncommon after pinching it under the tank (I had a broken wrist to prove it).
  4. Tompound
    Tompound M.M.S. Tommy
    May 24, 2009
    371
    TN
    This happens a lot with these bikes, the throttle cable will get pulled out of the cable seat at the carb and the rubber piece keeps it from going back in the seat, there for keeping the carb slide open. check this or the idle screw if you missed with it,
    make sure the length of the cable is correct.
    good luck
    cheers
  5. Machog
    Machog Adventurer
    Apr 13, 2006
    47
    +2 on the throttle cable being too tight, or incorrectly routed.
    Another thought, is the throttle return spring working correctly. You twist the throttle to start it, but its not springing back? Soon as it starts, go to the far end of the throttle cable and check to see if return spring is hard up against the idle adjustment screw.
    Machog
  6. Dr. Zombo
    Dr. Zombo I need a bike ...
    May 24, 2009
    214
    Holt, MI
    When you get to the states, you and Dot will have cool ale (no frozen swill beer), spicy home cooking and a roof over your heads in Michigan!:deal
    Ride on Dot!:clap
    Ride on Nate!:clap
  7. skeptic
    skeptic Been here awhile
    Jul 26, 2006
    308
    SoCal
    My old Honda TL125 (1973?) (probably running same or similar carb), has this issue. The slide in the carby is sticky and will not close from time to time even though you roll the throttle closed. I used some mildly abrasive polishing compound to lap in the throttle slide so it gained a little clearance and would close easier. Since your bike was running fine before, and tightening the bolts to the carb (which might possibly distort the carb body) was not necessary, it would seem that the most likely cause was the routing of the throttle cable. Perhaps you could test this theory by starting the bike up with the tank off or loose and see if symptoms go away.
    Thanks again for your updates.
  8. Kent Shaun
    Kent Shaun Adventurer
    Jun 30, 2009
    19
    The Garden of England
    Nate lad, I'd go with a trapped throttle cable, you've had the tank off and I wager that's what is causing your troubles. If it is a carb slide, you can use some chrome polish to help it slide up and down a tad smoother, I've used this method on a couple of my BSA's.
    Keep them yarns coming lad, they're GREAT. Hope to have that beer with you in Dover soon :D
  9. WOXOF
    WOXOF Just wander'n
    Mar 2, 2008
    706
    Ada, MI
    +1 on the throttle cable. You even commented about having it routed wrong and had to remove the tank again.
    Then proceed to the needle settings.
    Good Luck Nate
  10. Brainflex
    Brainflex Been here awhile
    Jul 17, 2009
    319
    Whakatane, Bay of Plenty
    Just to confirm, I checked my postie and the front sprocket does wiggle a bit. So thats OK. Carb? as above, great helpful advise there.
  11. nathanthepostman
    nathanthepostman Been here awhile
    Apr 28, 2009
    948
    After posting yesterday afternoon I went back to the hostel to consult with the Germans. Andreas had a satelite phone and called a mechanic friend back home who said just about the same things as the suggestions on here.
    And guess what...
    It was just a badly adjusted cable.
    It was Claudia who spotted it; getting on her knees and having look down the barrel of the carb with a torch. She said 'that should drop lower than that.' Of course referring to the needle assembly.
    So after much faffing and twisling of the adjuster bolt we finally got her right, punched the kickstart and listened to Dorothy sinjg softly in the Bishkek air. It was a moment I thought I'd never hear.
    Now doing a bit of admin stuff and then I pack ready to leave in the morning. Dorothy's delay now means we have a week to cross Kazakhstan. They tell me it's nearly 3,000 kilometres; it's gonna be tight.
    Thanks a million for all the help with the carbie. I reckon next time I might even be able to fix her myself!
  12. FES
    FES Been here awhile
    Apr 3, 2009
    128
    Portland, OR
    Sweet! Ride on Nathe and Dot. Ride on :ricky
  13. WOXOF
    WOXOF Just wander'n
    Mar 2, 2008
    706
    Ada, MI
    Safe Travels Dot & Nate :beer
  14. Mileater
    Mileater Been here awhile
    Nov 29, 2007
    380
    Christchurch, New Zealand
    Glad to hear it wasn't anything too technical and easily fixed :clap
    Rock on Dot and Nathan .
    Cheers :freaky
    Allan
  15. vOOdsy
    vOOdsy Been here awhile
    Jan 3, 2008
    774
    Eildon, Victoria, Australia
    It was always meant to be Nate..ride on!!!!!:thumb
  16. nathanthepostman
    Apr 28, 2009
    948
    When I took Dorothy out for the test ride she romped around Bishkek like a new woman.
    You'd never for a minute of guessed she was nearly and recently been flogged up some big hills. The new sprocket had caused the jerk at take-off, and with it being one tooth smaller it just added that extra little bit of thrust than the bigger one. I know I might not be able to cruise as fast but when I had such a job actually reaching cruising speed with the old sprocket I guess it doesn't really matter. Besides, I still think she should still be good for 65km/h.
    As for the needle I don't really know why it's made such a difference but now she idles much more smoothly with the response from the throttle much more gradual and smooth than it ever was before.
    My Dorothy's an all new beast.
    PS. someone asked about t-shirt's and yup, they're still for sale, just as long as you don't mind waiting a while for them. They cost 10 quid, with four or five of that going to the printer and the rest going to Comic Relief - a UK charity.
    Link here; http://t-machine.co.uk/postman/
  17. Poolside
    Poolside Syndicated
    Apr 1, 2003
    11,889
    Silicon Beach, CA
  18. Game over
    Game over Haha
    Apr 25, 2009
    137
    Texas
    First off, what is that? and where can I get one?
    Second, if you re routed the throttle cable a different way than it was, you may have taken some slack out of the cable and that can make for some odd adjusting. I know you have it fixed, but if you do have more trouble, 1/4" of slack can make a lot of difference. As far as your carb is concerned. The needle is tapered at the bottom end to regulate your air fuel mixture. The clip goes in the top at different positions to help you regulate the mixture.
    The needle regulates the air/fuel mixture from about 1/4 - 3/4 throttle, then the main jet takes over from 3/4 - full throttle. The idle jet and pilot jet control 0 -1/4 throttle. (This paragraph is generally accurate)
    I'm sure you really want to read about carb tuning while riding, I'll stop, you just keep taking pictures. When you are in Texas, let me know.
    Good luck,
    Doug
  19. nathanthepostman
    Apr 28, 2009
    948
    Hi Doug,
    That my friend is a bell. Not a loud more for show. To get one you have to join an Indonesian biker gang called Big Zoner and promise to open an English chapter when you get back. That, as far as I can see, is the only way to get one.
    That or visit a souvenir shop in Indonesian souvenir shop in Java and purchase one.
    Sorry if I'm not making sense. I'm updating after two beers and what withe the jubilaiton of having Dot on the road again I'm quite drunk.
    Ride safe everyone and remember to give your bike a name.
  20. nathanthepostman
    Apr 28, 2009
    948
    Juat posting to say don't panic if we're off line for a while. We've got a bit of a drive ahead of us in crossing Kazakshtan in a week.
    The tent's packed so we'll be sleeping in that rather than hostels in the city so not sure how much internet access we'll be getting until we touch down in Ukraine or Turkey, I'm not sure which.
    But we're excited to be finally on the move with a country to crack. Dorothy feels terrific with me in no doubt she'll make it to the far side of Russia where she can go wrong as much as she likes. But this next part I need her firing fine on every cylinder - okay the one she's got. I know she won't let me down. We've come too far and been through too much together to pack up as the finishing straight looms into view.
    This is it. The race to the end. All the faff and kafuffle is done with, it's just me and Dorothy aiming for the homec-coming date currently peniclled in for the 17th October. Apparently an Australian themed pub in London is going to let her ride right up to the bar to take the drink she thoroughly deserves.
    Come on Dorothy, it's time we hit the road....
