950 Adventure valve clearance question - What would you do?
Discussion in 'Dakar champion (950/990)' started by motoracer51, Apr 17, 2013.
  1. motoracer51
    motoracer51 Been here awhile
    Sep 18, 2009
    836
    Western Colorado
    First time checking the valves on my 2006 950 since I bought it last year.
    Bike has 18K miles on it, not sure of the valve check history.
    From my understanding the recommended valve clearances should be:
    Intake : .10-.15mm
    Exhaust: .25-.30mm
    All intake and exhaust on front and rear cylinders are measuring .102mm on the intake and .254mm on the exhausts.
    I know this is within spec, but do you guys think I should re-shim the valves to get to the loose end of the recommendations?
    Thanks!!
  2. SS in Vzla.
    SS in Vzla. Totally Normal? I'm not!
    Dec 31, 2006
    1,231
    Sugar Land, TX
    It's in-spec. Leave as is, go out and ride.
    The shims come in 0.05mm increments. If you re-shim, you will be out of spec.
    Yes, you can always grind a shim down to push your clearance more towards the middle of the ideal gap, but I'd leave it alone... It is within spec.
  3. motoracer51
    Sep 18, 2009
    836
    Western Colorado
    I think that's what I was figuring. Not really wanting to make custom shims.:clap
  4. Orangecicle
    Orangecicle On a "Quest" Supporter
    Apr 24, 2007
    5,641
    West Des Moines, IA
    My exact issue this year. All but the front exhausts were barely in spec on the tight side. Left them alone. I reshimmed just the front exhaust, which was tight.
  5. Alleycatdad
    Alleycatdad Unbunch yer panties!
    Feb 6, 2008
    1,776
    True Norcal, not that Bay Area/Sacto Crap...
    Not broke. Don't fix it
    S
  6. Pete156
    Pete156 I love to eat!
    Mar 21, 2006
    1,441
    Everett,WA
    Ride it
  7. Zuber
    Zuber Zoob
    Sep 28, 2004
    10,234
    West of the West, Oregon
    Shim it to the loose end, even if it's a little loose. It will run much better.
  8. motoracer51
    Sep 18, 2009
    836
    Western Colorado
    Just an update.
    I shimmed the intakes to the loose end of the recommendations, and left the exhaust alone.
    Beginning to put the bike back together. Been sitting, apart, since last July.:eek1
    I hope I remember where everything goes.
    I still have a Facet fuel pump to install, jet kit with remote idle mixture screws, starter torque limiter, and water pump seal and impeller to change out.
    #8
  9. bigkuri
    bigkuri Long timer
    Oct 31, 2004
    1,607
    Christchurch, New Zealand
    Good man - your valves would have been too tight otherwise... Loose is good.
    #9
  10. KnowFear
    KnowFear Adventurer
    Feb 10, 2003
    79
    Victoria, BC
    I have a similar question, for a 2006 950:
    Front cylinder...
    Inlet clearances were .11 and .13 (I'm going leave them alone).
    Exhaust clearances are .31 and .32 -- I am very tempted to leave them alone.
    Any recommendations?
    #10
  11. Motomedic
    Motomedic Over-caffeinated Raconteur Supporter
    Oct 4, 2004
    4,831
    Spokane
    For the record, Harley V-rod shims come in smaller increments...
    (and yes, they are the appropriate diameter :evil)
    #11
  12. kingrj
    kingrj Been here awhile
    Aug 14, 2005
    604
    Hattiesburg, Mississippi
    Ride that bitch!:clap
    #12
  13. KnowFear
    KnowFear Adventurer
    Feb 10, 2003
    79
    Victoria, BC
    Agreed. But you responded to the original post, not my question. Do you have an opinion on the .31 and .32 observed clearances? Thanks in advance.
    #13
