Back in Black
Discussion in 'Dakar champion (950/990)' started by Geek, Feb 21, 2011.
  1. viola-tor
    viola-tor Needs to ride!
    Feb 27, 2008
    2,075
    Rockies. Freakin' Rockies.
    You poor, poor thing, having to endure that awful Colorado existence... :D
  2. LoFlow
    LoFlow Long timer Supporter
    Feb 17, 2005
    1,035
    Kitsap
    Ah man I love that shot. I swear I can feel the sun on my shoulders.
  3. rnoliver
    rnoliver Adventurer
    Mar 5, 2012
    36
    First off, love the thread- read it all last night (stayed up way too late). Thanks for putting your HDB guards review in the thread as well. I have one question. I see you have a Kaoko throttle lock with your HDB brush guards. Did you buy the one for the stock 990 or the one for use with Barkbuster guards? I'm thinking the latter, but wanted to double check. Thanks again for all the posts- hopefully we'll run into each other- (Well, not literally...)
  4. elron
    elron Still Standing Supporter
    Jul 15, 2010
    744
    WI
    Geek, You are an electronics meister, I've really pick up a lot from your threads, here and elsewhere, on setting up all kinds of electronic and other "accessorizing" for the big KTM. My bike is a 2012 990 Adv R, my concern regards it's capability of handling a combination of additional electronic accessories mainly due to it's gen output. You've installed the voltmeter, obviously to keep track of what's going on with the power re your battery, my question regards just how much can the bike handle. Can one run aux lights, and heated grips, and heated clothing, and GPS, and cellphone/I-pod power and still be within the capability of this bike? I realize a lot depends on the draw of each, but they are fairly standard. How do you figure where the limit s/b other than trial an error?
  5. CamelBill
    CamelBill Ride It! Supporter
    Nov 17, 2007
    808
    St. Chuck, Mizery
    I have also learned a tremendous amount from Geek's posts (Thanks Geek!), and followed his lead and installed a voltmeter on my 950. Was out on it all day yesterday, and i can tell you tha the heated gear and grips do dry alot of power. Assuming your regulator is in good shape (mine is new), my experience is about 14.3 volts with nothing on. Grips draw it down to about 13.7, grips and heated vest down a couple more tenths. I avoid using my aux lights when I have two heat draws on, because they can suck a couple more volts. I don't like to drop below 13.5 volts for long, as I have a Shorei battery, and they need a pretty good charge.
    I'm sure Geek can (and likely will) provide a much more technical answer, but I thought I'd share my personal experience FWIW . . .
  6. elron
    Jul 15, 2010
    744
    WI
    Thanks, Camel, for relaying your experience, I find it quite helpful. Would you mind providing the wattage rating and brand/model of your heated gear?
    Looking forward to Geeks input as well on this subject.
    elron
  7. CamelBill
    Nov 17, 2007
    808
    St. Chuck, Mizery
    I use the TourMaster Synergy heated vest with collar, no other heated gear. Per their website, it takes 51.6 watts and 4.3 Amps.
    My grips are Warm-n-Safe with an in-dash variable controller.
    It all works out to be sufficient heat for down to freezing temps, with First Gear jacket and pants, liners
  8. keener
    keener Speed changes you.
    Feb 24, 2010
    2,266
    Toronto, Canada
    inspired by your idea I did this a while ago:
  9. gbowes
    gbowes Adventurer
    Jan 26, 2008
    22
    Cobble Hill, Vancouver Island, BC
    Hey Geek, I was wondering about the dash board on the handle bar mounts. what do all the switches do and where did you get it. I haven't seen one of those before.
    Greg
  10. kaia
    kaia team F5 ⌘R
    Aug 8, 2008
    4,394
    silicon valley, ca
    i think you're looking for stuff from Highway Dirt Bikes, of which Geek has the whole kit - Handguards / Mirrors, Top Clamp and Perch Switches
  11. mroddis
    mroddis Been here awhile Supporter
    Aug 16, 2011
    845
    Vancouver, BC, Canada
    Geek,
    Getting some winter maintenance out of the way and really want to do this - do you remember what size stud you used for this to get it "just right"?
    M
  12. Douf
    Douf Limey Bitch
    Feb 17, 2006
    1,009
    Close to Cumming (GA that is)
  13. Y E T I
    Y E T I Unpossible
    Apr 26, 2007
    8,521
    San Diego
    I know it's been a while since you posted in this thread, but I wanted to thank you for it. Some really good info here. Between you and Pyn, just about everything is covered.
    So what exhaust did you end up with? :hide
