Wrenching on my R80 G/S, an ongoing therapy
Discussion in 'Airheads' started by One Less Harley, Feb 1, 2010.
  1. hardwaregrrl
    hardwaregrrl Can't shoot straight Supporter
    Jan 26, 2006
    10,219
    Atlanta
    I got me some moose racing open package pegs at cycle gear for 40 bucks!!! Welded new stops on and good to go!!!
    #21
  2. One Less Harley
    One Less Harley OH.THAT'S GONNA HURT
    Nov 16, 2006
    6,791
    Bowling Green, Ky
    Newest addition to the G/S- Sump and center stand guards. I tried to get the OEM BMW center stand guard, but they were NLA, so The other option was the Twin Headlight Earnie one, which looks better and mounts better than the OEM, but the Earnies' sump guard was not a design I liked, the rigid attachment to the sump was unacceptable. I decided against it after seeing Hardware Girl's on the ST.
    I purchased the sump guard, bolts, rubber spacers and washers from Chicago BMW and as luck would have it there were none in the USA, but there was ONE left in Germany. YEAH THAT'S RIGHT ONE.....ONE ...ONE, WHICH MEANS THAT THERE WILL BE NO MORE OEM ONES EVER!!!! I don't think they will be making any more ever again.
    new sump plate pict
    A shot of the 22mm headed bolts (note the shank on the bolt), rubber spacers, and flat washers which mount between the rubber and sump.
    sump plate hardware pict
    Another shot of how the mounts are assembled.
    A comparison shot between the little bitty stock guard, note the cooling vents, sure wish the big on had these!!
    pict of stock sump plate
    A nice neat fit to the Twin headlight Earnie center stand guard.
    center stand guard pict
    #22
  3. hardwaregrrl
    Jan 26, 2006
    10,219
    Atlanta
    looks really nice. and sharp!
    #23
  4. One Less Harley
    Nov 16, 2006
    6,791
    Bowling Green, Ky
    BTW, no pictures here as I was in a hurry, but my front brake was a little soft so, since I had the caliper and master cylinder kits on hand, I rebuilt them a cople of days ago. Lots better pressure at the lever.
    Pretty easy to do, just needed snap ring pliers to get the piston out of the MC, then for the calipers, compressed air to push out the pistons, (keep your fingers clear), a small pick to snag the piston seals. then just clean the parts well. The mastercylinde and calipers bores were in good shape so the master cylinder bore was lightly sanded and cleaned again, then seals and bores lubed with brake fluid upon assembly.
    #24
  5. AntonLargiader
    AntonLargiader Long timer
    Aug 28, 2003
    8,431
    Charlottesville, VA
    It's the wrong sump. That skid plate matches the smooth-bottom sump, not the early GS and /5 sump.
    The smooth sump is slightly deeper: http://www.largiader.com/tech/oilpan/
    #25
  6. One Less Harley
    Nov 16, 2006
    6,791
    Bowling Green, Ky
    #26
  7. AntonLargiader
    Aug 28, 2003
    8,431
    Charlottesville, VA
    My mistake - I thought it was the GS plate, not the G/S plate. But if you run across a smooth-bottom sump (and matching pickup assembly) it might give you a bit more clearance. I'll measure the critical dimensions at some point.
    Take care of it, you might have a collector's item!
    #27
  8. Gimmeslack
    Gimmeslack furthur
    Oct 2, 2007
    2,984
    Shenandoah Valley
    Are you saying G/S and GS skid plates are different? I always thought it was the same plate. I picked up a used one and it seems to fit fine. I was told it came off a GS by salvage dealer. :dunno
    #28
  9. Infracaninophile
    Infracaninophile Finding My Way..
    Sep 27, 2001
    7,531
    Rhode Island, USA
    I thought they were the same as well. Looking at the fiche shows different part numbers. The G/S is now showing NLA. The GS is still purchasable. I thought the engine blocks were exactly the same? Is it that the GS has the crossover tube and therefore the PD skid plate is different?
    Tom
    #29
  10. One Less Harley
    Nov 16, 2006
    6,791
    Bowling Green, Ky
    If I see a GS and/or GSPD at the European Rally this weekend I'll take some picts....as I'm curious now.
    According to the BMW fiche-sump guard #'s
    88-90 R100GSPD p/n 51-47-2-315-392
    88-90 R100GS p/n 71-60-2-315-345
    88-92 R80GS p/n 71-60-2-315-345
    #30
  11. AntonLargiader
    Aug 28, 2003
    8,431
    Charlottesville, VA
    MAX shows a pic of the GS plate. Narrower in the back, no cutout for the drain plug (makes sense as the smooth sump has a rear-facing drain). Most likely the difference originated with the different centerstand on the GS. Don't know if it's shaped differently around the exhaust or anything.
    I don't see why you wouldn't be able to retrofit the GS system to the G/S. System being plate, sump and pickup.
    EDIT: actually I don't think it is narrower.
    #31
  12. Infracaninophile
    Sep 27, 2001
    7,531
    Rhode Island, USA
    I have both a 81 G/S and a 93 GSPD in the garage. I can measure both and see what the differences are this weekend. Visually they look exactly the same.
    Tom
    #32
  13. One Less Harley
    Nov 16, 2006
    6,791
    Bowling Green, Ky
    I have been doing some jetting changes on the G/S, the bike was jetted with 135MJ/ 45 Idle jet needle position unknown, millage was OK, 42-44 on back roads under 75mph, but starting from cold was bad, as bike wanted to die when giving throttle until warmed up for about a minute.
    here's a list of jets and MPG figures for the bike.
    Note- I am not heavy on the throttle, and ride fairly sedate. Sometimes spirited but not extremely hard on it.
    Stock Carb Settings
    Main Jet 135 (150 stock, 130 stock for 1981)
    Idle Jet 45 (45 stock for 1981,40 for 83-86)
    needle Jet 266 (stock) , needle has about 15,000 miles
    Needle clip 2nd from top (3rd stock)
    Needle 46-241 (46-251 for 1981)
    <TABLE cellSpacing=0 cellPadding=0 width=698 border=0><COLGROUP><COL style="WIDTH: 68pt; mso-width-source: userset; mso-width-alt: 3291" width=90><COL style="WIDTH: 66pt; mso-width-source: userset; mso-width-alt: 3218" width=88><COL style="WIDTH: 89pt; mso-width-source: userset; mso-width-alt: 4315" width=118><COL style="WIDTH: 115pt; mso-width-source: userset; mso-width-alt: 5595" width=153><COL style="WIDTH: 75pt; mso-width-source: userset; mso-width-alt: 3657" width=100><COL style="WIDTH: 112pt; mso-width-source: userset; mso-width-alt: 5449" width=149></COLGROUP><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="HEIGHT: 12.75pt; WIDTH: 68pt" height=17 width=90>Main jet</TD><TD class=xl25 style="WIDTH: 66pt" width=88>Idle Jet</TD><TD class=xl25 style="WIDTH: 89pt" width=118>Speed/Conditions</TD><TD class=xl25 style="WIDTH: 115pt" width=153>Needle Position from top</TD><TD class=xl25 style="WIDTH: 75pt" width=100>MPG</TD><TD class=xl25 style="WIDTH: 112pt" width=149>Date/notes
    </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="HEIGHT: 12.75pt" height=17>150</TD><TD class=xl24>45</TD><TD class=xl24>65-70</TD><TD class=xl24>bottom</TD><TD class=xl24>38</TD><TD class=xl24>
    </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="HEIGHT: 12.75pt" height=17>150</TD><TD class=xl24>45</TD><TD class=xl24>60-70</TD><TD class=xl24>bottom</TD><TD class=xl24>38</TD><TD class=xl24>
    </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="HEIGHT: 12.75pt" height=17>135</TD><TD class=xl24>45</TD><TD class=xl24>-75</TD><TD class=xl24>3rd from top</TD><TD class=xl24>42-44</TD><TD class=xl24>choke not very effective</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="HEIGHT: 12.75pt" height=17>150</TD><TD class=xl24>45</TD><TD class=xl24>60-70</TD><TD class=xl24>bottom</TD><TD class=xl24>38.9</TD><TD class=xl24>
    </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="HEIGHT: 12.75pt" height=17>150</TD><TD class=xl24>40</TD><TD class=xl24>60-65 rain</TD><TD class=xl24>bottom</TD><TD class=xl24>41</TD><TD class=xl24>
    </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="HEIGHT: 12.75pt" height=17>150</TD><TD class=xl24>40</TD><TD class=xl24>55-60</TD><TD class=xl24>bottom</TD><TD class=xl24>39.7</TD><TD class=xl24>
    </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="HEIGHT: 12.75pt" height=17>142</TD><TD class=xl24>40</TD><TD class=xl24>55-60</TD><TD class=xl24>3rd from top</TD><TD class=xl24>44.02</TD><TD class=xl24>
    </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="HEIGHT: 12.75pt" height=17>142</TD><TD class=xl24>40</TD><TD class=xl24>55-60</TD><TD class=xl24>3rd from top</TD><TD class=xl24>45</TD><TD class=xl24>
    </TD></TR><TR style="HEIGHT: 13.5pt; mso-height-source: userset" height=18><TD class=xl26 style="HEIGHT: 13.5pt" height=18>
    </TD><TD class=xl26>
    </TD><TD class=xl27>
    </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl26 style="HEIGHT: 12.75pt" height=17>
    </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl28 style="HEIGHT: 12.75pt" height=17>135</TD><TD class=xl28>45</TD><TD class=xl26>
    </TD><TD class=xl26>1st from top 38
    </TD><TD class=xl26>2.68 needle jet, cold start BETTER
    8/16/2012, plugs dark, runs great, slight hesitation at constant speed of 50plus
    </TD></TR></TBODY></TABLE>
    132...................45.................................clip 3rd from top.......................2.68 needle jet.............black spark plug and exhaust...good power (4/10/2014)
    #33
  14. Beemerguru
    Beemerguru Beemerguru...G/S guy
    Nov 7, 2006
    3,681
    Redwood City, CA
    Try a 145 and needle on 3rd position and see what happens.
    #34
  15. One Less Harley
    Nov 16, 2006
    6,791
    Bowling Green, Ky
    I'll run some more gas though it to get some average mpg figures. Then try the 145's, I would expect the mileage to drop though.
    #35
  16. Rucksta
    Rucksta SS Blowhard
    Oct 26, 2008
    2,885
    Gold Coast
    Main 145
    Needle 2.64 position 4
    Needle jet #46-241
    Idle jet 45
    Idle air jet dia 1
    claimed 47.0 mpg @ 60mph (with a pointy headed anorexic midget rider)
    This was the spec for a non US G/S with no polution control.
    I think you must be getting pretty close.
    I never could work out what they meant by position 4 as my needles only had 3 rings.
    #36
  17. Beemerguru
    Nov 7, 2006
    3,681
    Redwood City, CA
    I use the european specs for the 800 engines after the emission plumbing is gone. Breathes better, runs cooler, heads last longer and decent mpg if you keep it under 70mph
    #37
  18. One Less Harley
    Nov 16, 2006
    6,791
    Bowling Green, Ky
    does that mean your using the 145 MJ as specd buy rucksta??? Should have mentioned that the air injection has been removed. No other mods. Fresh top end and new rings.
    #38
  19. Caddy82rats
    Caddy82rats Long timer
    Mar 8, 2007
    1,365
    South France
    I've got 135 with asymatrical inlet (Euro BMW upgrade)
    Better milerage, better low end response.
    #39
  20. AntonLargiader
    Aug 28, 2003
    8,431
    Charlottesville, VA
    There was a SIB to implement that here, also. AFAICT, every bike runs better with the asymmetric intakes and most of them have probably been converted. It can make a dramatic difference on the R80!
    #40
