Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old Yesterday, 07:37 PM   #5146
scudrunner82
combustion addict
scudrunner82's Avatar
Oddometer: 2,633
Originally Posted by OrangeV View Post
This morning in Canberra -3 degrees it was chilly but not frightening
I noticed my clutch side heated hand grip was not working, the other side was like volcano temp. Has any 1190 rider had this issue before?
I will have my workshop fit my Cyclops headlight upgrade and also ask them to look into the hand grip.
It worked all fine up until today.
Would anyone know what this could be... Love the 1190
Possibly a broken wire leading to the grip. I would check the wiring for anything obvious and then put a volt meter on the plug that the grips connect to (behind the headlight mask). If you have 12 volts there then its a faulty grip or wire leading to it.
The wires to the grips are constantly in motion/vibration so if they weren't routed properly they could fail. This happened to my air temp sensor wire.
Hungry Tenere TripTeam Ghetto Does a Hot Lap of America
350, 450, 848, 900, 1190r
My Youtube channel----- https://www.youtube.com/channel/UCXo...kdER0Y5QfoE9gQ
scudrunner82 is offline   Reply With Quote
Old Today, 01:52 AM   #5147
OrangeV
OrangeV's Avatar
Oddometer: 682
Thank you for your reply scudrunner82.
I'm booking it in next week..
75 V perky peak power from around 5000rpm and loves to be worked through the gears.
When you hit that sweet spot, it is simply electrifying. Stoner
A smile is a curve that sets allot of things straight..
OrangeV is offline   Reply With Quote
Times are GMT -7.   It's 09:50 AM.
