Side stand too long?
Discussion in 'Dakar champion (950/990)' started by fridgyis, May 18, 2013.
  1. fridgyis
    fridgyis Fridgy
    May 4, 2007
    52
    BC
    I have 2013 990 baja and run the stock wheels off road and a 19/17 combo on the highway. I am contemplating cutting an inch off the side stand because it is too long when running the 19/17 combo. It is difficult to get off the bike as it is too upright and almost tip over when on the side stand. If you are loaded with luggage it Iowa too long. Has anyone modified this? How much to take off?
  2. Soberman001
    Soberman001 Been here awhile
    Jul 13, 2008
    774
    New Jersey
    Yes, I have done this when I lowered my bike. Pretty easy if you are good with a welder. BUT.. if you change between the stock wheels and the 19/17 wheels you might want to consider an adjustable side stand which uses a lengthening bolt/nut in the middle for quick changes (requires a wrench). One of the guys here in ADV makes them. Do a search.
  3. PABiker
    PABiker Anywhere but here
    Dec 1, 2006
    4,458
    Pittsburgh, PA
    I do the same wheel swap, so I made the stand adjustable.
    First cut the stand, press a nut inside and weld it in:
    Then do the same to the base with a piece of all-thread, make the foot bigger at the same time:
    Put it back together with a jam nut and adjust it for both sets of wheels:
  4. Mr_Snips
    Mr_Snips Husky BRAAAAAAAAP!
    Oct 31, 2009
    356
    Yucca Valley, CA
    You can try adding a few washers on the bottom two bolts of the relocator to change the angle...cheaper and easier.
  5. fridgyis
    fridgyis Fridgy
    May 4, 2007
    52
    BC
    Hey,,
    I never thought of doing that! What a great idea! Oh the power of the forum always amazes me!
  6. Mr_Snips
    Oct 31, 2009
    356
    Yucca Valley, CA
    I can't claim the idea. I got it from another inmate on here. Just passin it along
  7. gefr
    gefr Life is a trip
    Nov 26, 2005
    5,158
    East Med, Greece
    Do you have a photo? Don't you need to unscrew these bolts to remove the adjusting washers and remount the screws? Isn't that more difficult from Pabiker's solution?
    Cheers
  8. brents347
    brents347 Trusting my Cape...
    Mar 5, 2006
    4,390
    Where the hell is Truckee, CA?
    The way Mr Snips is talking, it becomes a non-adjustable shorter sidestand and just leans more when on the 21/18 wheels.
    #8
  9. gefr
    gefr Life is a trip
    Nov 26, 2005
    5,158
    East Med, Greece
    So instead of cutting the sidestand, he repositions it, making it shorter to serve both wheel configurations.
    Cheers.
    #9
