Motion pro throttle body synch
Discussion in 'The Garage' started by Tomane, Apr 25, 2010.
  1. Tomane
    Tomane Adventurer
    Nov 18, 2008
    76
    NJ
    Only used once, now fluid has separated. Gaps in colunms. Is there fluid the only fluid that can be used or is there an alternitive fluid?
  2. TopDeadCenter
    TopDeadCenter Been here awhile
    Dec 7, 2009
    388
    NE of New Paris, WI
    I also have the same problem. Interested in hearing what others have to say as well.
    TDC
  3. Toolpen
    Toolpen Been here awhile
    Apr 22, 2010
    132
    I would contact Motion Pro and see what they have to say. I've always had good success with their customer PR.
  4. bisbonian
    bisbonian Long timer
    Nov 8, 2007
    1,780
    Tucson, AZ
  5. baloneyskin daddy
    baloneyskin daddy bikaholic Super Supporter
    Oct 21, 2009
    5,118
    southcentral PA.
    When not in use you should plug the lines back onto thenipples on the back of the unit to keep the fluid from taking on moisture which causes the separation in the tubes. Mine have mercury in them though I'm not sure about the newer ones.
  6. Midnightventure
    Midnightventure -
    Dec 23, 2008
    1,619
    Eldon,Mo
    My Motion Pro with mercury was always separating just as I was fine tuning things. I bought a Morgan Carbtune. It has steel rods that float in tubes. Works very well. Comes from England. I got it about a week after I ordered it.
