UHF Radio Questions
Discussion in 'Australia' started by ozadvntr, May 1, 2007.
  1. griffo1962
    griffo1962 Long timer
    Oct 24, 2006
    1,956
    Boonah, Qld, Australia
    so there's no way all the bits would fit inside a gutted battery?? that heatsink is massive......:huh
  2. Mike.C
    Mike.C Stelvio Dreamer!
    Dec 31, 2007
    595
    Brisbane-Australia
    No unfortunately there is no way it would fit in a space the size of a battery with the design I have. The heat sink will probably be able to be smaller but my plan is to encapsulate the whole lot in epoxy for protection and mount it elsewhere on the bike.
  3. Andy_P
    Andy_P Been here awhile
    Sep 2, 2012
    503
    Brisbane
    What voltage out do you need. You can buy switch mode regulators now that dont need heatsinks and are a lot more efficient. They would be much smaller too, as they use surface mount stuff...
    IF there is enough interested, I could knock up a small powersupply that should be able to fit in a battery space. Problem is to get circuit boards made you would need a few dozen people interested first otherwise its just to expensive.
  4. griffo1962
    Oct 24, 2006
    1,956
    Andy, the battery says
    7.4VDC, 1040mAh, 7.7Wh
    put me down for at least 1 :evil
  5. gsd4me
    gsd4me 90% bluff
    Dec 11, 2005
    10,779
    Brisbane, Australia
    Dead simple, but reliable. 5 watt UHF, with a dud battery hollowed out and 12 volt connection fitted. Power unit is in the fairing.
  6. griffo1962
    Oct 24, 2006
    1,956
    and you haven't had any issues with it being fed 12VDC instead of 7.4?? Id be worried about frying the radio.....
  7. gsd4me
    gsd4me 90% bluff
    Dec 11, 2005
    10,779
    Brisbane, Australia
    Nope. The same setup was on my 1100GS for a few years and quite a few thousand kilometres with no probs at all.
    Taken last year.
  8. griffo1962
    Oct 24, 2006
    1,956
    cool, I may give this a go then. I have a number of batteries that "sh!t" themselves
  9. Mike.C
    Dec 31, 2007
    595
    Brisbane-Australia
    You are way above me, the limit of my electrickery ability is just a kit from Jaycar..
    Is there not a possibility of RF interferance from the switch?
    Maybe this would work? http://www.jaycar.com.au/productView.asp?ID=XC4258
  10. OC
    OC Long timer
    Dec 20, 2011
    1,930
    Adelaide, South Australia
    I couldn't imagine putting up to 14.5V into the radio either. It reads to me that the step down converter is hidden under the fairing.
    Update: The Uniden to Sena cable received was the correct part. There is a manufacturing defect with threads missing from the collar.
  11. Dukehunt
    Dukehunt .
    Feb 20, 2007
    3,962
    NE Victoria
    Update: The Uniden to Sena cable received was the correct part. There is a manufacturing defect with threads missing from the collar.[/QUOTE]
    I must have got a different batch as mine is threaded.
  12. griffo1962
    Oct 24, 2006
    1,956
    David, can you confirm this please, does the radio run directly from the "12"VDC or have you got some kind of step down transformer "under the fairing"
    thanks
    g
  13. DMME
    DMME Old Fart, Older Bike
    Feb 10, 2007
    289
    Newcastle NSW, ('STRAYIA)
    I have refrained from commenting on the thread as I dont want to be seen as putting down other products, however just to save some heartache.
    The UH-076/8 will generally not be happy run off anything over about 9V, so YES you do need to sort a power supply to "convert" bike power down.
    IF you do do this then be aware if using a system (StarCom1, Autocom etc) you WILL LIKELY get earth loop noise, a lovely audible tacho :cry, not every time but it happens lots.
    MOST handheld's are now built to a price rather than a quality :deal, so running off things other than its own battery they tend to either RX OK and TX like shit, or TX OK and RX like shit, so be prepared.
    The best solution is to leave the battery in place and charge/power it as the battery in situ acts like a big filter.
    A 9V TO220 case volt reg (LM7809 for example) is sufficient, with capacitors on both input and output (standard design practice) and current limited on the output too wont need a heatsink and will fit in a matchbox :wink: (If people remember what one is :rofl).
    Have fun experimenting, dont be too pissed off when things dont work well, and good luck with it all
  14. gsd4me
    gsd4me 90% bluff
    Dec 11, 2005
    10,779
    Brisbane, Australia
    My UHF set up does indeed have a regulator that lowers the wattage; this is commonly available from places like Jaycar.
    When I said that it runs off 12 volt, I should have said that it runs off bike power and not batteries. Sorry that I misled youse.
  15. Andy_P
    Sep 2, 2012
    503
    Brisbane
    That's exactly what I am talking about. Switching frequency is usually just above audible frequencies, so no RF interference. Might be some harmonics, but unlikely to be an issue. At 7V output should probably do the job you want too.
    I was not going to suggest, but I also reckon running direct from 12V would probably be ok, but this all hinges on what sort of regulation is used in the radio. If linear, could be a problem. But most stuff these days uses switching regulators because they are small, cheap and efficient. I would not recommend anyone trying it themselves, but I am certainly going to have a crack with my wireless pacific radio when I have a chance.
    Just took another look at that jacycar switching regulator board, the output voltage can be changed by adjusting the value of a single resistor (R2 for the techo's).
  16. Tomack
    Tomack Been here awhile
    Nov 23, 2012
    158
    Cranbourne.
    Im new to ADV (forum & riding) & Iv got a cheap but trustie hand held radio(puxing 777) with a speaker mic that Iv used for trail riding, but now Im thinking a ear piece is the way to go.
    My question is: Whats the best ear piece design?
    Iv noticed differant set ups on egay.
    Theres an air tube
    http://www.ebay.com.au/itm/250810454336?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
    & a 2 in1 vib mic built into in the ear piece
    http://www.ebay.com.au/itm/110890439881?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
    cheers in advance
    Tomack
  17. Tomack
    Nov 23, 2012
    158
    Cranbourne.
    Any suggestions?
  18. DMME
    Feb 10, 2007
    289
    Puximg is the same conection as Kenwood :wink:
    Check the links in my sig for my suggestions :D
  19. felixblack1
    felixblack1 Been here awhile
    Jun 8, 2010
    336
    Australia, Sunshine Coast
    i've run the puxing 888 and 2 years still going strong. i've used that 2 in 1 vibe mic and it works ok. the PTT button wraps nicely around mirror mount within reach of your thumb. For trial riding it might get a bit hard to hear through the mic when ya get going. I've soldered a plug inbetween but still i find any corded mic combo a pain in the...
  20. Tomack
    Nov 23, 2012
    158
    Cranbourne.
    Cheers fellas:thumb
