Kick Startin' the Beast
Discussion in 'Thumpers' started by meat popsicle, Jan 7, 2005.
  1. meat popsicle
    meat popsicle Ignostic
    Feb 9, 2004
    14,742
    Circumlocution Office of Little Dorrit
    (Editor's note: posted this in Blood Sweat and Gears, didn't get one bite, only 50 nibbles... is it a lonely place or does everyone already know this stuff?)
    I have seen information here and there on kick starting bikes (usually when someone is complaining about having to... :lol3) but never a dedicated thread. That and owner's manuals never seem to cover it well enough.
    So I thought I would post this method taught to me by a friend who used to restore Husky's. In his obsessive/compulsive anal-sadistic ways he developed a system for kick starting large thumpers. It works like a charm on my 03 KTM 640 Adventure - easy as pushin' the button.
    This was key just this week when turning on the key gave me nada - a sign of my ongoing problem (to be fixed tommorow :freaky). So here it is - what do you think?
    And please, answer truthfully. This is for posterity... :D
    Kick starting thumpers
    Before anything else: is the bike on and out of gear? Kill switch set to run? Choked if cold? Remember to not touch the throttle! Good, now stand on the same side as your kick starter, lean the bike towards you slightly, and:
    1) Engage manual decompression lever,
    2) Kick thru several times with decompression engaged to get a fresh charge in the cylinder,
    3) Disengage the manual decompression lever,
    4) Lightly push the kick starter down until it engages the compression stroke (won't go down further),
    5) Engage the manual decompression lever again,
    6) Note: some of this step is KTM LC4 specific so you may need to experiment with other bikes. If you have e-start, gently push the kick starter down one more inch (stop!) to get the stroke past TDC reducing the compression for the kick start. If you don't then leave the engine a TDC (no extra inch!),
    7) Disengage the manual decompression lever and release the kick starter so it tops out,
    8) (Get Ready) Hop up and bring your weight down on the kick starter. Violence is not necessary, just a complete kick thru. If you give it a half-hearted, sissy-la-la, titsie-baby, candy-ass, rooty-poop kick... and don't reach the bottom, that the motor will take offense and try to put your knee thru your nose. Also, use whatever foot you prefer, and stop asking me to specify... user preference :lol3,
    9) Is it started already!?!
    Mine starts very easily this way; even the actual kick was easy! Replaces cursing with a smile. It only took my friend a year of troubleshooting to refine this method...
    The fresh charge might be one of the keys, but I think that #6 is the real key; this puts the piston just past TDC so that the piston is past the compression portion of the stroke. Even a high compression 600+ cc thumper is easy with this method. :nod
    PS - the LH kick doesn't bother me a bit. :dunno what all the fuss is about...
    timeOday likes this.
  2. creeper
    creeper Still alive...
    Dec 13, 2003
    10,718
    Puget Sound
    This is not needed Meat... well, not really. :evil
    All kick start systems have engagement and disengagement points. They engage, or "connect" to the driveline at some point just a few degrees past the position in which they normally rest, and disengage, or "disconnect" very near the bottom of the kick starter stroke.
    In other words, if you can kick it thru, to the bottom of it's stroke, go ahead and leave your precious foot right there... 'cause the motor could blow itself to kingdom-come with no ill effects to your body.
    It's only if you give it a half-hearted, sissy-la-la, titsie-baby, candy-ass, rooty-poop kick... and don't reach the bottom, that the motor will take offense and try to put your knee thru your nose. :D
    Love ya'
    Creepy :wave
    Bitingdog likes this.
  3. meat popsicle
    Feb 9, 2004
    14,742
    Thanks for the enlightenment creeper, I will edit the original to include this info. :thumb
    I noticed that my RD350 doesn't kick back on the bottom of the stroke, but with the LC4 I had never stayed on the kicker, I always popped off. Maybe it was because the first time I tried to kick it, I didn't move the stroke past TDC and when I jumped up and came down on the kicker, it didn't move... :huh and the bike almost fell over away from me! :lol3 And I am 200lbs.
  4. markjenn
    markjenn Long timer
    Nov 9, 2003
    10,728
    Bellingham, WA
    So gentleman, is the concensus that you stand to the left of the bike for these left-side kickers and use your right leg? I've had my LC4 for over a year and have never kick-started the beast. It's probably time to give it a shot so I'm not attempting it for the first time in a "must do" situation.
    Speaking of which, I almost had to give it a try "in the field" the other day. I ran low on gas and the thing sputtered to a stop at a stoplight. I switched to reserve, but couldn't get a fire relit for quite a lot of cranking, almost running the battery down. It finally fired and ran again just as the battery was giving its last gasp. (I was running around in traffic with an electric vest going, so I probably had the battery a little run down even before the stall. I don't get the impression these things have a lot of extra generating capacity.)
    I don't know whether it was conincidence but I think my opening the fuel valve on the right tank valve was necessary to finally get the thing to fire - just turning th petcock to reserve didn't seem to be doing the trick. I note that the manual says that if you run it low on gas, you may need a full gallon to get it to pump again, which is about the total reserve capacity in both the standpipe reserve and the right lobe reserve. Given that these bikes have a rinky-dink vacuum fuel pump, I wonder if they're marginal at priming and pumping when you get down into the reserve supply. The PO also fitted an inline filter - perhaps this adds to the pump's difficulty.
    It's a bit of a shock to pull up to a pump and run up nearly a $20 fuel bill on a motorcycle!
    - Mark
  5. dagwood
    dagwood Banned
    Aug 25, 2003
    35,395
    Vancouver, Not! BC...
    Same exact method I use. works like a charm even on the chilly 20* mornings. :nod
    Just don't try that method on an old XT/TT 500 . :lol3 it will put your knee into the bars and it will hurt for at least 3 days+
    "The green dot damnit the green dot"
  6. gaspipe
    gaspipe 50 years in the saddle! Old School ADV
    Jul 12, 2004
    11,456
    Counce, Tennessee
    I do that stuff, except number 6. I can feel the sweet spot just kicking through easily. The kicking it through a few times with the decomp lever pulled in is the key, at least for me.
    Both my BST equipped 640 and my FCR equipped 620 usually start on the first kick, and I do that sitting on the bike.
    My old Yamaha SR500 needs a different ritual.
  7. dagwood
    dagwood Banned
    Aug 25, 2003
    35,395
    SR500, xt/tt500 , I imagine motors are the same or close and yes it was a Ritual fersure. with Jaba the chickenblood and Rum it was still risky at best until you got it down.
    "Hey Dude, Can I take it for a spin?" Sure if you can start it.
    :lol3
  8. Jasper
    Jasper Adventurer
    Jul 21, 2004
    39
    #8
  9. gaspipe
    Jul 12, 2004
    11,456
    Counce, Tennessee
    :rofl:rofl:rofl
    If you don't know the drill, it could be an experience on those Yamahas, especially if you have a bigger carb (38mm) on there.
    Same motor, BTW.
    #9
  10. Happe
    Happe Adventure Bike Spanner Man
    Sep 25, 2003
    694
    Wales UK
    Hi Meat,
    Nice tutorial :thumb
    But :eek1
    its only true for the E-start generation of the Lc4 engine :evil
    It worked like a charm on my ADV '03 and all the other @ventures I know, but not on my Rally. The difference that finally makes my Rally start, ist this little inch after the Autodeko shuts the Outlet Valves (the loud klick).
    On the older Kickstart Versions you shouldn't set the piston after centre.
    The rest is exactly as you'd described.
    I had to learn it the hard way as I bought the Rally. I was kickin' for nearly 5 minutes and my lungs were hurting, I was sweating like a pig. Then the previous owner came and showed me how to do it, it was just this bloody inch. The Rally started first kick :cry
    And it does it ever since :wink:
    cheers
    Stefan
    #10
  11. meat popsicle
    Feb 9, 2004
    14,742
    Fellas,
    If you have the time please add your kicking methods for those bikes. How do they differ from the method you use for the LC4?
    #11
  12. meat popsicle
    Feb 9, 2004
    14,742
    I don't know why bikes w/out the magic button would need a different foot? :dunno Happe said his non e-start rallye is different too; what foot do you use Happe? :ear
    Plus I have been told not to kick start with the bike on the stand. I tried this once and even though it was the fact that I couldnt get the kick starter to swing (full compression :eek) that caused the crisis, the bike still tried to fall over as I was thrown off balance. :lol3
    I will add this into the description - any nay-sayers? :ear
    #12
  13. meat popsicle
    Feb 9, 2004
    14,742
    Thanks Stefan, I will add in that non e-start caveat. :thumb Could you elaborate a bit on the part I put in bold above? I don't know if I follow you exactly. Also check my original post, I edited in what I thought you meant. Lemme know if this is correct. :D
    #13
  14. vrago
    vrago Plays with dirt
    Mar 31, 2002
    899
    Occidental, CA - Sonoma County
    Is standing next to your KTM to kick it with your right foot kind of like sitting to piss?
    I had a XR400 which need a ritual with the decomp, right hand on the cross bar so no trace of throttle until it fired, etc.
    I've had no problem kicking my 640, and I have not been so precise about the process.
    Clearly some thumpers have more tolerance than others.
    #14
  15. dagwood
    dagwood Banned
    Aug 25, 2003
    35,395
    it's been along time but basicly they have a little window on the right end of the cam cover with either a green dot or red dot. red dot is 180 out green dot is just past tdc. manual decomp no clicker . one or two blips on the gas roll it over two or three + ,times run it to compression stroke pull decomp just until green dot shows or you feel the release sorta, right hand on the cross bar so no gas, give it your best shot. After awhile you dont much use the window and go by feel but if you screw it up it will bite back :lol3
    BTW I kick the Lc4 standing next to it. no biggy. I've used the left foot when I fuckerd up the start switch packed full of mud on the trail and it was like using my left...well you know. it worked fine but just felt like ...strange. :lol3
    #15
  16. meat popsicle
    Feb 9, 2004
    14,742
    So is using your right foot to kick considered :gay in America? The differences are so weird across the pond eh?
    For example, here in the USA top loading washers are the norm, and the new-fangled front loaders are just making their entrance. They are getting play because they use alot less water, power, and even soap. But they are usually about 2x the cost :eek All the progressives want them because they are eco-friendly. I think that is great but add that the front loaders are also easier on your clothes so those last longer :nod
    Across the pond in the EU, our Greek friends tell us that front loaders are the norm but everyone is salivating over the "exotic" top loaders. They are much more expensive and use lots of resources to run, but man-o-man is the grass greener on the other side of the fence! :lol3
    Oh god, the humanity!
    #16
  17. Happe
    Sep 25, 2003
    694
    Wales UK
    Hi Meat,
    For the normal start up in the morning or after a break I use the right foot, while standing on the left side of the bike.
    If I stall it somewhere I start it with the left foot, if its flooded I have to use the right foot, left is not strong enough to kick 20-30 times in a row :D
    Never kick it on the stand! It is not made for this.
    cheers
    Stefan
    #17
  18. Happe
    Sep 25, 2003
    694
    Wales UK
    Here you go:
    This is the magic Inch you shouldn't use on my un-magic Rally :wink:
    cu
    Stefan
    #18
  19. Happe
    Sep 25, 2003
    694
    Wales UK
    Anybody who writes shit like this has never kicked a KTM Thumper for 40-60 times in a row.
    :mrskbasa
    How to kick a KTM Thumper in 25 easy pictures
    and the following
    cheers
    Stefan
    #19
  20. meat popsicle
    Feb 9, 2004
    14,742
    I agree. What is it about things being different that brings the bigot out in us?
    Nice series of pics, but none of them compare to this one:
    holy belly fillers Batman!
    :lol3
    #20
