The 650 Dakar Thread
Discussion in 'Thumpers' started by underwaterguru, Mar 10, 2009.
  1. atFault
    atFault Logical Positivist
    Mar 8, 2009
    93
    Ottawa, Canada
    Yeah, it's called a plotter. You can either run them with pens or blades with some modification.
    Earlier models the stickers are under the clearcoat, but later ones they are on top. I'm not sure where the cutoff is, but my '07 has them on top.
    When you order vinyl it's up to you what you want to get, but essentially most places stock several thicknesses. If you tell them you want to use it on a motorcycle they will likely recommend 4 mil (0.004") thickness, but you may want to go with something thinner. 4 mil is stronger, wears better and lasts longer, but removal of it years down the road is a huge job. They want their work to look great when it's done and you to be happy till it's not their problem anymore.
    Something thinner will look the same, be ever so slightly less durable, just because of thickness, and be way easier to remove.
    If you think you will be removing or repainting in 4-5 years, I would go with 3.2 mil indoor/outdoor and save some money. If you are doing it never to take it off, then the thicker 4 mil might be the ticket.
    Oh, and, Corel Draw?!:eek1 Does anyone even use that for vector artwork anymore? Export that badboy as an .eps so that anyone in the world can open it.
  2. notmybikemodelname
    notmybikemodelname KOTW is a myth!
    Mar 5, 2008
    7,332
    That's a good story, have another one?
    Hey, Where'd I go:lol3 Now we're talking Photoshop!
    Funny how those two rocks look so much alike. And I always thought nature never repeated iteself exactly!
  3. underwaterguru
    underwaterguru Moto shop Adventurer
    Oct 31, 2007
    78
    Grand Junction, Colorado
    What is every one using for crash bars and what did you pay for them? Pictures will always help. There are a couple of used center stands for sale on e bay. chat soon
    xxxmauxxx
  4. tmotten
    tmotten Lefthand ride Dutchy
    Jun 28, 2006
    2,705
    Calgary
    Didn't like anything on the market, so I made my own. Air cargo handling boys managed to buckle one of them when we used them as tie down points, so I need to make one more. They handled what they were designed to do though.
  5. kovrob
    kovrob Adventurer
    Mar 17, 2009
    46
    Budapest, Hungary
    Yes, it is downloadable from: http://f650.hu/kovrob/dakarstickers.zip
    <?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:eek:ffice:eek:ffice" /><o:p></o:p>
    <o:p>Format: cdr v14 and eps</o:p>
    <o:p>The Dakar, Tuareg and F650GS(D) vector pictures</o:p>
    <o:p></o:p>
    <o:p>I hope, you can use it! ;)</o:p>
    <o:p></o:p>
  6. atFault
    Mar 8, 2009
    93
    Ottawa, Canada
  7. kovrob
    kovrob Adventurer
    Mar 17, 2009
    46
    Budapest, Hungary
    Rob, why don't use your body protectors? Or is it an unique moment?
  8. notmybikemodelname
    Mar 5, 2008
    7,332
    I was wearing my jacket that day that has built in armor. Got too hot:knary and took it off and strapped to back of seat.
    Also, haven't found any that I like and fit me well. And most importantly, it gets in the way of my expandable beer filled kidney belt.............um, I mean beer belly:freaky
  9. herrhelmet
    herrhelmet Land n sea adv
    Mar 13, 2008
    2,425
    USA West
    Dude, you need to find one of the giant pink chest protectors for big gals.
    Aren't you like a DD cup now?:rofl
  10. -N8-
    -N8- Ride like you stole it!!
    Mar 19, 2005
    125
    Marietta, GA
    Wanted to share my weekend project results. I did the LED instrument panel light replacements. I decided to go with red for the dials, since red is the easiest on the eyes at night. I bought the LEDs through http://www.superbrightleds.com
    Very happy, very cheap, and easy to install.
  11. herrhelmet
    Mar 13, 2008
    2,425
    USA West
    Very cool. Looks like a BMW car instrument panel...the way they should have done these IMO.
  12. kovrob
    kovrob Adventurer
    Mar 17, 2009
    46
    Budapest, Hungary
    does this fit well? :D
    7 weeks ago i broke my left arm (exatly the "olecranon") :cry because at this time wore my jacket without the inner thermo liner and the loose elbow protector turned out. One metal plate, eight screw, x months relaxation... :shog
  13. Stegerman
    Stegerman MotoOCD sufferer
    Dec 19, 2008
    590
    SW Idaho
    Very cool.. for us lazy guys mind sharing which bulb part #?
    THanks
  14. -N8-
    Mar 19, 2005
    125
    Marietta, GA
    They are 74-x Wedge Base LED bulb. I used the 74-xHP Wedge Base LED bulb for the 4 bulbs that light up the tach and speedo. I wouldnt use the Highpower for the warning lights. The regular LEDs are plenty bright enough. Also, from what I read on F650.com do not replace the turn signal bulb because it will cause it to flash rapidly.
    Good Luck
  15. -N8-
    Mar 19, 2005
    125
    Marietta, GA
  16. JDLuke
    JDLuke Ravening for delight
    May 3, 2007
    8,646
    New Jersey
    I did all of the indicators on my F650GS a couple of years ago, also using the parts from superbrightleds. They all work fine, including the turn signal indicator... However, I did need to add a 'rectifier' to the circuit for the signals. Here's why:
    LEDs differ from conventional bulbs in many ways, but electrically the biggest differences are that they have far lower current draw, and that they are diodes. Diodes only pass current in one direction, so if you hook one up in reverse it blocks the current.
    The reason that replacing the turn signal bulbs causes trouble is that the flasher relies on (the heat generated by) the expected current flow through the bulb. With LEDs the current load will be so small that the flasher doesn't work properly. A flasher designed for this purpose, or added load resistors between each bulb and the power source will fix that.
    On the F650GS, the current direction to the indicator is different depending on whether the left or right signals are activated, so the dash indicator will only work for one direction. The rectifier fixes this by converting what is essentially a very low speed AC current with DC current.
    This is the thread where we discussed this stuff, which includes wiring diagrams and pictures.
  17. notmybikemodelname
    Mar 5, 2008
    7,332
    Bummer, Don't worry, the dirt will still be there when you heal. Hopefully your right arm is your drinking arm:freaky
  18. notmybikemodelname
    Mar 5, 2008
    7,332
    Is that what your lips are telling ya:D ?
  19. RagingBull
    RagingBull Stout Black & Tan
    May 27, 2009
    16
    Atlanta, GA
    Cant speak for BMW but does remind me of my XRS with all red tachs; very nicely done here -N8-!:thumbup
  20. Gravel Seeker
    Gravel Seeker Old, growing older.
    Apr 27, 2002
    12,166
    Dreary old Norway, dreaming of adventures past
    You attacked me wrong ! :D
    I have LED turnsignals and everything is just dandy. Don't think I replaced the relay either. Ofcourse my original dash is in a box somewhere and the TT dash indicators are wired directly/ home made piggybacked to each turn signal up front.:1drink
