Crashbars For 1996 R1100gs
Discussion in 'GS Boxers' started by dwj - Donnie, Dec 4, 2008.
  1. dwj - Donnie
    dwj - Donnie Long timer
    Apr 26, 2006
    19,099
    North Carrollton, MS - Traveling on the Moto
    Hi!
    I will be picking up my "new to me" 1996 GS next week. One of the few things it needs, or maybe it's me:D, is crashbars. Where are the best prices? I'm just interested in basic bars, nothing fancy. Thanks!
    Donnie
  2. Whammo
    Whammo Nature's toothbrush
    Nov 24, 2002
    2,217
    Rohnert Park, CA
  3. GSbiker
    GSbiker new and un-improved
    Jul 11, 2005
    12,465
    Wrong side of the tracks
    I have the BMW bars on my 95 GS. They have been tested quite a few times and have worked well. My only complaint is having to remove them to change the oil.
  4. mike wright
    mike wright Been here awhile
    Oct 6, 2006
    283
    Hepco and Beckers on my GS....
  5. Possu
    Possu de-nOObed!
    Jan 9, 2004
    5,235
    Oxford, UK
    H&B's offer good protection but on my partners 1150, I had to remove them at service time to get the valve cover off & on. Cover needs to go on square to the head so that the plug seal seats properly & this was hard with the H&B's in place.
    We both use Wunderlich 'bars with Stanton Headguards, no need to remove or loosen them off to access the valves.
  6. Stonewall
    Stonewall The Wild
    Dec 28, 2003
    1,809
    Bishop, CA / Castle Rock, CO
    I love them on my 95 GS. I do need to losen them to adjust valves, but I do not have to take them off.
  7. Dorian
    Dorian huge carbon footprint
    Jul 7, 2004
    1,058
    WA State
    I have a set of Touratech www.touratech-usa.com crash bars on my '961100GS. Easy mounting, good protection, they don't interfere with removing/replacing the valve covers and you can un-bolt the bottom supports for EZ oil changes.
    The 1100GS's are awesome bikes!
    Congrats on your "new" ride :clap
    - Dorian
  8. dwj - Donnie
    Apr 26, 2006
    19,099
    How are the SW-Motech from Twisted trottle for less than $200?
    #8
  9. Twilight Error
    Twilight Error Going nowhere slowly
    May 18, 2002
    22,878
    The Submarine Mines
    Reasonably good, mine have taken some very serious hits and they're still intact. The lower brace mounting scheme is a bit cheesy, I've destroyed more than a couple of the rubber mounts. Valve adjustments simply require a loosening of the bars, not a complete disassembly. The downside to them (so I understand) is the front mount over the alternator belt cover doesn't allow the mounting of an Ohlins shock. I do know it makes removing the belt cover something of a PITA.
    #9
  10. Farnsrocket
    Farnsrocket Gang Gang!!
    Mar 12, 2004
    4,334
    Central Ohio
    +1,000,000 :clap
    #10
  11. bananaman
    bananaman transcontimental
    Jun 20, 2007
    8,007
    I have BMW OEM. I would not recomend them. I have to take them off, competely, to change the oil. I don't have to take them off to get at the valve covers, but they don't protect the jugs very much at all. I've dropped it hard enough to break the plastic covers.
    If my crash bars are going to be a PITA, I'd rather have them actually, like, protect something.
    HB's look toughest. They're on my with list. Maybe somebody wants to trade?
    #11
  12. dmack
    dmack 96 R1100gs
    Nov 5, 2006
    172
    Central OR
    I have the SW bars and have been happy with them. Good price helps.
    #12
  13. dwj - Donnie
    Apr 26, 2006
    19,099
    Thanks for the advise!:clap
    #13
  14. crackhead
    crackhead Long timer
    Jul 18, 2007
    1,275
    Waay NW Washington
    SW Motechs are the shit in my opinion..
    #14
  15. Peka
    Peka Long timer
    Nov 12, 2004
    2,016
    Brisbane, Australia
    Hepco Becker on my 1100 too. I can just get the valve covers on/off without removing mine. I have to take out the bolt at the front for the cross piece to get the alternator cover off. I can even leave them on and remove the gearbox :D
    #15
  16. manfromthestix
    manfromthestix Lost in Space Supporter
    Dec 29, 2004
    6,743
    Lexington, Virginia
    +1 on Hepco Beckers, they work great on my 1150 and don't have to be removed to fiddle with valves or anything. Damn, I need to hang some big nasty lights off those things! :evil
    Doug
    #16
  17. Partagas
    Partagas EarthFirst
    Apr 13, 2007
    327
    Dofflemeyer Point
    GSbiker,
    I am surprised that you have to dink with the crash bars for an oil change!:huh Is this statement accurate?
    #17
  18. GSbiker
    Jul 11, 2005
    12,465
    Is true. The bars anchor to the bolts on the bottom of the skid plate. You have to lift the tank far enough to reach the two bolts and then drop the bars. I have been thinking about cutting the bars and making a joint in each side to correct the problem.
    #18
  19. sdpc2
    sdpc2 Just another Rally Rat
    Oct 10, 2003
    1,417
    Charlotte, NC
    with the mounting of the Touratech hard parts? Or did i read it wrong somewhere else?
    #19
  20. GS Dog
    GS Dog Adventurer
    Apr 24, 2004
    71
    Southern California
    +1 for the Wunderlich Bars. No hassle servicing. Just make sure that BMW Santa Cruz double checks that all the hardware ships out with the bars. Some hardware was missing when I received mine.
    #20
