Airhead rear drive removal question
Discussion in 'Airheads' started by Prairie Beemer, Nov 22, 2010.
  1. Prairie Beemer
    Prairie Beemer Adventurer
    Oct 5, 2008
    52
    Saskatoon, Saskatchewan, Canada
    I need to remove the rear final drive on my 1978 R60/7 for repairs off-site. Is it possible to do so without removing the right exhaust? The lower shock attachment bolt would appear to be problematic. Maybe I can detach the final drive from the drive shaft, loosen the shock bolts and then swing the thing up and away from the exhaust before removing the lower shock bolt.
    Thanks for any advice.
  2. boxerboy81
    boxerboy81 Stay Horizontal
    Jul 22, 2009
    4,824
    Melbourne, Oz
    On my R100rs 1982 model, I can remove the final drive, with the right shock separated from the top mount but attached to the fd lower mount. That leaves the muffler on.
    It's not too difficult to remove the muffler, and importantly, removing it gets it away from the bike and possible accidental damage from falling tools. Tiny little dents might be a huge eyesore to an owner, if the whole bike is otherwise in good nick.
  3. SprintSix
    SprintSix Been here awhile
    Dec 24, 2009
    152
    Ohio
    I think if you remove the top shock bolts, the swingarm will be able to move up and down. Move it as needed to access whatever nut. You may want to do a spline lube as long as you are halfway there.
