2012 KTM 350 freeride
Discussion in 'Thumpers' started by Bikeaddict, Oct 18, 2011.
  1. ADVJake
    ADVJake ***** dweller
    Aug 16, 2004
    4,340
    Sydney, Australia
    Why?
    It has the similar power output and more capacity. Going by on paper specs, i would have no doubt it would surpass a WRR's longevity.
    Thats the point too, its a lazy donk rather than a racey explosive bike like the 350exc.
    And whats very unusual from other motorcycles that have lazy donks, is the weight. Its lighter than the race equivalent.
    This is a very special motorcycle indeed...
  2. kyns
    kyns Long timer
    Feb 25, 2009
    3,678
    Because it seems to have a 350 RACING engine stuffed in it.
    Engine looks the same as 350 EXC, has same bore and stroke, most likely same oil capacity...
  3. bluesman
    bluesman Long timer
    Feb 13, 2007
    3,898
    Hoegaarden, Belgium
    the very main point of that bike for me personally is and was fact, that engine is VERY de-tuned.
    This automatically raises bar for wear and reliability, leave aside all torque talks.
    The engine is less stressed, so much less stressed I can see it being much more reliable than WR and easier on service. But only time will tell.
    Yeah, and one more thing. Leave aside 350EXC - when I tested WR (admittedly - on streets) I had to find tall kerb to get onto bike and use same kerb when I stopped. Because my feet were 10 cm from ground at least.
    So - this new KTM is answer for shortypants like me.
  4. ADVJake
    Aug 16, 2004
    4,340
    Sydney, Australia
    In that same sense, the R1 motor is also a racing engine in the GP. The WR250R takes 1 lug off it, and detuned.
    The 350 freeride motor may have racing heritage, but any race motor that has power output reduced for longevity will last a long time.
    The KTM LC8 motor was raced in the dakar, but is proven to last well over 200,000kms because they have detuned it below 100HP (while even the TL1000R suzuki twin makes 110+HP)
  5. flatboarder
    flatboarder Been here awhile
    Mar 17, 2010
    277
    Austria/Europe
    Not true, in particular.
    The engine looks like the EXC engine, but was modified internally.
    For instance they inserted steel valves instead of titanium for better durability.
  6. kyns
    kyns Long timer
    Feb 25, 2009
    3,678
    I had a WRR. R1 is a street bike.
    I'm curious how they have made the 350 more reliable. If it's reliable and cheap, i get it.
    They could have just made the 350 EXC more reliable/low maintenance, it has better suspension, bigger tank and really doesn't weigh that much more.
  7. Grreatdog
    Grreatdog Long timer Supporter
    Apr 6, 2007
    38,748
    Annapolis, MD
    For me, a motorcycle like the Freeride has a very different role from an EXC350. An EXC350 is a very fast offroad race bike that will get you through pretty much any trail. But it is going to work you hard on really rough, low speed terrain. All fast bikes make you work when you are picking your way through snot.
    The Freeride seems to me more like a hybrid trials/enduro bike that you would ride to make that same terrain a lot easier and, to me, a lot more fun to ride. Those are two entirely different missions. What you call better suspension on an EXC wouldn't be appropriate for how I would use the bike because I want soft suspension
    Neither would the huge amount of power an EXC350 puts down. An engine tuned to pull from down low without a "hit" anywhere in the rpm range is perfect. I wanted an offroad bike in the stable that is small, very light weight, softly sprung and has good pulling power from zero rpm's to ride rock gardens and miserable trails.
    Too bad I started rolling my own before I knew about this. But at least I will have $5000 more in my checking account when I get finished. :lol3
  8. novaboy
    novaboy Been here awhile
    Oct 6, 2008
    723
    Rothesay, New Brunswick, Canada, eh
    +1, you hit the nail on the head with regards to the Freeride. Its not meant for dualsporting, or for racing, it's a fun lightweight trial/trail/woods bike. Unfortunately, the KTM websites in Canada and the US don't show the Freeride, only the European ones. Hopefully it will show up in North America because this for me is the perfect dirtbike.
  9. flatboarder
    Mar 17, 2010
    277
    Austria/Europe
    I had been riding a Yamaha Tricker for 3 years, starting with 2006.
    The Tricker had 120kg and an engine well suited for difficult climbing or riding slow and difficult passages. The Tricker engine had 19HP (EU). It would not give a lot of speed or perform at steep and long uphills, but it was extremely easy to ride for those slow and funny sections.
    The KTM Freeride would be my idea of a bike doing all things the Tricker could do. And I used it for everything including vacation rides in or through Italy (click weblink above).
    But the Freeride could do it much better.
    The Tricker for instance had 6l of fuel, but its engine consumed more then 4l/100km, which was way too much for it. I would expect fuel consumption considerable lower than 4l/100km with the Freeride, therefore everything would be possible that was possible with the Tricker despite its small fuel tank.
    The Tricker had a cheap Teikei carburator that was kind of cumbersome, also suspension was weak, und those small wheels introduced a bad restriction of available tires. This was the reason I sold it, but I definitely wanted to replace it with something better.
    I do like the WR250R I got me as a Tricker replacement in 2009, but in fact it is no replacement, since it is totally different. The Tricker was a true playbike compared to the WR.
    And I want that back :evil
  10. Kawidad
    Kawidad Long timer
    Jul 9, 2005
    6,620
    Central Coast, Cal
    From everything I've been reading I would bet a large chunk of money it is the fruit of the new Indian connection for KTM and may be assembled in Austria, but most certainly the parts are sourced from India. But, I'd also be willing to bet a smaller amount of scratch it is completely Indian.:deal
  11. Sumi
    Sumi Long timer
    Mar 30, 2010
    2,239
    Hungary
  12. LukasM
    LukasM Long timer
    Nov 15, 2006
    5,513
    On a RTW ride - currently touring the U.S.
    Austrian prices include NOVA tax, Germany is normally 10% cheaper, and the US even more.
  13. bluesman
    bluesman Long timer
    Feb 13, 2007
    3,898
    Hoegaarden, Belgium
    current in Germany 6995
    Italy 7200
    Wait 6 month after release :) it'll be less.
    Anyway - as I said before - WR costs more here ....
  14. bluesman
    bluesman Long timer
    Feb 13, 2007
    3,898
    Hoegaarden, Belgium
    Belgium...f...k.
    7200 Euro.
    Well, better than Netherlands. 7949!!!!
    OK, I am off to organs market :lol3
  15. TEZZA
    TEZZA ADV B4 DEM/TED
    Jul 16, 2008
    322
    N.E.Vic,Australia
    When you get a new bike ship the TLR 200 to me ????:ear
    Tezza:D
  16. windquest
    windquest Been here awhile
    Nov 25, 2008
    574
    Calgary, AB
    Love the look of the tiny dual exhaust...
  17. IheartmyNx
    IheartmyNx Ihave2draft
    Apr 10, 2009
    3,910
    Nashville TN, no chit, police state.
    Great.. A STREET LEGAL trials bike with a seat, AND a dealer network... There went $8,000...
  18. cat
    cat Long timer
    Jun 23, 2004
    1,323
    Durban, South Africa.
    Yes. :) With a much bigger tank and a seat, and probably more steering rake and so on. And a plonker 350, better thaan a 230 or something. And standard KTM enduro lights. Perfect.
    Some of the older guys will remember the OSSA Explorer. OSSA 1970's trials bike with slightly more rake and higher final gearing and a bigger tank and seat. This KTM is sort of like a modern version of that.
    Maybe just a case of what I can sell to get one. There is nothing else like it. We've even thought how it would be good to put a plonker engine like the Yamaha 230 in a KTM 200EXC.
  19. lowbudget
    lowbudget _twin brothers on the go_
    Sep 18, 2008
    328
    the old world
    My stab on a Freeride... Finally got around testing a trials tire on the 200...
    100kg, Large fueltank, something around 35hp, quiet when not reved to the max etc, probably better suspension etc.
    And it´s even cheaper than the 350 Freeride
  20. jesusgatos
    jesusgatos fishing with dynamite
    Nov 17, 2006
    3,187
    santa cruz mtns, ca
    Looks like Ossa's going to be making a modern version of that bike too.
    This one is not too far off-topic either.
