What Did You Do To Your KTM Today?
Discussion in 'Dakar champion (950/990)' started by DeeGee, Apr 12, 2010.
  1. NewToMe
    NewToMe safety 3rd
    Apr 2, 2014
    1,863
    Big D
    Took the drive sprocket cover off, scrubbed away all the old grease that had found its way into the nooks and crannies. A bit more than my usual "spray and wipe."
  2. kag
    kag Wander Lust
    May 29, 2012
    2,433
    Kansas
    I like it
  3. kag
    kag Wander Lust
    May 29, 2012
    2,433
    Kansas
    <iframe width="853" height="480" src="//www.youtube.com/embed/uePzwhVzTl8" frameborder="0" allowfullscreen></iframe>
  4. Stinkerbelle
    Stinkerbelle Been here awhile Supporter
    May 15, 2007
    170
    Alberta, Canada (but British!!!)
    I fitted the heated grips I bought last week - I only need the one as they cost an arm and a leg!:rofl
    Fairly easy job but you have to virtually strip the bike to do it. Also fitted some cheap bar-end mirrors following my experiment with removing the OE ones. I was amazed how much wind noise and buffeting was reduced but also how much you grow to rely on them - arrived home with a sore neck. If the new cheapo ones prove OK I'll upgrade to some that cost more than £12.50 ($20) and don't have wavy glass!
  5. GJ990
    GJ990 Been here awhile
    Mar 27, 2013
    386
    Central Florida
    So I did the 14k service:
    • Oil
    • filters
    • Rear brake pads
    Still need to do:
    • Front brake pads
    • sprockets
    • chain
    • Tires
    Then I took her out for Veterans Day:
    <iframe width="640" height="390" src="//www.youtube.com/embed/98a_cc3kUWQ" frameborder="0" allowfullscreen></iframe>
  6. Lupin 3rd
    Lupin 3rd Raygun Gothic
    Jul 9, 2009
    1,804
    MoCo, MD
    Around Michaux SF (South Central Penn.)
    <a href="https://lh3.googleusercontent.com/-u05isbtS-0E/VGPdXG4XKOI/AAAAAAAAGHY/Bz14JNjTzVk/s2560/20141111_112558_Milesburn%2520Rd.jpg"><IMG src="https://lh3.googleusercontent.com/-u05isbtS-0E/VGPdXG4XKOI/AAAAAAAAGHY/Bz14JNjTzVk/s1024/20141111_112558_Milesburn%2520Rd.jpg" width="1024" /></a>
    <a href="https://lh4.googleusercontent.com/-P_8ccOQEGBs/VGPZYoeOptI/AAAAAAAAGE8/-5mF29NBuBQ/s2048/20141111_112810_Milesburn%2520Rd.jpg">
    <img src="https://lh4.googleusercontent.com/-P_8ccOQEGBs/VGPZYoeOptI/AAAAAAAAGE8/-5mF29NBuBQ/s800/20141111_112810_Milesburn%2520Rd.jpg" width="800" /></a>
    <a href="https://lh3.googleusercontent.com/-t0tIs5bKHOI/VGPXMRoSz4I/AAAAAAAAGDs/PZcGHcS-S7s/s2048/20141111_114314_Milesburn%2520Rd_Richtone%2528HDR%2529.jpg" >
    <img src="https://lh3.googleusercontent.com/-t0tIs5bKHOI/VGPXMRoSz4I/AAAAAAAAGDs/PZcGHcS-S7s/s1024/20141111_114314_Milesburn%2520Rd_Richtone%2528HDR%2529.jpg" width="1024" /></a>
    <a href="https://lh3.googleusercontent.com/-t4EMg_U0dnM/VGPWhzYsKeI/AAAAAAAAGE0/vBAaM7Zb0H0/s2048/20141111_114334_Milesburn%2520Rd_Richtone%2528HDR%2529.jpg" >
    <img src="https://lh3.googleusercontent.com/-t4EMg_U0dnM/VGPWhzYsKeI/AAAAAAAAGE0/vBAaM7Zb0H0/s1024/20141111_114334_Milesburn%2520Rd_Richtone%2528HDR%2529.jpg" width="1024" />
    </a>
    <a href="https://lh6.googleusercontent.com/-ZcDCRo6N8Sg/VGPVFeK1l4I/AAAAAAAAGCQ/YSrkgj8XgFc/s2048/20141111_123912_Richtone%2528HDR%2529.jpg" >
    <img src="https://lh6.googleusercontent.com/-ZcDCRo6N8Sg/VGPVFeK1l4I/AAAAAAAAGCQ/YSrkgj8XgFc/s1024/20141111_123912_Richtone%2528HDR%2529.jpg" width="1024" /></a>
    Probably the last ride up there for the year unless we get some freakishly warm weather this winter... yea right :cry Most of the trees were already bare, next year I need to head up there earlier.
  7. Mad Cow
    Mad Cow Dakar Addict!
    Jan 7, 2011
    861
    Just outside the City of Dreaming Spires
    Replaced my leaky clutch slave cylinder with a shiny orange anodised Oberon one.... very Gucci :D
    And shoved some new rear brake pads in and swapped my knobbly shod wheels with the road wheels/tyres.
    The big Katoom lives again!
    Next job is to refit my Ralle Moto steering damper that finally came back from warranty repair in Ostralia this week (well actually it's a new one as the original got lost in transit)!
  8. GJ990
    Mar 27, 2013
    386
    Central Florida
    Removed the Baja decals since they were starting to turn yellow. Kinda like the clean white look.
  9. Qwik
    Qwik Adrenaline Addict Supporter
    Apr 27, 2008
    10,805
    Aspen Colorado
    Got some goodies from my Supplier ( it's a drug, that makes CJ my Dealer )
  10. Masso75
    Masso75 Been here awhile
    Dec 28, 2011
    407
    I'd like to mount a Rekluse exp clutch,is it a good kit for my 990 adventure s ??? Opinions?
  11. Young-Gun
    Young-Gun KTM Tragic
    Dec 6, 2005
    1,322
    Brisbane, Australia
    I've got the EXP 2.0 with the rekluse slave, I love it. I still use the clutch lever and forget that the rekluse clutch is even there. Then when things get technical and tricky, I leave the clutch alone, pick the gear and ride, no feathering needed. The best way I can.explain its effect is that it engages the clutch automatically to prevent a stall, the same as you would do manually
  12. Masso75
    Dec 28, 2011
    407
    Ok thanks......is it a good choice only for offroad or also for a street use ? I use my bike also in street......
  13. Young-Gun
    Dec 6, 2005
    1,322
    Brisbane, Australia
    Both, I probably do 75% of my mileage on the bitumen. I still use the clutch lever and don't force the rekluse to do its job all the time.
    Some people will tell you that it's no good for slow technical downhill riding as you will lose engine braking, I haven't found that to be true. As the rekluse is activated above a certain rev range (+/- 1600 RPM), you'd have to be in either the wrong gear which is your own fault not the rekluse, or going almost walking speed so the rekluse helps prevent you stalling.
    My honest opinion, get it :freaky
  14. Masso75
    Dec 28, 2011
    407
    Thanks a lot
  15. toto#77
    toto#77 Been here awhile
    Aug 26, 2013
    212
    Italy, Santerno Motor Valley
    New mudguard
    Loud pipes, save lifes
  16. twizted
    twizted n00b
    Apr 4, 2009
    9
    Quebekestan
    Nice !!!
  17. FakeName
    FakeName Wile E Coyote SuperGenius Supporter
    Jan 1, 2007
    2,157
    San Diego
    Update on this: Love these tires!
  18. oldfuddy
    oldfuddy Long timer
    Aug 28, 2013
    5,858
    SouthWest (AZ)
    found someone the 1290 approves of… new to me SMR with 3K miles, showroom mint, 100% original unmolested, all documentation and still wearing the original Scorps…
  19. Nowwhat
    Nowwhat I'll Go Second... Super Supporter
    Mar 2, 2007
    12,385
    On the Ground Laughing
    man you have the sickness.....bad.....:lol3:deal
  20. oldfuddy
    oldfuddy Long timer
    Aug 28, 2013
    5,858
    SouthWest (AZ)
    Couldn't afford it... Had to have it...
    Put riding on hold for 26 years... Making up for lost time.
