86 R80RT Speedo Repair
Discussion in 'Airheads' started by Damifino, Apr 1, 2012.
  1. Damifino
    Damifino Damn if I know Supporter
    Mar 3, 2006
    914
    Maryland
    My speedo is acting up and not working properly, the needle floats around reading mostly lower than actual and the miles are not accumulating.
    I have read about changing bad gears on the odo, but does that also fix the speedo needle floating?
    Am I better off sending this out and if so to who would be best? Any inmates fix em?
  2. wirewrkr
    wirewrkr the thread-killer
    May 23, 2008
    4,293
    HIGH desert
    You want to talk to WIRESPOKES who is a member here.
    He is purported to do a really nice job at a fair price.
  3. Mista Vern
    Mista Vern Knows All - Tells Some.
    Dec 1, 2005
    25,203
    McMinnville, Oregon
    +1
    And he is actually a nice guy, to boot!
  4. Wirespokes
    Wirespokes Beemerholics Anonymous
    Jul 26, 2002
    9,677
    Jackson's Bottom Oregon
    These are two different problems. The odo problem is common to these gauges, but something else is going on with the needle - and can't guess at that one without seeing it.
    These speedometers are actually two siamesed gauges - a speedometer and odometer packaged in one container. The odometer is gear driven off of the input shaft to the speedometer.
    PM me if you're interested in having it repaired.
    Ah HAH! so that's why you're always kicking me around! :)
