I've got the stock aux lights on my 07 GSA. They work, but I can't get them to turn off (aside from turning the key off). Anybody else have this problem? Any suggestions on how to fix it?
Yes I'm referring to the fog lights. Should I just get rid of that switch and put my own switch on there using the existing wires?
On my 07, when I turn the fogs off, it takes a moment or three for the lights to go off. If you decide to change out the switch, I am interested in buying it from you. Good luck with it.
My switch works some days, not others. I really don't care because I run them ON all the time anyhow. I took the back off the aux block and it was full of crap. Cleaned it up and that fixed me up... for 2 days :huh
I will let you know what I decide to do. After playing with the switch a little more, I found that sometimes the lights switch off, and sometimes they don't. My guess would be corrosion on the connections.
